Question about Pacific Cycle Cycling
The Adjust screw on front brake broken out of plastic bracket, new schwinn mtn bike. Ft brake pad rides on rim.
The plastic holder to tension the brake pad is broken, This is on the left side of the ft wheel.
5 Suggested Answers
capsman
  • 111 Answers
SOURCE: i took front wheel off bike to fix puncture. i
Loosen up the hub nuts. Center the wheel between brake pads. Put something like a screw driver in the space between wheel and frame to keep the wheel centered and not moving as you tighten the nuts.
Posted on Oct 03, 2009
dunnbiker
  • 8546 Answers
SOURCE: adjusting brakes - Schwinn Speedster
Try this:
http://parktool.com/repair/byregion.asp?catid=14
Posted on Jun 28, 2010
vetteman3002
  • 2299 Answers
SOURCE: When I apply the front
The brake mechanism should have a spring to return the brakes to the open position. It sounds like the spring has came loose. Check the spring on the brake mechanism down on the front wheel. It will have a spring on the back side of the brake.
Posted on Mar 01, 2011
dunnbiker
  • 8546 Answers
SOURCE: brake pads on schwinn folding bike, one side of
http://www.parktool.com/blog/repair-help/linear-pull-brake-service-v-brake-type
Posted on Jun 25, 2011
Replace and adjust brake pads
Is this disk or brake blocks like cantilever or vbrake. I have disks now b ut have never messed with them. If it is not disk then I would just say to make sure that the rear part of the pad hits the rim first. Fine tuning is done by adjusting the turn buckle where the cable goes into the lever. Set the brakes so that when you are pulling hard on the brakes, on dry pavement, set the brakes so that they only get tight enough to not quite lock up. And make sure you use both brakes at the same time. Not just one or the other. adjust the pads by putting one or two dimes between the pad and rim. There are also adjustment screws on the brake arms that control spring tension and in the end the alignment of tire between the brakes. You want the same space between pads and rim on both sides. If they squeal because you have been riding with poorly adjusted brakes take a file to the pads to level them out. Thy will grab better after this. Hope it helps
Apr 08, 2011 | Fuji Cycling
When I received my new Dahon Speed D7, the front brake's pads cramp up on the rotor. I tried to adjust the cable tension from the little dial at the handlebar but could not find the difference. Is there...
I think that bike has a v-brake on the front. You probably need to loosen the spring tension adjustment screws. On each brake, near the pivot, there is a small screw - turn them counterclockwise until you see a gap between the pad and the rim. If you don't have enough play, you may need to loosen the screw on the top of the right (i think) brake to give you some slack. Try the tension screws first.
Mar 01, 2011 | Dahon Speed D7
Schwinn Meridian rear brake squeak. Goes away with slight pressure on hand lever. Solution? Thanks.
The brake pads should be "toe'd" in, that is, the front part of the brake pad should touch the rim first when the brakes are applied. This should only be an adjustment of 2-3mm when you look at the pad compared to the wheel rim.
Another possibility is the age of the brake pads. As they get older, they get harder and lose their pliability. Their harder surface can cause squeaking, and poorer braking performance. You can try sanding them down with coarse sandpaper as a stop-gap, but for the relatively low cost of new ones, replacement is a much better option.
Nov 20, 2010 | Schwinn Meridian Adult 26-Inch 3-Wheel...
I have a 26" Huffy men's mountain bike with shocks on the front forks. When ever I apply the front brakes the bike shakes badly and the front forks flex forward and backward rapidly. I couldn't see any...
Sounds like you have brake chatter. You need to "toe in" your pads on the front brake. Most new brake assemblies have a wedge shaped washer between the pad holder and where it mounts. If you loosen the nut that that holds the pad holder to the assembly and turn the washer you can see the relationship betwween the pad and the rim change. Turn the washer so the pad is toed in slightly(the end towards the front of the bike). If your brakes don't have the shaped washer you can put a crescent wrench on the brake arm and CAREFULLY tweak the toe in. Be gentle and good luck!
Oct 06, 2010 | Huffy Men Mountain Bike (26")
How do you adjust front cable tension, the front brake pads are a bit away from the rim
The sleeve surrounding the outer cable where it exits from the brake lever mechanism is usually a screw adjuster. Turn anticlockwise to bring blocks closer to rim.
Oct 31, 2009 | ProMax 197NC Bmx V Type Brake Set, Rear,...
How do i adjust the brakes on a schwinn stingray low rider bicycle? the front brakes dont grip the wheel enough to stop and the rear is rubbing on one side. thanks
Let us start with the rear. The brake arms will have a small screw located on them near the pivot. You can screw these in to adjust the relation of the pad to the rim. You can also (if that didn't take care of it) remove the brake arm and move the spring's pin to the next hole to make sure it properly clears itself.
The front can be tightened on the brake levers with the adjustment barrel, or, if that is already fully turned out, turn it all the way back in and release the cable at the brake itself and retighten it when you have adequately adjusted the brake there.
Check out Parktool.com's repair help page (located at the top right hand of their homepage) for excellent detailed and illustrated help in bike maintenance.
Hope this helps a little,
matt
Sep 19, 2009 | Schwinn Stingray Chopper Youth Bicycle...
I have a cigna ozark mtn bike. How do I get the front tire off??
Pull the two brake arms together at the top and you should be able to unclip the cable guide ( noodle ). The guide clips into the bracket on the arm opposite to the one the cable is bolted to. If you don't have enough clearance you will have to loosen or remove the brake pad on that side and adjust it again after. Hope this helps.
May 23, 2009 | Cycling
Cycling Logo
14 people viewed this question
Top Pacific Cycle Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Pacific Cycle Cycling Expert? Answer questions, earn points and help others
