Question about Brother International Brother HL 5470DW
Pause button and printer won't print - Brother International Brother HL 5470DW
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
Your problem is not clear
Posted on Sep 09, 2016
Printer is paused all the time
Hello, sounds like your drivers are messed up, reload them to the computer or the connection cable maybe bad. If neither of these fix then the printer is bad.
Sep 05, 2012 | Canon PIXMA MX870 Wireless Office...
My printer status says it is on pause and it won't print. How do I get it off of pause?
I'm assuming that you're using a Mac. Try to uninstall the Lexmark driver first then download an updated driver online: http://bit.ly/McHL54
If it doesn't work, try to reset the printing system:
  1. Open System Preferences and click "Print & Fax". Then click or right-click on the blank space around the list of printers on the left-hand side.
You should see a pop-up menu and the option to "Reset printing system...". Once you select the option, the OS will restore the CUPS printing system back to its original default settings. NOTE: This will, of course, erase all of your print queues.
Then add a print queue manually: http://bit.ly/SxD5Za
Aug 08, 2012 | Lexmark 90T9105 - Pro 901 All-in-1
In epson lq1150 /II esc/P2 how to clear data in memory. Already removed alldata in print Que .Restarted System as well as printer.
Actually, what you're doing already clean up the data in memory.
If the memory still contain data, maybe there's something wrong with the printer.
Run a self test print whether the printer is okay or not,
Turn on the printer while holding down the LF/FF button or Load/Eject button. If it start print, that mean the printer okay. Press 'Pause' and turn OFF the printer and then turn On back to stop the self test printing.
Jul 04, 2012 | Epson Office Equipment & Supplies
Only prints first job - can't delete from que
Please try this approach instead:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
I hope this information has been helpful.
Dec 20, 2011 | Lexmark X6170 All-In-One InkJet Printer
My Dell Photo A10 Printer is stuck on 'PAUSE' and I can"t get it off . Please help.
There is no A10 printer , the AIO stands for All-In-One. So i'll assume you have the 924 model.
First make sure the printer itself is functional: shut it down, disconnect it from the pc, start it and use it to scan and copy a file - just press the Start button.
If it doesn't work then the printer is effectively dead - the damage is in the procesor and to replace iot would cost more than a new printer.
If it works then there is something wrong in the setting from the pc. In that case the first thing you should check in Start ? Control Panel ? Printers and Other Hardware ? Printers and Faxes ? Double-click Dell Photo AIO Printer 924, and then click Printer ; in there make sure a check mark is not next to Pause Printing. If a check mark is next to Pause Printing, click Pause Printing to clear it. If it's not then the driver and the associated utility have been corrupted: uninstall it from Add/Remove Programs, reboot , manually wipe all the remaining Dell folders reboot one more time and reinstall them.
Aug 08, 2011 | Dell 924 All-in-One InkJet Printer
Zebra 2844 Printer was fine...unplugged USB then plugged into a different port on the same computer now it won't print. Says error in the printing status. It is not offline or paused.
This is due to windows which has attributed a new virtual usbport.
Go to the printer port and try another one (the last one for example)
Jul 31, 2011 | Zebra LP 2844 Thermal Printer
My canon printer won't print. It was okay yesterday, but now it's not working right. I changed the ink but it's still not printing. What should I do?
Hi Ruby
Can you please elaborate the problem and the model of your canon printer. Normally the problem will be with the cable or the driver. try the following just in case.
1. Check the printer settings in PRINTERS & FAXES
2. Open the printer icon in it and check if the printer has a ticked mark for pause printing.
3. Change the cable and try to print.
If the above does not solve the problem then there has to be a problem with the Formatter board Assy. which is the board present in printer where you connect the USB cable.
Jul 14, 2011 | Office Equipment & Supplies
Won't print...says printer is on pause
According to your problem, first check the printer settings. Go to the Printer and faxes wizard in control panel. Right click on printer, if you fond there Resume printing then click on it. It will make printer working. Then reboot the printer and the system both. If it doesn't help you then there is the problem of printer software. Reinstall printer driver/ software again and reboot the both.
Jun 21, 2011 | HP Officejet 6500 Wireless All-in-One...
Keeps pausing job won't print. also won't scan... "can't load application" scans only to flashdrive.
Your firewall could be blocking some printer communications. Make sure to allow full access to all Lexmark and printer communications in the program rules/permissions for your firewall. For more information on how to configure the settings for your firewall, visit the Lexmark website at http://bit.ly/iNwkNs.
May 14, 2011 | Lexmark X4650 InkJet Printer
Pausing printer
Try enlarging your "Printer Buffer" if you can.. OR maybe you need to set your Parallel Port to a differsnt mode in the BIOS. And/Or try updating your "Drivers" see if this all helps.
Jun 18, 2007 | Epson LQ-570e Matrix Printer
Brother International Brother HL 5470DW Logo
66 people viewed this question
Top Brother International Office Equipment & Supplies Experts
Gil Shultz
Ron Baird
 Andrew Henderson
Andrew Henderson
Are you a Brother International Office Equipment and Supply Expert? Answer questions, earn points and help others
