Question about Dell 1135n AllInOne Laser Printer
Output bin full remove paper (no paper in bin)
This is a sporadic problem and when it occurs, there is no paper in the output bin. No flashing lights on the printer itself, just a popup on the computer re printing status. Thanks!
  • 105 Answers
SOURCE: No paper light stays on and printer won't print (paper is full)
There is a black, curved-shape piece that hangs down (protrudes) from within the paper bay (visible with cartridge removed) that is spring-loaded. That piece might be jammed or broken.
Posted on Mar 27, 2008
Corysf62
  • 188 Answers
SOURCE: dell 5200M laser printer
there is a flag in the output bin that lets the printer know when there is too much paper on top of the printer and it stops so that the papers do not continue to feed out and overflow.
Either the flag is stuck in the up position, in which case you can just gently move it so it is hanging straight down, or the flag has been broken off and no longer functional ( in which case the flag and/or sensor would need to be replaced).
Posted on Sep 28, 2008
  • 53 Answers
SOURCE: Dell Printer 1720
This error is caused by the the flap on the right hand side of the output tray (the tray the paper feeds into once it has printed). It becomes stuck in the up position and sends a false positive error to the printer. One "work around" for this is to tape a quarter to the plastic flap. This keeps the flap in a down position, thus negating the false positive. The other option is to call dell laser printer tech support to get it fixed. <If it is still under warranty>
Posted on Nov 22, 2008
  • 50 Answers
SOURCE: status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Posted on Mar 24, 2009
jbussine
  • 5 Answers
SOURCE: flashing:remove output and cannot print
Sounds like the Outputflag is sticking or not returning back to the proper position as quickly as i should. The output flag is gravity return in other words there is no spring required.
Perhaps there is paper or dust collecting in that area and causing the flag to stick... regardless follow these instructions to test this :
The output bin flag on the 1720dn is on the right side. (as you face the printer)
Turn the printer off, hold up the flag while pwring on, wait until al the lights stop cycling. the only light remaining ON (flashing) should be "Remove Output".
Release the Output Bin flag; the light should stop flashing (go out) and the "Ready" light
If this is the case try cleaning that area with compressed air to see if the flag will lower on its own.
Best of Luck
Posted on May 18, 2009
REMOVE ALL PAPER FROM BIN ,OUT PUT BIN IS FULL Hi
Does not sound like a paper jam problem but a sensor problem sensor acurator is broken or out of place or the sensor is bad worse case the control that the sensors reports to is bad. Check you Output Bin Sensor acurator.
Sep 06, 2013 | Minolta QMS PagePro 9100 Laser Printer
Paper Jam errror
Jam in output bin - duplex area
Error message
Jam in output bin
alternates with
Open door and clear jam
Description
Paper jam in duplex reversing area
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Jam in output bin - fuser area
Error message
Jam in output bin
alternates with
Description
A paper jam has occurred in the output bin near the fuser area.
Action
  1. Clear the jam.
Goodluck..
May 14, 2008 | HP Color LaserJet 2600n Printer
Output bin full
Power off your printer. Take out the papers and unplugged cables from it. Remove the cartridge and then check is anything jamming the paper inside.
After checking, reinsert the cartridge and plug the cables. Keep the paper and take a test print.
**You can also avail our technical support by visiting our website: http://www.vtechsquad.com
Apr 29, 2013 | Samsung Colour Laser CLP-320
Standard bin full
This error is cause by either having your output paper bin full of paper or the flag sensor out of alignment where the paper comes out of the top. Look at the top f the printer where the paper comes out and you should see a black plastic sensor flag, it should move freely. If it is stuck remove the top cover above it and try to free it so it can move. Below is a picture of the printer with the output sensor flag circled.
Feb 02, 2013 | Lexmark T632 Laser Printer
Hp 5550n error - standard output bin full please remove all paper from bin
After print paper reaches upper bin, you can observe a flag moving while paper coming out. once this flag is stopped moving printer treates bin full..check the flag is moving freely. open top cover clean this sensor.
Sep 21, 2011 | HP Hewlett Packard LaserJet 5550n Printer
Paper feeds about half way and then stops. All of the indicator lights come on.
If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing. If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on. If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
Apr 11, 2011 | Lexmark Optra E312L Laser Printer
The paper light won't stop blinking - there is more than enough paper, new toner, new holder in which toner sits and it won't accept manual feed. What's the problem ?
The light sequence means that the output bin is full. Remove printed pages from the output bin.
Press Continue to clear the error code.
For further assistance, please contact Lexmark Technical Support.
Jan 29, 2011 | Lexmark E250dn Laser Printer
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
Flashing:remove output and cannot print
Best of Luck
May 18, 2009 | Dell 1720dn Laser Printer
Dell 1135n AllInOne Laser Printer Logo
174 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
