Question about GPX MW-3847 MP3 Player
Mp3 files dont show up in sansa fuze music folder, but exist.on the player. when i run the player, it works fine all the music is there and no problems when i connect it to my computer to add/remove files in either auto detect mtp or msc mode, it also works fine aswell except one thing, when i go into the music folder nothings in it, all the mp3's which work on the player just seem to not exist, the drive reads as near full, which it is, but all files are not there. what up wif dat?
  • 3 more comments
  • fucwutuhrd Feb 12, 2009
    PSH mine wont show my music either and i want to delete some of the songs but i cant because i cant see them
  • Anonymous Mar 14, 2009
    same issue
  • Anonymous May 20, 2009
    just the same problem , have latest firmware.
    8gb full, can be played on fuze, but cannot be seen or accessed on PC !
  • DrTZ May 23, 2009
    Same problem. On my laptop, when I opened it in explorer, there were two folders: Internal Memory and External memory and it showed all my files in each. My new computer will only read it in MSC mode;
    When I go to My Computer I get:
    Removable Disk (F:) = please insert a disk in drive (F:)
    Removable Disk (H:) = got all my internal memory music files
    Sansa Fuze (G:) = Full of empty folders labeled MUSIC, PHOTO, VIDEO, etc...
    Updated firmware and monkey'd with USB settings, nothing seems to be working.
  • Anonymous May 24, 2009
    answer from sandisk support :
    Hello!
    Thanks for contacting SanDisk Technical Support. It isour goal to make sure you have all the resources you need to get themost from your product.
    First you have to make sure that youhave the latest version of Windows Media Player on your computer. Ifyou do not have the latest (version 11), please update it. Try toconnect the player to a back USB port of the computer. Make sure thatyou have USB ports 2.0 on your PC.
    If the PC still doesn’t recognize the player, please try to force the MSC mode:
    • Turn off the device
    • Switch to Hold/Lock position
    • Press-and-hold the Left << button while connecting the device to the PC
    Now try to low-level format the player:
    1. Right Click My Computer, select Manage
    2. Go to Disk Management
    3. At the bottom of the window you should have a list with different drives.
    4. Go to the Removable Disk (which has approximately the same capacity as your player)
    5. Right click white box on the right of the Removable Disk and select Format or New Volume
    6. Select the File System FAT32
    7. OK
    TheMSC mode is used in order to copy/paste music. You have to use the MTPmode in order synchronize music with Windows Media Player. If youcopy/paste files to the player while it is connected in MTP mode youwill not be able to see those files in the PC.
    To see how youcan create and download a playlist to your player, visit the URL belowand go to Windows Media Player 11 and see the movie 7) Adding aplaylist to your Sansa MP3 player in MTP mode using Windows MediaPlayer 11 (Windows XP | Vista).
    URL:http://www.sandisk.com/Retail/Default.as...
    Best regards,
    Cornel I.
With my Sansa Clip I just have to make sure it is set to MSC, then I can always see the files in the Clip from my computer. I transfer a lot of mp3 files to the Sansa Clip from a SmartCard with a Memorex TravelSync connected to both the Clip and a SmartCard reader. Initially, I couldn't figure out how I could play them on the Clip but not see them when connected to a computer. But when I set the USB Mode to MSC, I could see all the files.
Posted on Jun 07, 2009
    New Friend:
Hi i got the same problem, i got the sansa fuze with a chip for extra space, when i plug into my computer the first time it was great i got all my pics and music onto it, when i reformatted my computer and tryed again it only detects one drive and the other is unknown, none of my stuff is on there? when i unplug and look its on my sansa? ive updated it? can any one help me, im useing usb mode msc, its the only one that detects
Posted on Apr 26, 2010
I have the same problem, some songs that show up on my mp3 don't show up in my pc, so what can I do to see them? because I can't delete those songs now, since I can't see them! (I have the sansa c240)
Posted on Jul 24, 2010
SOURCE:
Why wont this sync with my itunes library?
Hi, Is the SanDisk Sansa Fuze compatible with iTunes? In some ways, it is. Unfortunately, the Sansa Fuze and iTunes don't always play nice together. You'll have to get a few workarounds to make these two sync together.
The SanDisk Sansa Fuze and iTunes
The SanDisk Sansa Fuze is natively a Windows product. You should be able to sync it with Windows Media Player automatically. However, not everyone owns a Windows PC and even if they do, they might store more music in their iTunes library.
If this is the case for you, you might find it helpful to be able to sync your Sansa Fuze with your iTunes music library. Bear in mind that you won't be able to sync apps, games or any other iTunes products that are not formatted for use on a Sansa Fuze.
Using iTunes with the Sansa Fuze
So, is the SanDisk Sansa Fuze compatible with iTunes? If you download the right software, it is. Apple offers a free download that works with many other non-iPod MP3 players, Sansa Fuze included.
Unfortunately, this product only runs on a Mac operating system. However, if you own a Mac, this is great news because it means you can still use your Fuze without buying a Windows PC.
If you use a Windows PC and want to transfer your iTunes music to the Fuze, don't lose hope - there's a way to do that, too.
Syncing the Sansa Fuze with iTunes
If you're using a Mac, visit this link for Apple's free software download. It comes directly from Apple, so you can be assured that it's spyware-free.
Install the software on your Mac. You need Mac OS X 10.4 or higher as well as iTunes version 8 or higher.
Plug your Sansa Fuze into the Mac and wait for the software to open. You should see a listing of your iTunes music library pop open in a window. You're then given the option to sync as many songs as possible onto your Fuze.
The syncing process is similar to syncing an iPod. Don't unplug the device until it's finished.
Syncing the iTunes Library in Windows
You can sync your Sansa Fuze with iTunes using a script called the Automator, found here. Once downloaded, open the script under your "Downloads" folder on your "C:" drive and find a string of characters that looks like this: "/Users/richard/Music/*.mp3".
Replace the name "Richard" with your own username. Don't change anything else. Select "File," "Save" from the menu.
Select the Automator icon with the right click button on your mouse and choose "Open with," "Automator Runner." If working properly, this should automatically sync the music from iTunes with your Sansa Fuze.
If that doesn't work, go into your iTunes library and highlight any DRM-protected tracks that you purchased from iTunes. Right-click and select "Make MP3 Version." These should now be compatible with the Automator.
This sounds like more or less of a "hack" than a solution, but this might be the only way to sync music from iTunes to your Fuze using Windows. If all else fails, make MP3 versions of the songs as shown above, then navigate to your iTunes folder where those files are stored. Then drag and drop these into Windows Media Player, where they should sync right onto your Fuze.
Hope that helps..
Feb 17, 2011 | SanDisk Sansa Fuze MP3 Player
My Sansa e260 player works fine, plays my music and everything, but I have a problem with adding/deleting music. When I connected it to my computer, it did not recognize the player and it did not show up...
MSC will allow you to see the expansion card ( 2Gig E200 series 4gig Fuze) mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion..... make sure your usb 2.0 driver is installed..Syncing to wmplayer puts music in the mtp music folder. change usb modes again and use the explorer to see the sansa msc lets you sync any Q/A IM or email me @ Schmead01@yahoo.com
Jun 23, 2010 | SanDisk Sansa e260 MP3 Player
Sansa Fuze not Regestering Songs
The device only likes mp3's. Most other files don't show up.
Apr 13, 2010 | SanDisk Sansa e260 MP3 Player
How do I download a book or music to my sansa . I just received it as a gift and do not understand how to work it. I want to download a couple of audio books and some songs
Use the supplied cable to connect the Fuze to your computer. It should show up as a removable drive, one of whose folders is called "MUSIC". Drag&drop your audiobook and music into that folder. For future ease, I suggest keeping the file structure, copying the folders intact.
Feb 19, 2010 | SanDisk Sansa Fuze MP3 Player
I don't know how to download music on my sansa fuze (4GB)
On your Sansa Fuze, go to the "Settings" menu, then go to "System Settings", then go to "USB Mode", then select "MSC".
Now, connect it to your computer, then double-click "My Computer" on your computer's desktop to run Windows Explorer. You should see your Sansa Fuze show up as "SANSA FUZE". Double click on "SANSA FUZE", and you should see a folder called "MUSIC". Copy your music into that folder. When done, unplug your Fuze and your music will be on it.
Jan 27, 2010 | SanDisk Sansa Clip MP3 Player
Sansa Fuze Music not showing up in the folders
check if you have a virus get firmware updates
Jan 23, 2010 | SanDisk Sansa Fuze MP3 Player
PC wont recongize Sanza as a drive
You could try a reset?
Press and hold for 20 seconds the ON and PLAY (>||) buttons at the same time.
Dec 28, 2009 | SanDisk Sansa Fuze MP3 Player
How do I delete multiple songs from my sansa fuse mp3 player?
HI,
To delete multiple songs you need to connect your Sansa Fuze to your computer and delete the files from the Music folder.Just press hold CTRL and select the song files with your mouse which you want to delete and then press the DEL button.
If you need any more help let me know.
Thank you
Aug 13, 2009 | SanDisk Sansa e260 MP3 Player
Sansa Fuze MP3 Player - it is loading pictures to
Is it Loading Album Art? If this is the case, I don't think you'll be able to to stop it, Album art is typically very tiny in file size, and should have negligable impact on your available space. If it is syncing automatically to a folder, try moving any pictures in that folder somewhere else. This can probably be done with Album art as well, but you'll need to turn on the Setting "Show all Files (Including Hidden and System Files) in the Folder Options Dialogue box.
Jun 26, 2009 | SanDisk Sansa Fuze MP3 Player
Deleting music off of my sansa E250r!!HLP ME
If you originally used rhapsody (or began in Rhapsody mode) , you have to use rhapsody to remove the songs. If that doesn't work, you can manually open the music folder by enabling "hidden folders" under "tools" -> "folder options..." -> click the "view" tab -> scroll and check "show hidden files and folders". Then go to My Computer -> Sansa e250 -> "system" -> "music" -> then delete the songs. I don't know the effects of using this method, so use it at your own risk.
Btw, Real Player should do fine as well.
Dec 22, 2007 | SanDisk Sansa e250 MP3 Player
GPX MW-3847 MP3 Player Logo
9,005 people viewed this question
Top GPX Audio Players & Recorders Experts
Joe Negus
Joe Negus
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
