Question about Craftsman 29cc Wheeled Edger w/ Speed Start
How to change the belt on my edger - Craftsman 29cc Wheeled Edger w/ Speed Start
How to chage timing belt
there is none on a trimmer or edger
Jun 27, 2015 | Garden
The edger runs when switched on but then shuts off when I start to sand with it. The brushes and switch have been changed on it.
check the belt and the pinion..had same problem...replaced the belt and the pinion drive, works fine
Dec 15, 2013 | Bona Edge XL Flooring Edger Sander
Blade is turning wrong way
The blade drive belt on your MTD edger makes a half twist in its pattern. When the belt was installed, it was twisted the wrong direction. Remove the belt from the blade pulley and reinstall with it twisted the other direction. Before you start the edger again, visually inspect the belt and make sure it is not touching anything other than the pulleys.
Dec 21, 2010 | Yard Machines Red Edger
How to install a yardman edger belt
i changed the belt on mine today. The belt will loop over the back left pulley then inside the middle pulley with the back of the belt towards the bottom pulley and the v shape in the top of the pulley you then pull the belt over the front pulley( next to the blade) with a screwdriver and thats it.
Aug 25, 2010 | Yard Machines Red Edger
Drive belt broken is it worth replacing it? Other parts OK
the cost of the replacement belt is cheaper than a new trimmer so has to be worth changing
Jul 06, 2010 | Black & Decker 14" Grass Hog Xp...
How do I change the belt?
I do not have a diagram but i changed the belt on mine today. The belt will loop over the back left pulley then inside the middle pulley with the back of the belt towards the bottom pulley and the v shape in the top of the pulley you then pull the belt over the front pulley( next to the blade) with a screwdriver and thats it.
Jun 22, 2010 | Yard Machines Red Edger
GH1000 Motor runs but spool just quit working.this is electric.
Same thing happened to me. The belt broke. You'll need to take off all the screws to change the belt. There's a hidden screw under the black label. Feel around for the soft spot.
May 21, 2010 | Black & Decker 14" Grass Hog Xp...
How to change an old edger blade
Take a pair of vise grips and clamp the blade to a 2X4 for more leverage. Some old edgers had a left hand thread.
Apr 09, 2009 | Garden
Craftsman 29cc Wheeled Edger w/ Speed Start Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
