V- lec MODEL ASW-H18A4/HSA air conditioner compressor cuts out.
Turn unit ON and it will run correctly. it may do so for few minutes or up to few hours. Evap fan continues to run as does cond fan. Only comp cuts out. Unit has no thermal OL. I suspect pc board has dry joints. Does any one else have any answers or know if i can get a replacement pc board?
Aircon cuts out after 20 mins and starts to blow warm air -
Posted on Jan 06, 2010
  • 306 Answers
If you get the numbers off the board give this web site a try. I live in the city they have shop in and they are very good.
Posted on Jan 28, 2009
What causes an air conditioner to continually reset itself to 28' after you set it to any other temperature?
Did you press ok after re setting ?, it may be set at 28 by default , if so go into settings a change this.
Nov 13, 2016 | Heating & Cooling
E-3Error detail Remote controltransmission error (transmitting error)
Inspected unit Remote control.
Dec 13, 2010 | Heating & Cooling
Reset button
Unplug it for a few minutes and see if this resets the unit and cures the problem. If the unit was running when you did this, you cut power to the compressor and it will lock out for awhile until pressures equalise. This is normal and is meant to protect the compressor from being short cycled.
Jul 21, 2010 | Fedders A6P09S2A Air Conditioner
Compressor will cut on run a few minutes and shut off hot air
The compressor is probably going out on overload. There may be a small refrigerant leak thus making the compressor run hotter than usual. If there is not enough refrigerant in the system, the compressor will not get the refrigerant back to it to keep it cool. This is a safety feature built into the compressor to keep it from overheating and locking up. You may want to take it to your local appliance store and have it looked at. Most of the time it usually is cheaper to buy a new unit than to pay for just the labor to have them fixed.
Jun 07, 2010 | Samsung AW1203B Air Conditioner
Unit cools for a few minutes then stops cooling. Even fan stops blowing air but the unit remains 'on'
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
May 21, 2010 | Samsung AW1003M Air Conditioner
Kenmore AC Model 25370156000 keeps shutting off and on by itself
If you have just installed this unit in your window for the season, you may want to wait a day or so, for everything in the unit to settle, and try again. You make have shaken it up a bit too much. If not.....sounds to me like it is kicking out on high head pressure. This happens when refrigerant gets too low, or there is air in the refrigerant system. There is nothing you can do to solve this problem, except take it to a repair shop. If I am correct what happens is you turn the unit on, and the fan and compressor start simultaneously, then after a few seconds (maybe up to a minute) the compressor kicks off, and the air gets warm, then the compressor kicks on for a few seconds, and we repeat. This is actually a safety mechanism for the compressor motor so it does not run without refrigerant. (That would destroy the pump.)
Jun 04, 2009 | Kenmore 76129 Air Conditioner
Air conditioning
My guess would be from what you have described is that the refrigerant pressure might be low and is tripping the low pressure cut off that protects the compressor.
Jun 01, 2008 | Amana PTC074B25AE Electric Heat Air...
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Oct 26, 2007 | Heating & Cooling
Heating & Cooling Logo
873 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
