Question about Toshiba 26HF84 26" TV
Menus but no Input
TV fell off the table onto its face! Now the menus display properly and seem to work, but they are on a black background -- none of the inputs generate a picture. No sound either. I haven't found any loose parts or wires inside. Any idea how I could isolate the problem?
  • Brian Rowbotham Sep 08, 2007
    I have been over all 4 boards three times with a magnifier. No sign of any damage.
    Sergeant:
  • 279 Answers
Have you checked what Tekwiz suggested? And if so, found anything? I'd suggest looking at where each of the input jacks meets the board they are mounted on. I assume there were cables connected to these, and that they received a good tug when the TV fell. If that is the case, it's possible the connection between the jacks themselves and the board they are on was cracked or severed. If they look good, check the rest of that board carefully. Since you're obviously getting no input from any port, and since, assuming there were cables plugged in, that board probably underwent the most stress, I would say it's likely the culprit.
Posted on Sep 06, 2007
  • 105 Answers
A careful visual inspection is the way to start. Examine the circuit board(s) carefully for cracks. This may require removal of the board & a magnifying glass. Inspect the connectors where wires enter the board, & pay careful attention to the areas around heavy components. Any cracks found must be soldered where they cross the copper traces on the board. The green coating (solder mask) must be scraped off prior to soldering. Most likely the damage is confined to board cracks, as most solid state components are pretty rugged & not subject to impact damage. Use extreme caution around the high voltage area, as the set may retain high voltage even when off & unplugged. The high voltage area is that around the thick wire that goes to the suction cup on the picture tube itself. If you are not comfortable doing on-board repairs, call a qualified technician to do the repairs.
Posted on Jul 20, 2007
6ya staff
SOURCE:
Hitachi tv showing only programmes in black and white menus still display colour
try changing the color system to ntsc 3.58..on the remote control
Jun 06, 2014 | Hitachi C29-F800S 29" TV
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
I have a Polaroid TLX-04240B It comes on and Displays the Polaroid logo, then it goes to a black screen with the HDMI1 input box on the top right hand corner. THis box eventually disappears, leaving me...
Buy another HDMI cable.Try another HDMI cable with another HDMI hub on the tv port.If u still have the same problems,mean the whole main tv Tuner signal board have problems and the caused.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.
May 19, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
Black screen on EVERY input/channel
Turn off the closed capition
Jun 19, 2009 | JVC AV-27530 27" TV
I have a 32" LCD TV that I can't seem to get any of my DVD players to work on. Keep getting error message "no video signal" but They use to work. help
How do you have your DVD player hooked up to your TV(i.e. composite, s-video, component)? Some DVD payers and TVs have menus to switch inputs and if you somehow switched off the input your players are connected to, you'll get a "no signal" message.  First try hitting the input button on your TV or the Input/connection option in your TV's menu.  If that doesn't work try hooking up the DVD player(s) with the composite Cable(yellow), the component(red,green,blue) and S-Video(black/round) at the same time. If you scroll through your TV's inputs you should get a picture on one of these connections and the TV should display which one. The display will usually be in the corner of the screen.
Apr 27, 2009 | Televison & Video
HD-A3 Movies Don't Play Video, but Menus are fine?
Might be a resolution issue, the menus are most likely in 480, while the video might be in a resolution not supported by your tv. Try changing the resolution and see what happens.
Jun 29, 2008 | Toshiba HD-A30 HD-DVD Player
JVC Flat screen TV LT-37E488, Hard to hear narration or dialogue over music
Are the settings on your tv set to mono by any chance? This sounds like the speaker output is not properly configured. Is this issue only persistent while watching cable? Have you had any issues with DVDs, blu-rays or Netflix? If so you can try doing a hard reset, unplug the tv from the socket and leave it unplugged for 15mins.
Apr 18, 2017 | Televison & Video
Toshiba 26HF84 26" TV Logo
57 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
