Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
MASTER 29456 IS NOT GETTING ANY FUEL WHAT WOULD CAUSE THIS
2004 chevy cavalier wont start.
You must scan the system with a code reader.
Jul 17, 2013 | 2004 Chevrolet Cavalier
Front brakes stuck on (1994 toyota corolla) getting hot and smells terrible it is snowing and -30 at the moment could this be the cause
If your front brakes are froze on then the calipers are not releasing. Most common cause is a bad master cylinder. you may be able to bleed your brakes but most likely you will need to replace your master cylinder
Jan 24, 2011 | Toyota Corolla Cars & Trucks
115 000 BTU Diesel or kerosene// fuel psi 5.3/// model # 29456 /// amp 3.6 When I run the unit after aprox 10 min it shuts itself off and blows a big puff of smoke. Do you have any idea what the...
There should be some sort of fire eye on this, either a visually operated sensor of a thermocouple that is reading the temperature of the flame. If it senses no flame it will shut the unit off so you don't get poisened by fumes.Does it re-set when you try and start it again or do you have to push the reset button, either way it needs to be re-set before operating again. I suspect that this sensor is causing your problems. These units also have fuel pumps, this may also cause the problem, hard for me to tell without seeing the unit.
Nov 14, 2010 | Reddy R155D Utility Heater
Car does not want to start. Lights still come on, horn works, radio works. We installed a code master that still beeps when we use it but the car still doesn't want to start. Please help!
Check your owners manual or a repair manual and locate the Ignition Fuses Under the hood and in the passenger compartment), and others that might cause a starting issue. Coils packs, fuel injector, loose vacuum hose, etc. Could be anything.
Remember
F >> FUEL
A >> AIR
S >> SPARK
T >> TIMING
Keep it simple. Make sure your getting fuel, Spark What code were you getting? Have you had an alarm incident recently? Could be the alarm has locked you out even.
Hope this helps
Nov 04, 2010 | 2000 Saturn SL
Honda ex 650 genorator carburetor not getting any fuel, and wont stay running
check the fuel filter and the fuel shut off to see if they are clogged
Jun 22, 2010 | Master Heaters MASTER HONDA POWERED...
Motor rotates and has spark,but not getting fuel.starts w/starting fluid,gas tank is full but wont stay running.
it is either your injection systems master relay or the fuel pump, you better hope its just the relay cause the relay is a $30 and about 12 seconds to change, the fuel pump requires you to get the vehicle up in the air, drop the tank, remove the pump assembly, replace it and put it all back together, its about a 3 hour job if nothing goes wrong and a pump can run you up to $350 just for parts. to check the relay, simply remove it and take a ohmmeter to it to check for completed circuit, there should be a crude circuit diagram right on the relay itself.
Feb 25, 2010 | 2004 Ford E150
I have a 2001 Chevy cavalier that has been sitting about 7 months. I went to start and battery was dead so I went and bought a new battery and installed. The car cranks fine but will not start. I sprayed a...
The fuel is a likely cause of problems in this case. One possibility is a clogged fuel filter. If the tank wasn't completely full, it may be possible for condensation to form in the tank as a result of changes in temperature and weather, which can lead to water and rust in the tank. Fuel changes on long storage too, forming varnish which can prevent enough fuel getting to the engine. Long story short, the safe thing would be to have the car towed to a shop and have the fuel system checked out, because continued attempts to start the engine with dirty fuel can cause more problems.
Dec 03, 2009 | 2001 Chevrolet Cavalier
1977 f250 just quit running. It turns over but won''t fire. It sounds like it is not getting gas or fire. What could be the cause?
Module in the distributors are known to go bad. If you are getting fuel, this is the cause. If you are not getting fuel, check for plugged fuel filter or fuel pump inop.
Jun 26, 2009 | 1997 Ford F250 SuperCab
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
