Question about Philips 20PT643R 20" TV
Picture Tube Failing
I've scoured the internet and have finally settled on submitting my issues in hopes of understanding my problem and maybe finding a solution. I own the below mentioned TV had have for at least 2-3 years, manufacture date on back is August 2004.
About 6 months ago I started to notice discoloration on the right side of the screen running vertically (red). Eventually on the Left side as well (green). I know this is a picture tube issue. Very small fridge magnets seem to help fix the picture slightly (and temporarily) when ran across the effected area. The set has never been dropped or otherwise mishandled. I don't believe any items near it would generate any kind of interference either.
I have continued to watch DVDs and play games on it with some mild visual discomfort. I just dealt with the issue until now. Occasionally the visual flickers slightly and seems to be adjusting itself, as if it was degaussing but then goes back to the discolored visual.
I guess I'm curious what could have caused this and if there is really anything that could be done to try and troubleshoot this issue before giving up on this set.
Thanks!
    Genius:
  • 1,175 Answers
HI...
I t sound like the De-gauss circuit has failed.
De-gauss demagnetizes the TV tube so you dont get what youre seeing.
It could be something as simple as a solder joint on one of the parts in that circuit. I fixed my Panasonic that way
Posted on Jan 27, 2009
Tv cannot connect to the internet
Hello .I understand this situation very much so , I had the same issue.. You must call your Internet provider you are with to walk you step by step through the process on how to connect your tv to the Internet .Sometimes it get's tricky . Ask for tech support. It worked for me . Hope this helps .:)
Oct 16, 2016 | Computers & Internet
The control panel display is so light that it can not be read. I have a double built in oven SCD302. What can be done?
Hello, welcome to FixYa.
There are two common scenarios with these Thermador wall ovens fitting what you've described. The harness to the display from the control board is loose (not likely) or the display itself is failing (most likely).
The issue with these displays is they lose their intensity over time because of the fluorescent tube technology they use, hence the only remedy is to replace the control/display kit...the display only is not available, but a "kit" is.
You can find these "display kits" at "repairclinic.com" and similar to what I've attached here...
**Your other option, and the one I recommend, is to have the existing display and control rebuilt...the down side is this will require the parts to be removed and sent away**
You may find other suggestions or "band aid" remedies on-line, but in my experience this is the sure way to go. Here you'll find all the info pertaining to this option by clicking on the link I've provided below
http://www.corecentricsolutions.com/CCSWeb.nsf/published/bosch
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Oct 14, 2011 | Thermador SC302T Electric Double Oven
It seems like im having some issue with my syncmaster2493 monitor. it will black out and once i wiggle the power cord it will come back on. any help will be apprecaited
Your power supply board is failing and when you wiggle the cord it is turning it on and off until it finally starts up. There are parts called capacitors that start failing and it will cause intermittent power issues such as slow to show picture, flashing power button, wavy or flashing picture. The board can be repaired and the monitor will be as good as new. Here is a picture of the power supply with the parts circled that need to be replaced.
There is a step by step repair guide for the Samsung 2493HM unit here:
http://www.ccl-la.com/blog/index.php/reparing-a-samsung-2493hm-24-lcd-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Jul 30, 2011 | Samsung SyncMaster 2493HM Monitor
Our tv has been getting darker and darker - we've tried to adjust brightness in menu and have it set to far right but its still too dark. Is there another adjustment to brighten the picture other than...
In many many cases this is an indication of a failing picture tube. The gun assembly in the neck of the picture tube is shorting. There is a fix, but this is surely last resort and the final cure may not provide a fix. Picture tube rejuvenation is not always successful. I would certainly opt for a new TV. Thanks for asking, and show a few hands of support!
Mar 13, 2011 | JVC AV-27530 27" TV
Picture tube failing?
NO thats not the picture ,that is more from the vertical circuit some capacitor defect or the ic it self
hope thet will help you
regards Alan
Jun 07, 2010 | iLO 2600 Television
My tv has sound but no picture
hello Your set, with a dark screen or no picture but with sound is failing in the high voltage to the picture tube. It is caused by a failure in the horizontal deflection circuits which generate the high voltage (20,000 volts). The repair is expensive; at least $100 or more, most likely, depending on exactly what components have failed.
Regards Gizokieth
Sep 11, 2009 | LG 42LC2D 42 in. LCD HDTV
1995 chevy monte carlo
Hi anthony,
I'm not quite understanding what the issue is. Is it this just bugs you or do you want to know if the fuel level sensor might be failing. Unless its causing engine malfunction or fuel pump problems I personally wouldn't worry too much over it. I would bet that fuel level sensor is failing, this sensor is part of the fuel pump assembly. With a car this old fuel pump issues are quite common.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Oct 18, 2008 | 1995 Chevrolet Monte Carlo
RCA D52W20 - turns on and off, blue screen, tech said need picture tube
It very well could be the Blue CRT shorting out. However the not shutting off is not a symptom of the tube being shorted that sounds more like a signal board issue rather than a picture tube, as the signal board can cause all the symptoms you have described.
Aug 26, 2008 | Televison & Video
Tv Flashes
key2life316,
Your TV has a bad picture tube = no reasonable repair possible......time to go shopping!....................T.
Guest,
Your TV has a bad pix tube + a blown power supply!!
Time to move on ........T.
Aug 25, 2007 | Sony KV-35S42 35" TV
RCA Model # 20F510TD TV/DVD
What makes you think the picture tube is bad? What exactly are the symptoms you see? The RCA 20 inch picture tube is a good quality long lasting tube and I doubt I have ever seen a bad one.
Jul 03, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
Philips 20PT643R 20" TV Logo
133 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
