Question about Garmin Forerunner 305 GPS Receiver
How to change battery for Garmin forerunner305
My unit alway running low batt and I suppose need battery replacement. Anyone can help to let me know how to order battery and how to install it?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 84 Answers
It;s not easy. here is a link to show you how to take it apart.... A local battery shop should be able to get you a replacment but it needs to be soldiered in....
http://ctorunner.googlepages.com/dismantleforerunner205
Posted on Nov 13, 2009
Gsc will not pair with forerunner305
have u did asoftware check to see if that needs to be updated. If not u can do a reset or send it in for repair...you need to try the others first
May 12, 2010 | Garmin Speed/Cadence sensor - GSC 10
Chronotherm III...Replace Battery notification blinking...replaced twice with the appropriate batteries, turned the correct way. Cleaned off the battery terminals and still have replace battery...
Thermostat problem; Honeywell chronotherm lll ' Low Batt. indicator Keeps blinking after Batteries replace. I chk'd batt. with elect. volt ntr. Was told to pull batt. and change ends with them , letthem stay reversed for 5-10 sec. then put them back in right order,and replace thermostat. No success!
Anyone have any answers
Nov 12, 2009 | Honeywell Power Humidifier: Furnace...
My Garmin 276c indicates "Battery Missing" even with a new Batt.
Check the battery contact points inside the unit. There may be a thin film of crud (oxidation) that prevents contact, especially if the previous battery had any signs of corrosion.
Jul 02, 2009 | Garmin StreetPilot c550 GPS Receiver
My Garmin forerunner 305 recently got immersed in
I have read in some other posts about the unit only working while being plugged into a USB port. My guess is that the battery is in fact shot and the unit will only run off the USB port while plugged in. Submersing in water is not a good idea. On the back of the unit there are some small holes for the speaker. These speakers corrode from sweat and eventually quit.
Jun 05, 2009 | Garmin Forerunner 305 GPS Receiver
IPaq rx3115 working like PC not Pocket PC, need to plugin always
You need to purchase a new removable battery for your RX
The removable batts usually only last about a year (like cell phone batteries).
Although it is showing 100% charge, the battery is not storing enough power to run the ipaq
The rx series uses 2 batteries, one is the removable one u can see/access when u remove the back cover. The other batt is a small round batt which stores the basic info for your system (so you don't lose your data when u swap out the removable battery).
This small (backup) batt is similar to the cmos battery on a laptop or pc.
You cannot easily replace this, as the unit needs to be disassembled to access this batt.
If you are tech-y (and brave), the replacement button batteries are sold on ebay for $9-12
Normally, if your removable batt is bad, you could still use your unit plugged in, and could
remove from AC power without losing data. Not the case if your replaceable batt is exhausted.
When both batteries are bad, you lose everything when u remove unit from AC power.
My workaround without having to disassemble unit:
Purchase and fully charge new removable batt (They have huge capacity ones available for like $15 - better than the original !).
Load up all your programs & settings the way you like.
Perform full backup to SD card (& also on PC via active sync - to be safe)
Now the only time you should lose your data (like hard reset) is if you allow the battery
to completely drain, in which case you can restore your backup.
If you purchase 2 removable batts, you can easily swapout without losing data if you
use the usb charge cable & leave ipaq plugged in while you change battery
Hope this helps
Jun 01, 2009 | HP iPAQ RX3115 Pocket PC
Screen goes blank after locating sattilites.
Accordingto Garmin, this problem can be fixed by disabling the WAAS feature in teh set up menu. There is an incompatibility between the old Garmin software and latest WAAS upgrades. Later software from Garmin is supposed to fix this problem.
May 21, 2009 | Garmin eTrex Legend GPS Receiver
When checking battery - garmin freezes when using "exit" button
I would go to the garmin site and update the firmware. The 850's had a loop problem in the software recently so it is worth a try.
Jan 02, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Second hand moves every 4 seconds
the battery need replacing this is what its supposed to do when batt low. if this helps please rate joe
Nov 20, 2008 | Watches
Unit fails to maintain charge
You are correct, most GPS units use a lithium ion rechargable battery, typically they loose there ability to retain a charge after about a year or so depending on use, resulting in the unit having to be always plugged in.
You probably could replace the battery on your own if you could get one, (needs to be soldered into the mainboard) however GARMIN does not sell battery's to consumers, they state that a battery can only be replaced by a garmin service tech.
Check the link below for contact info for garmin.
https://buy.garmin.com/shop/shop.do?pID=290&tab=sp340
Hope this helps
http://pchelpforanyone.blogspot.com
Mar 07, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
764 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
