Question about Acer Power F2 (APF2BU3500) PC Desktop
No audio I had to disconnect the usb, audio and mic board that is located on the lower front part of the tower . The usb plug got messed up and was shorting out, It finally caused the computer to shut down and would not boot back up. So I unplug it from the mother board. Since I did that I have had no sound. I believe that I need to put jumpers on the motherboard to get the sound to work agian, but I do not know where to put them. Can anyone help me with this?
  • Dan rogers
    Dan rogers May 11, 2010
    can you provide the model numbers off your motherboard?
    Problem Solver:
  • 5 Answers
Pls....Specify the Motherboard's Brand and model.....
If it is Gigabyte log on to Gigabyte Support Website......
Posted on Jan 28, 2009
  • NEil Duyag
    NEil Duyag Jan 28, 2009
    Click on Support and Downloads>Motherboard>type Motherboard Model>Manual........there you can find the Motherboard manual....in F_AUD section ty to see if there are jampers connected.....
My speaker jack broke off inside my audio input in the back of the computer. I want to use the thermaltake case's front usb and audio out/mic in jacks, but they don't seem to get power or work. My drivers...
> Have you removed the broken jack from the rear end of the pc ?
> Are you trying to use the audio ports on the front panel ?
> if you are trying to use the audio port on the front panel you will first need to remove the piece of the broken jack stuck in the rear port - cos you can take an audio out line either from the front OR the rear any one
Oct 22, 2013 | Thermaltake Mid-Tower VL10001W2Z Element G...
My son tried to put a usb lead into my pc the wrong way and he bent all copper pins inside is it easy and cheap to repair or could i connect the tower to my laptop???? theres a hard one for you teckno
No, it isn't hard.
Wrapping your mind around Quantum Mechanics, and String Line theory, is a little tough; though. lol!
http://en.wikipedia.org/wiki/File:USB-Connector-Standard.jpg
http://en.wikipedia.org/wiki/File:USB.svg
Will make sense in a moment.
The front of your computer is the Front Panel.
Those are Front Panel USB ports.
On the motherboard are USB headers.
Small rectangular shaped pieces of plastic, that have contact pins sticking up.
EACH USB header will support TWO USB ports in the Front Panel.
Therefore; there will be two cables coming from two USB ports, in the Front Panel; and connect to ONE USB header on the motherboard.
IF, you feel the contact pins in the USB ports in the Front Panel, may be Touching each other; I strongly advise disconnecting the cables TO them.
Disconnect from motherboard.
Why?
Because if they touch each other, it will short the USB header out; on the motherboard.
This = No.
Then just use the USB ports on the back of the computer.
!O_O!
This is to save money, Mark; and save your computer.
Going further; If there are enough funds available, then I suggest replacing the Front Panel I/O/USB/Audio Control Panel Board,
http://www.ebay.com/itm/DELL-MJ282-DIMENSION-3100-E310-FRONT-I-O-USB-AUDIO-CONTROL-PANEL-BOARD-CN-0MJ282-/380380245011?pt=LH_DefaultDomain_0&hash=item58906dec13
http://www.dell.com/support/Manuals/us/en/19/Product/dimension-3100C
Service Manual (1611KB)
A) Removing the Computer Cover
B) Removing and Installing Parts
Connect desktop to laptop to do what?
For USB port availability? IMHO that is like shooting yourself in the foot.
Also, how do you propose to accomplish this?
The USB ports in the Front Panel, are for ease of accessibility.
(As the young tyke has found, lol!)
Connecting a laptop greatly detracts from this.
Jus sayin'.
For additional questions please post in a Comment.
Regards,
joecoolvette
http://www.youtube.com/watch?v=Nv1_YB1IedE
http://www.youtube.com/watch?v=Mlbuh3_ZKsE
Mar 23, 2013 | Dell Dimension 3100 PC Desktop
How to connect speaker into my computer.
Speakers generally have a cord with a usb plug on the end for power and another cord with a male audio jack (it should be green) for receiving the sound from the computer. On your computer tower there should be terminals for both. These are located on the back, front, or both depending on computer model. Connect each wire to its respective terminal. If possible you should connect them from behind because it creates less of a mess around your desktop.
Aug 25, 2011 | Kinyo Audio Players & Recorders
Hello, I recently purchased all new computer components, including a Diablotek EPIC ATX Mid Tower case. I have the system complete and running. At first I plugged a USB device into the front left USB...
Hi Red,
I had a similar problem on a different case though.They might have similar causes.
The front usb port circuit board was connected to the MB with a ribbon cable. The prior owner had the cable attached backwards. It worked fine, until you plugged in a USB device, instant crash.
Can't say for certain this is what is happening with you, but it is a possibility.
I'm sure you already know, pin 1 is the striped cable. On the board pin 1 has an arrow.
Best regards
Mike
Feb 05, 2011 | Diablotek CPA-802 ATX Mid-Tower Case -...
Can you please tell me where the front jack audio pins and USB pins has to be pinned
ok...
this is how you can find it..
you can see the audio pin in the lower left of your board...
and the usb socket you can see it in the right side of the board..
by the way there name encrypt on it..
take note the - sign indicates the black wire and the positive is the red..
don't get messed up..
hope i've help you..
Feb 08, 2010 | EliteGroup P4M800-M7 Motherboard
Hi sir i have hp d530sff pc and i have
The audio cables are either connected from your sound card,or very close to the location of the rear audio output.
Nov 05, 2009 | HP (KZM-6120) Motherboard
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
Front panel how too
Hi slider1958,
You want to connect the new case's front sound & mic.
Just about every case will come with a pre-assembled connector for front USB's & sound & mic. Your board has a set of ten pins used just for this. They are loacted just under the boards rear external sound / mic silver housing. Noted in your manual on pg. 15. Named AUDIO1.
def37da.jpg Notice there is one pin missing. Line your case connector to match.
The manual is uncleare if you are able to use both rear speaker & front speaker at the same time. I would think not. Newer boards with HD do allow this.
Good Luck & Kind Regards.
& please vote.
Mar 18, 2008 | Intel Motherboard
Hi i have a problem connecting the front pannel mic and standard audio connections to my winfast k8m890m2ma motherboard the manual shows where the 8 pin "front audio connector" is like this...
It is a bit of a problem when you have single connectors but here goes. You use the Front Audio connectors. The manual says you have :::.:
If you turn the board round until the dots are the same way round as above. Working from left to right.
Bottom row. MicIn, MicBios, SpkoutR, empty,SpkoutL
Top row GND, empty, returnR, blank space, returnL. Now this is the tricky bit. Try the power if it works OK. Because the board and the case manufacturer work to different descriptions, try this as an alternative. You may have to swap over the two connectors for GND and Mic Bios.
Mar 10, 2008 | Computers & Internet
Acer Power F2 (APF2BU3500) PC Desktop Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
