Question about Lasko Ceramic Heater
Is there a fuse in a lasko ceramic space heater
I have a lasko model 5848 ceramic space heater that stopped working. I have cleaned it and also unplugged for 30 minutes and tried again in order to reset it to no avail. Is there a fuse inside that can be replaced?
3 Suggested Answers
  • 8 Answers
SOURCE: lasko heater run about 5 minutes and shut down/how to clean
i have the same problem ... i almost throw this heater out ,,
the fix .. open the unit theres 6 screw at the back.. remove it if you have problem removing the triangle screw use the small square head screw ...size 0 and then you also need to open the black plastic ..
i believe it has 8 screws .. then vaccuum all the dust .. chances are the front and the back of the heating element is covered with dust ..
after that put all back together and i guaranteed it should work like brand new ,,,, dont worry its not that hard ... the only hard thing for me was removing the 2 triangle screws at the back .. Goodluck
Posted on Feb 23, 2009
SOURCE: Lasko heater beeps too LOUD
I was cleaning out my Lasko ceramic heater 6000, looking for instructions on how to do so, and came across your comment. After I opened it up and cleaned everything out (really easy, no instructions needed, it is all obvious) I started thinking about how much I hate that beep as well. So I decided as long as I had it opened to try to disable it.
Well, I could tell from plugging and unplugging that it was (unfortunately) mounted on the under side of the green circuit board. You will have to unscrew the circuit board completely (all wires still attached) and (carefully!) move it so you can flip it upside down to get to the other side. Note: there were 7 screws to remove and 1 was under the motor and really hard to get to. The motor looked WAY too complicated to remove so I got the screw started just a little with a precision screw driver and turned it the rest of the way with needle nose pliers.
Once the circuit board is off, the beeper is a little black circular thing (about 1/2 inch in diameter) with a little hole in the middle. It has a serial number on it and a "+" symbol. It looks like it is built in two pieces (upper and lower), so I tried to carefully remove the upper piece with needle nose pliers while leaving the lower piece connected to the circuit board. Well, the whole thing ripped out! I thought two things: 1) It will never beep again, and 2) I hope this didn't break a circuit causing the whole thing to fail.
Well, I put the circuit board back on ( I left off the one difficult screw, as 6 of 7 is more than sufficient to hold it on). Put the whole unit back together, and . . . . IT WORKS FINE!!!!!
Posted on Dec 10, 2010
I have a Lasko model 5420 compact ceramic heater and would like to clean the interior . There are 4 screws that attach the back, 3 are philips head but the fourth is a head design I don't recogniz
Requires a special security screwdriver. I modified a slim old screwdriver by filing a small V in the middle of the blade. You can also buy 1/4" driver bits at Harbor Freight, etc.
Jan 07, 2012 | Lasko Heating & Cooling
I lost my owners manual & would like to know how to turn & operate my lasko ceramic heater. Thank you in advance. Roy Reyes
Follow this link:
http://www.laskoproducts.com/heaters/heaters.html
and put in your model of heater. Once on your models page, the link to the manual is near the bottom of the page, a red link.
Mar 15, 2011 | Lasko Ceramic Heater
Whenn I turn my Lasko htr model # 5132 on it beeps twice n acts like there is no power. what can I do?
unplug the heater. clean the vents in the back using a vacuum cleaner hose attachment. wait 15 minute and plug the heater back in. This has worked for me.
Feb 14, 2010 | Lasko 5132 Ceramic Compact Heater
Cleaning filter
They are called security screwdrivers
or tamper resistant but you should find them here
http://www.amazon.com/Anytime-Tools-Security-Screwdriver-Reversible/dp/B000F7DWMQ
Jan 12, 2010 | Lasko 5530 Ceramic Compact Heater
Won't turn on. It gave me a beep when I plugged
Have you cleaned the filter that's on the back? This has happened to me, and I just took the filter out and cleaned it, and it worked fine after.
Dec 27, 2009 | Lasko 5130 Ceramic Compact Heater
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Dont know what buttons mean
hai sir the button which you are confused in is used only for reseting the equipment.please find your equipment seller for a copy of users manual.
Jan 29, 2009 | Lasko 5365 Ceramic Compact Heater
How to clean filter on Lasko tower ceramic heater
Thanks for the response = I blew the filter clean with a forced air canister.
Nov 29, 2008 | Lasko 5540 Ceramic Compact Heater
Lasko  Ceramic Heater Logo
71 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Steve Oakes
Mack Baxter
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
