Question about Abit NF8-V2 Motherboard
LAN cannot work
My motherboard has LAN port but when i seach at network connection is not have..It's because of driver or something???
  • 53 Answers
You need to connect a LAN cable to it which is connect to another computer, network, router, and or hub. Then you need to setup the LAN network itself. Here are a few links that might help.
http://performit.co.uk/network/
http://www.firingsquad.com/guides/lan/default.asp
http://www.tweak3d.net/articles/network/
Posted on Jan 27, 2009
I have a D101ggc Intel motherboard, I have recently installed window XP on my p4 system, but even after installing realtex Lan driver from intel website, internet is not working on my desktop computer, the...
Hi, maybe you have installed the wrong driver get right one here:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D101GGC
Its this one you have to download and install:
LAN: RealTek* 8101L LAN Driver Select the exe program when you have downloaded it. Try also to seach for it manualy in the device settings. Maybe the LAN card is not working you can buy one to add in the white pci slot. Hope this will help you.
Aug 21, 2011 | Intel D101GGC Motherboard
My ports and my on board LAN are not working my motherboard is ECS PV4MM2..What shoulbe the proble and how can I resolve it.Yahks if you would respond immediately on my problem
Go to Device manager By following this steps
  1. On the desktop right-click on My Computer and click Properties or open the Control Panel and double-click the System icon.
  2. In the System Properties window click the Hardware tab.
  3. In the Hardware tab click the Device Manager button.
Then on left side Search for Yellow question mark on Ethernet controller if it occurs than the problem is that you have to reinstall your LAN drivers which can be Downloaded here
And If there is no Yellow Question Mark then you have to bring a LAN card and insert in PCI Express Slot.
Jan 28, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
My lan driver not work
Go to the following link, select your operating system then download it & install. http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Chipsets&ProductLine=Desktop+Chipsets&ProductProduct=Intel%C2%AE+865+Chipset+Family
After installing, right click on My computer, Hardware, Device manager. Check Any thing in yellow color in Network adapters or in any place. If it is related to network then, re-install Operating system & try. If nothing is in yellow color then the Ethernet port i.e., LAN port is gone bad replace the same & insert new LAN port in other slot i.e., PCI slot & install the driver & check. I hope it will work for you.
Jan 24, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Connecting inteface with computer- lan port
The LAN (or Network port) is located on the back of the motherboard. When you connect the cable from the AR 161 to the motherboard, the lights will start to flash - Green = Stable and Orrange = data flashing.
Sep 23, 2009 | Sharp AR-161 Laser Printer
Network driver
if u mean wired lan driver that is also called network lan driver then here is the file
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5GL-MX/LAN.zip
if u want to update directly from the manufacturer REALTEK of the lan card u can download here the updated driver
http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PNid=6&PFid=6&Level=5&Conn=4&DownTypeID=3&GetDown=false#RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L)/RTL8139C(L)+/RTL8139D(L)/RTL8100(L)/RTL8130/RTL8139B(L)
pls rate me FIXYA if i have fixed ur problem
Mar 03, 2009 | ASUS P5GL-MX Motherboard
Ethenet not reconized
Hi, If your son' s computer has a LAN port, then install the LAN driver. LAN port is different from modem. Modem is used for dial-up connection while LAN uses broadband or dsl connection. If you do not know where or how to find the LAN driver, post the manufacturer and model name of your LAN or the motherboard. You can also find it by right clicking the My Computer icon->Manage->Device Manager. On the right side, Expand the Network Adapter. You will then find the software that you are going to reinstall. Another thing is to try to update the driver if it works or not. Here are the steps :
  1. Right click My Computer icon.
  2. Click Manage
  3. A box will appear (Computer Management), Click Device Manager
  4. On the right side, Click and expand Network Adapters
  5. Right click the software, click update driver.
  6. Wait 'til it finds the necessary software.
  7. If it does, then your finished installing the Network Adapter driver. If it says it cannot find the necessary software, you have to manually install it.
  8. IF NOT yet installed, copy the Network Adapter software and paste it in google to find your Network Adapter installer.
I hope this fix your problem. Drop me a comment again if you encounter some problems, ok? I will assist you.
Jan 16, 2009 | Computers & Internet
ASUS P5RD2-VM MOTHER BOARD - lan port is not working not showing led on lan port jpshah j5p10shah65@yahoo.com
You have to install lan card driver to show your lan connection.
Check the cable is connected both end properly and other end pc is connected modem or switch is turned on.
Aug 26, 2008 | ASUS P5RD2-VM Motherboard
Lan ports dont work
Where you able to check the Network adapter on the Windows Device manager?
How to verify your Network card is working properly
If you are unable to resolve the problem with your intergrated lancard then you can add additional LAN CARD on your computer or you can also buy USB to LAN CARD adapter.
http://www.techdeals.eu/electronics-store/images/tduc0205-1.jpg
Mar 07, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Pano mgnetwork?
gud pm keanne...hmmm here's my suggestion:
1st u need to buy 8-Port Hub/Switch
NIC or LAN Card
7 pcs UTP Wire w/ RJ45 Jack on both end (depende sa haba)
Then connect smartbro to the CPU (Built-in LAN)
Connect 8-Port Hub/Switch to the CPU (LAN Card)
Install Hub/Switch Driver (If Needed)
Connect the 6 PC to the Hub/Switch
Setup your network using Network Wizard (Control Panel)
goodluck...
Jan 29, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Abit NF8-V2 Motherboard Logo
284 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
