Question about Coralife 08608 Lunar Aqualight CF Fixture
The fluorescent light flashes when u turn it on
On a 4 2x2 fluorescent. The inverter shots up wen turning them on and a alarm and red light come on.
Using portable power for a fluorescent light - Photo.net Lighting ...
photo.net > ... > Lighting Equipment and Techniques > Fluorescent lights
Jun 13, 2009 - 8 posts - ‎4 authors
so from a 12 volt battery, the inverter will take something like 20 to ... tube is ignited, it has a quite high current consumption (except when ... I considered the initial start up for fluorescent lamps and I'd certainly power this light up slowly! ... devices, and are insanely sensitive to the waveform powering them.
How To Shoot With Fluorescent Tube Lighting - Envato ...
photography.tutsplus.com/.../how-to-shoot-with-fluorescent-tube-lightin...
Sep 23, 2010 - I just mean, you should plug your lights in and let them run for several... For this shot, I simply set up the weight on a neutral-colored platform with a ... The long shape of the fluorescent tube when lighting a long curved ... Turn Captions On ...tungsten that you can get an inverter and power these off batteries.
Dec 28, 2015 | Inverter Electronics - Others
How do you find the white balance on this camera?
This camera does not have a customizable white balance. It does have some presets -- they are:
  • Auto (default)-automatically corrects white
balance. Ideal for general picture taking.
  • Daylight-for pictures in natural lighting.
  • Tungsten-corrects the orange cast of household
light bulbs. Ideal for indoor pictures under tungsten or
halogen lighting without flash.
  • Fluorescent-corrects the green cast of fluorescent
lighting. Ideal for indoor pictures under fluorescent
To access them, press the [Menu] button and look for White Balance -- the icon is a Sun and Light Bulb symbol.
Oct 28, 2013 | Kodak EasyShare Z760 Digital Camera
When i take a picture with the flash, it has a yellow tint to it. Why?
Most likely your white balance setting needs to be adjusted. You didn't specify the model of your camera, so I can't tell you exactly how to change it (your manual should say).
Your camera should have several settings:
"A" or "Auto"
"Daylight/Sun"
"Tungsten" or "Indoors" or "Incandescent"
"Fluorescent"
and possibly also:
"Flash"
"Cloudy" or "Shade"
When taking flash pictures, the "Flash" setting should be best. If you don't have a flash setting, then "Daylight" or "Sun" will be the best.
Human eyes adjust quickly and easily to different colors of light, but cameras see light as it is, so indoor light will look yellow, outside bluish, fluorescent greenish, etc. So digital cameras shift the colors in the image to try to make white objects appear white like they would to your eye. But sometimes they mess up and don't get it quite right. That is where the manual white balance settings come in. If you play with these settings, then you will find you can improve the color quality of many of your pictures.
Dec 03, 2010 | Cameras
How to FIX
Televisions have protection circuits which prevent full power-on if a fault is detected in a high voltage/high current circuit such as the backlight inverter.
Some googling on 'Sony Blink Codes' found that 4 blinks is 'backlight failure'. A common failure in LCD displays is the backlight inverter board which is a transformer similar in function to a fluorescent light ballast, as the backlights are fluorescent lamps.
If the screen color is getting pinkish/reddish, that's a sign that one or more of the lamps themselves are going bad.
Since multiple lamps are connected to (typically) two inverter boards (a primary and secondary board), I am fairly certain that the blink code refers to a failed inverter board and not a failed lamp.
Oct 19, 2009 | Televison & Video
Blank screen
You said it correct the fluorescent bulbs are going bad, unfourtunately the are part of the screen (panel).
to replace the panel make sure you get the exact part # from the panel inside rear and check prices online and on ebay.
Aug 03, 2009 | Princeton Digital VL2018W Monitor
ViewSonic LCD Monitor Went Blank
It is probably a bad INVERTER and / or backlight fluorescent bulb.
Jul 02, 2009 | ViewSonic Computers & Internet
Acer AL 1715 monitor flashes 2x and dies
LCD panels use cold-cathode fluorescent bulbs to make the light necessary for them to show images. What you're describing is something I've seen in panels where the bulbs were dying or dead. it's also possible that the controller for the bulbs is also on the fritz.
Jan 08, 2009 | Acer AL1715 17" LCD Monitor
Hampton Bay 54" Covington Ceiling Fan light problem
Solids state fan controls don't work correctly with fluorescent bulbs. If you check the tail end of you remote's instructions it will say something like "Max light watts: 300 (incandescent only). So replace your energy saver bulbs with 60 watt "regular" bulbs to solve your problem.
Aug 22, 2008 | Heating & Cooling
What are the white balance modes available with the camera?
The following White balance settings are available for the A2: AUTO, Preset (Daylight, Tungsten, Fluorescent, Shade, Cloudy, Flash and Custom1 to 3) The following slight adjustment is possible: * At setting Daylight, Tungsten, Shade, Cloudy and Flash: +3 to -3 (one unit is approximately equal to a 10 mired shift.) *At fluorescent lamp setting: equivalent to 7 fluorescent lamp(3 -wavelength colored fluorescent bulb, 3-wavelength white fluorescent lamp, 3-wavelength neutral white fluorescent lamp, 3-wavelength daylight fluorescent lamp, white fluorescent, neutral white fluorescent, daylight fluorescent lamp)
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
The following White balance settings are available for the A1: AUTO, Preset (Daylight, Tungsten, Fluorescent, Shade, Cloudy, Flash and Custom1 to 3) The following slight adjustment is possible: * At setting Daylight, Tungsten, Shade, Cloudy and Flash: +3 to -3 (one unit is approximately equal to a 10 mired shift.) *At fluorescent lamp setting: equivalent to 7 fluorescent lamp(3 -wavelength colored fluorescent bulb, 3 wavelength white fluorescent lamp, 3 -wavelength neutral white fluorescent lamp, 3-wavelength daylight fluorescent lamp, white fluorescent, neutral white fluorescent, daylight fluorescent lamp)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Coralife 08608 Lunar Aqualight CF Fixture Logo
62 people viewed this question
Top Coralife Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Are you a Coralife Fish Expert? Answer questions, earn points and help others
