https://docs.google.com/document/d/.../edit
Google Docs, Sheets, and SlidesDake parma trademaster section i ii band saw instructions parts. Dake parmatrademaster, section i ii, band saw, instructions and. Vertical bandsaws ...
if u cant remember your password or witch email u used to open your account, there is a tab u can click on that says...cant remember password or email. click on that and theyll send u your info, but youll have to remember what email address u used to sign up for yahoo. Note.. I use a Rolodex to keep all my email, website, subscriptions, and passwords in. when you sign up for something, put it in the rolodex or a card file. then put that in a safe place. It works...
First dump the old gas and put in fresh. Clean or replace spark plug.
Put a squirt of starting fluid in the carb. If it fires the ignition system is good. Do this a few times because there is still old gas in the float bowl and fuel line. When the fresh gas gets to the carb it will stay running. If it did not fire with starting fluid the points and condensor will need to be replaced and maybe the coil.
I am running Windows XP. My Franklin Rolodex RT-8212 is connected to a USB port through a USB to serial connector I purchased separately. I was getting exactly the same problem until I downloaded and installed a driver for my connector (even though the supplier pretended it was a plug and play device). In my case I had to set my connection setting to COM4 in the Intellisync Mobile Desktop application (under the Setup + Connection menu). It is working fine now.
Hi; I recently asked a question about the Rolodex 128; and I just found the answer at Franklin under manuals for RF-1000. The question was how to erase the whole card file in order to start over; and it said to push the restart on the back and then hit the enter button on the front (or maybe it was both at once). Anyway, it worked; in case anyone else had the same problem.
Good luck on fixing your Electrodex. I have three of them and all have problems mostly due to keys that no longer respond. I was able to open mine up fairly easily by removing the single screw on the bottom. Judging by the date on your letter, you have probably resolved your problems one way or another by this time. I found that the button contacts basically disintegrated and were beyond repair. If you have a solution and a fix, would appreciate hearing from you.
