Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Opening & closing by itself
We installed our 1/2 HP Craftsman Model 139.53985 back in April 2004.
In the past several months there have been a few occassions that the door has gone up and down on its own, but only up/down one or two times.
Overnight, we woke to hearing the door opening and closing over and over. I went out in the garage and looked at everything (didn't touch anything) and didn't see anything out of place. I stepped out when the door was up and looked at the outside remote keypad, then stepped back in the door.
At that time, it stopped going by itself and when I pushed the main control panel to close it, it stayed closed.
Seems this issue is getting worse, the manual troubleshooting page doesn't give much info for this but to remove the bell wire from the door controls and see if remote units work.
Does anyone know of any other situations that can cause this and how I may be able to fix it?
Thanks for your assistance!
Scott B
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Did you make sure the sensors are aligned properly? Sounds like they may be off just enough to be toggling between blocked and unblocked.
    You may also need to check and adjust the down lmit also. If it is set to come down too far it will go back up.
    Just a couple thoughts offhand.
  • 244 Answers
Above would not explain unit running in middle of night after door had been closed. I to would suggest taking off wire from motor (white and red). if problem stops, you have a short in wire or a bad pushbutton.
Posted on Jan 28, 2009
Craftsman Riding Mower (24 HP 42 in cut Model 289254) with throttle issue. Very slow in 6th gear
follow the throttle cable all the way down to the engine. Have some one move the throttle up and down to see if the throttle plate is opening and closing all the way. You can loosen the screw holding the throttle cable and move it back and forth to see if it will allow the throttle plate to open and close correctly. It may have slipped when the assembler tried to tighten it.
Mar 10, 2012 | Craftsman Garden
How do i link my phone to my car? i have tried and it gets stuck have to undo the battery do i fix this problem i want to use my phone on the system
We are talking about factory-installed Bluetooth, right? A 2004 model car would likely have had Bluetooth version 1 hardware/software installed at the factory. If it has not been updated ($$), I will be surprised if you can find any phone made in the past several years that will link to a 2004 model car. There were relatively few phones made in that standard.
Mar 09, 2011 | 2004 Acura TL
Craftsman 1/s HP 315 MHz garage door opener (Model 139-18470DM). The temperature here is currently 34 degrees celsius with the windchill. When trying to close the garage door from the main switch, the...
Check for some obstacle in the path of the light beam sensor that (should) be installed across the width of the door opening about 3-4 inches off the ground.
Jan 30, 2011 | Sears Craftsman LiftMaster Chamberlain...
My mom has a 1/2 hp chain opener that was installed in 2000 or so. It had recently begun overdriving both closing and opening (so button had to be pressed once to stop it). I tried adjusting the raise...
Remove the cover from the motor unit and you will see the limit switch assembly. If you watch the operation I think you will understand it and be able to adjust it properly.
Nov 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
CRFATSMAN opener - Problem when closing only
It sounds like you have a loose connection. Pull the logic board and check for bad connections especially around the small transformer.
Feb 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman remote won't close my garage door
If the remote opens and closes while inside the garage but not outside , there are a few things it could be. Assuming it was working fine before..
1. weak battery in remote.
2. remote itself could be bad. (unless you have more than 1 remote acting the same)
3. Logic board in opener is going bad causing limited range.Is the wire that hangs down from the opener straightened out? That is your remote antenna.Some people have coiled or even cut it off..reducing range.
4. Less likely but this can happen- interference from another electronic device, wireless routers, cell phone, new appliances etc.. can reduce remote range. Any new electronics recently purchased?
Jan 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
I just installed a sears craftsman 1/2 hp garage door opener. when i close the garage door with the remote the chain track bends up just about 12 inches before it closes all the way, and this only happens...
What is wrong is you need to adjust the limit on the door when it comes up. What it is doing is coming to far back on the track. You need to push the back limit forward away from the motor so the door does not come back and drop down on the inside of the garage. The opener is trying to push the door up hill to get it to close that is why you are getting the bend in the track.
Good Luck
Oct 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened by neighbor
Have you seen the neighbor open your door? The reason I ask is because it is almost impossible. The most common cause of a door opening by itself is a bad wall control or the wiring leading to it. You can temporarily eliminate both possibilities by removing the wire from terminal 1 at the rear of the motor unit. Do this and ask your neighbor to bring over his remote and try it on your opener.
Jun 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
25 yr+ old Sears opener runs past lower limit
Update: I remembered that I had a problem with the door reversing too much a while back. It was chattering in the tracks and I could not fix it with lubrication and changing spring tension. So I dialed up the down reversing force. This contributed to the jam-up I had when the lower limit was ignored. If I had a lighter force, it may have at least reversed.
After futzing with it I left it alone for several hours. The motor would hum every few minutes. I was considering cutting power to it overnight. I pressed the remote one more time and the motor ran normally to a limit and stopped. I tested it a few times then reconnected the chain and door. Seems fine now. I suspect an intermitten logic board problem. I'll try lightening up the down force and using it for a while.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
193 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Are you a Sears Building Material Expert? Answer questions, earn points and help others
