Question about GRACO INC FinishPro HVLP 9.5 Paint Sprayer
9.5 graco leaking at needle
My spraying is leaking at the needle area. Sometimes it also leaks from the cup. Manual says leaking from needle not being inserted correctly but it is. Could this maybe be from the seal needing replacement on the gun where it attaches to the cup...HELP!!
Trying to prime my 395 air assisted finish pro and I have fluid coming out of air holes in gun
I had the same problem. turned out I was using the rubber gasket on the tip saddle instead of the hard plastic one.
Aug 30, 2013 | GRACO INC FinishPro 395 Air-Assisted...
Water is leaking out of the bottom of my philli[s GC 9240
see the next steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Nov 14, 2012 | Irons
Why does water leak back into my resevoir when i brew a cup of coffee and i only get half cups?
If you are experiencing inconsistent brews, there may be some coffee grounds lodged in the needles that pierce the K-Cup packs. This video will show you how to SAFELY clean this area of the brewer
Aug 28, 2012 | Keurig B60 Coffee Maker
2002 sportster wont spray gas to the carb sometimes
Hi Anonymous, if you have a carburator the usual suspects are:
1. Damaged or restricted fuel tank venting system (gas cap).
2. Inlet system air leak.
3. Vacuum piston malfunction.
4. Accelerator pump leaking or no output.
5. Plugged bowl vent.
6. Fuel level (float chamber) too low.
7. Restriccted fuel supply passages.
8. Plugged jets or passages.
9. Worn or damaged needle or needle jet.
10. Enrichner valve not seated or leaking.
Good luck
Apr 02, 2012 | 2002 Harley Davidson XL 1200 C Sportster...
Rough idling, high pitch whistling sound
Sounds like a vacuum leak. Best way to locate is with a spray bottle and some water. Spray in the area where the known noise is. You will have located your leak when the water sounds like someone drinking soda from the bottom of an empty cup with a straw. Good luck.
Aug 20, 2011 | 1996 Ford Taurus
Keurig leaks when I use filter and sprays around cup
One cause would be the filter is filled to tightly with your coffee. Try using a looser load. Your upper spay needle head may also have debris in it. Lift your handle all the way up and look up under the to see the spray needle. Using a paper clip, clean each of the three openings out in the spray head.
Nov 26, 2010 | Keurig B70 Coffee Maker
KEURIG SENT US A NEW GASKET AROUND THE NEEDLE AREA & IT STILL LEAKS WATER ALL OVER THE PLACE WHEN YOU PUT DOWN THE LID TO BREW A CUPWHAT CAN THE PROBLEM BE?
Your not putting the k-cup in a Keurig my K-cup are you? Because there must be a needle in the bottom of the k-cup holder inorder for this to work properly.
Mar 28, 2010 | Keurig Elite B40 Coffee Maker
Vaccum leak load whisling noise cant locate
Take WD-40 and spray it around the engine, when the engine idle comes up, the vacuum leak is in the area you where just spraying. From there you'll need to investigate more closely by hand around that part of the engine.
Jan 05, 2010 | 2004 Jeep Grand Cherokee
Water coming in and pooling in the drivers side floorboard
Does it have a sunroof? if it does, check drain hose; poor a cup of water into the area around the drain holes & check for drainage under the car onto the ground. Has it recently had a glass replacement? Get another person to spray the outside of the car methodically from bottom to top slowly while you check for leaks inside the car. Or, turn air on w/all glasses closed, spray soapy water onto suspect areas, leaks will create more bubbles.
Sep 17, 2009 | 1997 Honda Accord
GRACO INC FinishPro HVLP 9.5 Paint Sprayer Logo
Top GRACO INC Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a GRACO INC Air Tool and Compressor Expert? Answer questions, earn points and help others
