Question about Dell Dimension™ B110 PC Desktop
Dell B110 won't display1920x1080 resolution
Good day. I just purchased a 21.5" Samsung widescreen flatpanel, which has a native resolution of 1920x1080. I've downloaded and installed the most up to date VGA and chipset drivers I could find from the Dell website, as well as the latest driver for the monitor itself from the Samsung website. All of the drivers are correct and working, but the image is still stretched out, and it will not show 1920x1080 in the list of resolutions in the settings. Any further ideas or links to a driver that might solve my problem would be greatly appreciated. Thanks!
  • Dell Master
  • 27,725 Answers
Click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system. also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal ,larger or custom settings.
Always click APPLY after making any changes Right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add at it to the toolbar On the top of the internet page you should Tabs File Edit View Favorites Tools and help Click on the view tab on the drop down list you should see a zoom % Click a different percentage also a text you might try a different text although this will not increase the of the page only the text fonts inside it. Hope this helps.
Posted on Jan 22, 2013
2 Suggested Answers
  • 1056 Answers
SOURCE: Intel 82845G Graphics doesn't support 1680x1050
You also have to install the monitor drivers.
And yes, the drivers directly from Intel will not work. Dell has a perpritory video, and you have to use the Dell Intel drivers.
I've installed a few of these, and I know they will work.
But I had to go with a 1280x1040 setting. It does work, and will fill the entire screen.
Another option is to put in a PCI video card (yes, a full size card will fit in the GX260's) One bonus to that is you can do multiple monitors. I've had best luck in the GX260's using video cards with an ATI chipset.
Posted on Aug 28, 2008
Why won't my computer dimension stop loading safe mode screen won't let me do anything ?
A b110? Oh wow, those are OLD!!! You may try to go INTO Safe Mode. It\'s going INTO safe mode because it\'s trying to tell you that the operating system is corrupted and for you to FIX IT
Apr 03, 2013 | Dell Dimension B110 PC Desktop
Proper PC Adjustment Parameters?
Hello,Instead of replicating your laptops desktop can you please try extending the desktop. This way your laptop can keep its native resolution and so can the projector. Let me know how it goes.
Nov 17, 2011 | Sanyo Office Equipment & Supplies
Just purchased and installed a new ViewSonic 22" VA2231wm widescreen monitor to go with an existing Dell OptiPlex GX620 desktop computer. While attempting to get better resolution, got 'Out of...
Download: http://www.viewsonic.com/products/desktop-monitors/va2231wm.htm
You need to set your PC to the native resolution of the monitor, if it is too high, you will get out off range message: native resolution is 1920x1080p @60Hz.
You can read more here about the message:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 02, 2011 | ViewSonic VX900 19" LCD Monitor
New purchase. VGA connection. First use, all was fine. Turned off, then back on, and image will not "center." Neither VGA Automatic nor the individual controls will adjust the horizontal enough...
Make sure you have your resolution set to 1680 x 1050 as this is the native supported screen size for this LCD. Also check your graphic card's overscan or manual adjustment settings. They might be manually set to offset the screen picture.
Hope this helps,
Chris
Jun 29, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
Black strip on top and bottom of screen about 5mm each and i can't fix it with screen menu.
Reset the resolution to be higher.
Many flat panel screens must work at their native resolution to be at their best.
May 23, 2011 | Dell E2210 22" Widescreen Flat Panel...
Can't get my Dell Precision M50 Laptop video to fill the screen at 1024 768 resolution. Video will only fill the screen when I set resolution to 1600 1200. Is there something wrong with my video card?
1024x768 is a native wide-screen resolution. more than likely your video card is fine and your notebook monitor does not support that format without shrinking the top and bottom which defeats the purpose of filling the whole screen. plug the kappy into an external widescreen monitor or TV and it will work at 1024x768.
Regards
Jun 06, 2010 | Dell Precision M50 Notebook
Lg 2242 won t display widescreen full resolution
the FX5200 doesn't support that resolution. You will need to buy a card that supports 1680 x 1050
http://support.dell.com/support/edocs/video/p57010/en/usage.htm#display_modes
Feb 05, 2009 | Star Computers & Internet
Round things are shaped like eggs
This is a widescreen monitor. To get the display to look right, you need to install the software that came with the monitor, and set the resolution to the manufacturer's recommended setting (the monitor's "native resolution"). I don't know what that is for the AL1917W. I have the AL1917, not the widescreen. A friend got a 21-inch widescreen and had the same trouble as you until we set it to the proper resolution. (And it looks great and I'm jealous!)
Nov 17, 2008 | Acer AL1917W LCD Monitor
Hannspree 19" Widescreen resolution available
I have the same problem. i downloaded a generic driver that allows 1600 X 900 resolution. this is better..things are taller rather than wider (with the 1280X1024 resolution). i dont understand why there isnt a 1440X900 driver available for XP systems.
Jul 30, 2008 | Hannspree 19" Widescreen LCD Flat Panel...
Dell Dimension™ B110 PC Desktop Logo
48 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
