Pot filler leaking NF-POTF-ORB
Need parts, rubber gaskits
5 Suggested Answers
  • 49 Answers
SOURCE: I need o-rings for 529 fontaine NF-KPDS-ORB Kitchen faucet
try plumbing parts plus .
Posted on Mar 18, 2009
  • 7 Answers
SOURCE: fuel leak
This part is a vent solenoid to the EVAP system. The solenoid is controlled by the PCM & vents fuel vapors to the charcoal canister. If fuel is leaking here you should first make sure your vent in the gas cap is not clogged.This could cause a vacuum in tank & possibly lead to your problem, or the solenoid may have been damaged when the tank was removed & replaced.
Posted on Jun 27, 2009
bschilz
  • 2049 Answers
SOURCE: leaky filler tube 1992 Accord LX need replacement
The filler neck is much more than the rubber boot you speak of. Here's a link to one place it can be purchased on line. You can do a Google search for other sources.
http://www.ecrater.com/product.php?pid=3619135
Posted on Sep 22, 2009
  • 4977 Answers
SOURCE: if the fuel filler neck dosent seem to be damage or have loose connections,but if you touch the rubber part of it an ash kind of black substance is left on your hands.could it be leaking through this
its possible that your filler neck is porous and is the problem(rare). while filling have you looked under to see where the leak is coming from. the ash substance happens on a lot of rubber parts as the environment begins to break down the rubber.
Posted on Sep 25, 2014
Top of radiator... the 15mm rubber hose that connects to the 7mm metal tube is leaking. Do I need to buy a whole new radiator or can I just buy a part..
just the rubber hose
I take it that you are referring to the hose and connection under the radiator cap filler neck back to the reservoir bottle
Jul 10, 2017 | Cars & Trucks
If the fuel filler neck dosent seem to be damage or have loose connections,but if you touch the rubber part of it an ash kind of black substance is left on your hands.could it be leaking through this
Sep 25, 2014 | 2003 Ford E150
Fuel filler neck
Hi I'm Peter, Not sure what your problem is from just posting fuel filler neck however I am assuming you have a strong gas smell. The rubber hose that connects the filler pipe on the tank to the fuel spout may be cracked and leaking. Another common problem is the tank vent tube that runs from the tank up along side the filler tube may be rubbing on the metal part of the tube and has a hole in it. This will give you the strong fume smell and possible fuel leak as will the rubber filler tube when the tank is full. These vehicles are known for this problem and also the metal filler pipe rusting causing a pin ole. Look to see if you can see rust anywhere . Even if you don't see rust on the outside does not mean there is not rust on the inside. I have seen where a lot of people have been have the rust issue also to the point they carry the part at auto parts stores . Hope this is what you needed.
Apr 16, 2014 | 1997 Nissan Maxima
Oil filter housing leak how to replace gaskit on a 2007 chevy impala
Filter screwed on too tight,causing rubber gasket to bind and leak,loosen up.
Jan 20, 2013 | Cars & Trucks
TEMP IS HOT
Check discoliration of oil and if present then blown head gaskit.
Thermostat ncould be stuck.
Blocked Radiator
Look for wet spots if car parked over night..could be leaking hose.
To check water pump remove thermostat ,seal and put thermostat cover back on and run engine with filler cap open.(make sure you fill water before running it)Water should circulat in the radiator,if not then faulty water pump
Sep 12, 2011 | 1993 Ford Tempo
Codigo p1440
EVAP System Vent Circuit Malfunction
This diagnosis detects leaks in the Evaporative Emission (EVAP) purge line using of vapor pressure in the fuel tank. The EVAP canister vent control valve is closed to shut the EVAP purge line. The vacuum cut valve bypass valve will then be opened to clear the line between the fuel tank and the EVAP canister purge volume control solenoid valve. The EVAP control system pressure sensor can now monitor the pressure inside the fuel tank. If pressure increases, the Engine Control Module (ECM) will check for leaks in the line between the vacuum cut valve and EVAP canister purge volume control solenoid valve.
Possible causes
- Incorrect fuel tank vacuum relief valve
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- Leak is in line between intake manifold and EVAP canister purge volume control solenoid valve
- Foreign matter caught in EVAP canister vent control valve
- EVAP canister or fuel tank leaks
- EVAP purge line (pipe and rubber tube) leaks
- EVAP purge line rubber tube bent
- Blocked or bent rubber tube to EVAP control system pressure sensor
- Loose or disconnected rubber tube
- EVAP canister vent control valve and the circuit
- O-ring of EVAP canister vent control valve is missing or damaged
- EVAP canister is saturated with water
- EVAP control system pressure sensor
- Absolute pressure sensor
Possible solution
- Loose fuel filler cap
- Leaking fuel filler cap
Hope helps (remember to rate this answer).
Jan 05, 2011 | 2000 Hyundai Sonata
I am planning to take the cylinder covers off a harley 1200 and replace with new gaskits. is there anything i need to know other than taking off the 4 head cover bolts and removing and replacing after...
No, that's just about it. Replace the breather valves in the rocker boxes while you have them off. They're just rubber parts very similar to the valve covers. They vary depending on year model. Torque the four 1/4" bolts to 100 inch pounds. Do not loosen or tighten the head bolts.
Good Luck
steve
Sep 12, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
Fuel leaks from filler pipe to gas tank
You don't need to replace the gas tank, the filler pipe is connected to a rubber hose which connects to the tank with clamps at each end.
Mar 08, 2010 | 1995 Toyota Camry
Gas leak on fuel filler neck, how can I fix this?
if it's a hose or pipe go to dealer or junk yard get another if broken clamp replace if neck part of tank call rad shop see if the can solder if you drain & pull tank
Aug 30, 2009 | 1995 Buick Regal
Washing Machines Logo
Top Washing Machines Experts
