Question about Gateway Computers & Internet
My gateway is stuck in configure 3 of 3 at start up
  • Gateway Master
  • 27,725 Answers
Turn on your computer. If your computer is already on, then reboot it. You need to see the initial display screen to get into the BIOS. Press the F1 key immediately in one second intervals when you see the initial screen displaying the BIOS provider information. The majority of Gateway computers use the F1 key. If, for some reason this does not work, then use the F2. All of Gateway's desktops use the F1 or F2 keys. this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. Hope this helps.
Posted on Jan 22, 2013
I want to know how I can re-set my 3Com 3crwe955275 wireless access point to its default factory settings. Can anyone help?
1 Remove power from the Gateway. 2 Disconnect all your computers and the cable/DSL modem from the Gateway router. 3 Using a straight through Ethernet cable, connect the Ethernet Cable/DSL port on the rear of the Gateway to any one of the LAN ports. 4 Re-apply power to the Gateway. The Alert LED will flash as the Gateway starts up, and after approximately 30 seconds will start to flash more slowly (typically 2 seconds on, 2 seconds off). Once the Alert LED has started to flash slowly, remove power from the Gateway. 5 Remove the cable connecting the Cable/DSL port to the LAN port, and reconnect one of your computers to one of the Gateway LAN ports. 6 Re-apply power to the Gateway, and when the start-up sequence has completed, browse to: http://192.168.1.1 and run the configuration wizard. You may need to restart your computer before you attempt this. 7 When the configuration wizard has completed, you may reconnect your network as it was before
Here on page 85 of the manual
3Com 3CRWE53172 User Manual Forgotten Password And Reset To Factory...
Feb 18, 2015 | 3Com Computers & Internet
Ethernet cable network doesn't work on my MP4000
You can use wifi OR ethernet, configure in user tools. -Carl
Mar 26, 2014 | Ricoh Office Equipment & Supplies
My computer is stuck in hybernation mode
Hi wushuassazin:
1. What exactly do you see on the monitor screen when the computer starts?
2. Do you see any error message?
Step 1: We recommend you to start your computer in last known good configuration and check if the computer starts.
a. Start your computer and tap F8 key continuously to see advanced boot options.
b. Select Last known good configuration and hit enter.
c. Check if the computer starts.
Step 2: If the computer does not start, then check if it starts in safe mode
a. See Start the computer in safe mode
b. Check if the computer boots to the desktop.
c. If it boots, then restore the computer to an earlier time.
See How to restore Windows XP to a previous state
Step 3: If the computer does not start in any mode, then repair install using Windows XP disc
a. See Perform a Repair Installation
b. Once you've completed the installation, check if the issue persists.
Also use a system utility software like RegInOut to fix and avoid all such type of windows errors.
Hope this solution works for you.
Dec 25, 2011 | Gateway Computers & Internet
Hi, I can't open the main modem configuration page. the modem is (thomson tg585 v8. and the page adress is 192.168.1.254 it opens for a minut or so after turning it off then on, then it shows explorer...
Please try one of the following option:
Browse to http://dsldevice.lan or to the IP address of your Thomson Gateway (by default: 192.168.1.254).
If your computer runs Windows Vista or Windows XP, you can also access the Thomson Gateway Web Interface using the Internet Gateway Device icon.
If you computer runs Windows Vista:
1 On the Windows Start menu, click Network.
2 The Network window appears:
3 Right-click your Thomson Gateway (displayed as THOMSON TGXXX) and click View device web page.
4 The Thomson Gateway Web Interface appears.
If you computer runs Windows XP:
1 Go to My Network Places.
2 The My Network Places window appears:
3 Double-click your Thomson Gateway (displayed as THOMSON TGXXX).
Be sure you don't have any popup blocker or firewall interfering.
For more reference here below the manual (Version 7 that is basically the same of V8)
http://www.cytauk.com/cytauk/userfiles/TG585-v7_SetupUserGuide_en_pdf.pdf
regards
Mar 22, 2011 | Computers & Internet
Gateway MT6707 Laptop...Will not boot. I get an error at start up to "fix problems or Start Windows Normally........I have tried both. Just gets to the screen That shows Gateway and Please...
You need to launch the Last know good configuration to get this fixed.
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Step 6: your PC will boot to the windows.
Dec 19, 2010 | Gateway MT6707 Notebook PC
My sony vaio cant configure properly
Start the Computer and keep tapping the F8 key to access the Windows Advanced Options.
Select Last Known Good Configuration.
If the issue persists, you can try start up repair from the Windows Advanced Options.
If the start up repair is not present in there, you can use the Windows Operating System disc to launch it
Mar 15, 2010 | Computers & Internet
How to change router settings for BUffalo WCR-G54 wifi router? i can't access the URL: http://192.168.0.11.1 thanks!
This is actually wrong: http://192.168.0.11.1
If your router is connected to your computer via ethernet cable you will be able to get the configuration page of the router.
Windows XP
1. Click start
2. Click run
3. Type cmd in the box and press enter
4. On the black screen type ipconfig and press enter
5. Look for the default gateway
6. Copy that and use that to access the configuration page using the internet explorer
7. Open internet explorer, type http://the default gateway you copied in the address bar of the internet explorer
ex: http://192.168.1.0
Windows Vista
1. Click pearl button (start in xp)
2. Click on start search box (run in xp)
4. Right click the black icon up at the top
5. Click on run as administrator
6. Click on continue
7. On the black screen type ipconfig and press enter
8. Look for the default gateway
9. Copy that and use that to access the configuration page using the internet explorer
10. Open internet explorer, type http://the default gateway you copied in the address bar of the internet explorer
Jan 14, 2010 | Buffalo Technology WHR-G54S Wireless...
Trying to set up D-link WBR-1310 with hughes net? internet works bypassing router, but will not work going through roughter.
The router will work properly with your internet connection if you have the right configuration. There is a configuration for cable internet connection and broadband internet connection. If you are using a broadband internet connection some of the ISP are providing a username and password before you can access the internet connection, so in your router, you will have to use the PPPoE username/password type of configuration. If you have cable internet connection, choose Dynamic IP DHCP and clone the mac address of your NIC by clicking the Clone Mac address.
Just in case if you don't know how to access the configuration page of your router follow the steps
1. plug your router to your computer via ethernet cable
2. If you are using windows XP
- click start
- click run
- type cmd
- press ok
- type ipconfig on the black screen
- look for the default gateway (this is the ip of your router)
- open internet explorer
- type http://the default gateway that you found
- press enter
- under internet, choose manual configuration
- save all settings after providing the correct configuration.
3. If you are using windows vista/7
- click pearl button
- click start search
- type cmd
- right click the black icon up at the top
- left click run as administrator
- click continue
- on the black screen type ipconfig
- check the default gateway
- open up internet explorer
let me know if this helped you we'll see what else we can do
Jan 06, 2010 | Computers & Internet
I have a Gateway NX570X that is stuck in configuration mode and just shuts off and on repeativly and the screen says "configuring updates stage 3 of 3 0% complete do not turn off ur computer it has been...
You have a virus and you can try to booup to a previous restore point. Or reload windows anfd run repair versus a full on installation i9f you want to save your data.
Please rate this helpful if you found this info useful.
Thanks
May 05, 2009 | Office Equipment & Supplies
Computers & Internet Logo
51 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
