Question about Hotpoint HSS25GFP Side by Side Refrigerator
Replacing Auger in ice maker
I bought this Auger part to replace in my ice maker. I can't figure out out to get the old/broken auger detached. I have it pretty much taken apart, but can't get the broken auger unscrewed from the plastic part. Can't figure how how it is screwed in to unscrew it.
  • Kim Romero Jul 20, 2007
    actually, I've been told that it is an auger (the twirly thing that pushes the ice forward) that goes into the Ice Dispenser. I can't figure out how to get the broken one off the claw type part that crushes the ice.
  • Anonymous Jul 30, 2008
    same
I have a hotpoint side by side fridge. the ice maker is still making ice but the auger is not working. no sound or anything coming from it. any ideas?
Posted on Mar 29, 2011
  • 139 Answers
Kim There are two Screws Holding the Complete Ice unit in Place,After Removing it it unpluggs inside the freezer,It would be advised to Replace the whole Unit ttech
Posted on Jul 20, 2007
  • loyd linker Jan 17, 2012
    what do you mean as the "whole" unit? What is the cost?
SOURCE:
Kenmore cold spot refrigerator model # 106.56662500 ice is not dispensing through the door. How do I fix it?
This is common in these units. When the dispenser lever is depressed, an auger motor rotates the auger wire. When the auger rotates, it pushes the ice toward the dispenser door and chute. When the auger is defective, it isnt able to push the ice out of the dispenser. You need to check the auger to determine if it is broken or disconnected from the auger motor. If the auger is broken, replace it.
Jan 28, 2017 | Kenmore Refrigerators
Ice maker does not dispense ice through the door
Hello. I had the same problem. I replaced the auger motor(around$95) 3 times and would only last about a little longer than a year. I bought the 4th one but this time, I wanted to diagnose the issue. So it turns out that the auger motor goes installed with the impeller upwards. What was happening was that if a piece of ice would stay in the dispenser chamber and melt, the water would go into the auger motor eventually causing the auger casing to get full of water and slow it down or short it out. I took the casing apart and noticed that there was a small space between the motor and the casing. I drilled 2 nice sized holes in the dimple of the new motor very gently as to not drill into the impeller motor and installed the auger. To this day, 3 years later, no more having to buy new auger motors. Hope this helps!
Mar 10, 2015 | Refrigerators
UNIT making ice but will not dispense......makes terrible noise......
Sounds like the auger has broken. Look inside the ice maker if possible to see if the blade has detached from the auger bar. Here is a link to all the parts you may need to make the repair.
Jul 21, 2011 | Maytag MZD2766GES Side by Side...
+auger in ice maker broken Can replace auger only? part?
Hello, Thank You for using FixYa. I will be helping you today.I checked every where and the ice stripper is no longer available for that ice-maker. You would have to replace the whole ice-maker.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Broken ice dispenser
try and remove the ice bin.the watch the auger motor while the door is open and the switch help close while some one is tryind to dispence ice.if the auger turns the check and see if the u shaped braket is stripped you can tell this by grabbing it and turning back and forth it should only move one way.if it does not turn then the auger motor does need to be replace.make sure to check the wiring as well.if the motor turn check th is bin and make sure there is no ice jammed in the teeth of the auger this wolud stopp it from turning.i hope this was some help to you good luck. would like to here how things go for you.
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Broken auger on ice maker needs to be replaced. Can't get apart.
You will have to remove the E ring that attaches to the end of the auger before you can pry the pats apart.
Please rate solution
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice dispenser not working
Pull out auger & try With Out auger in place with door open and see if auger motor will spin with out auger and tray IN.. you with have to push door switch in to get auger to work .. with door open
Sep 12, 2007 | KitchenAid Architect ® Series II KSRX25FT
Hotpoint HSS25GFP Side by Side Refrigerator Logo
753 people viewed this question
Top Hotpoint Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
