Question about Maytag MAT12CS Top Load Washer
Empty washing machine still unbalanced
My Maytag top load coin-op washing machine "unbalanced" light is on- even with no clothing within. I have spun the drum and turned the internal timer to "run" a load through. Once that "load" is done and I push the coin-filled coin tray in, I get the "unbalanced" light and no action (unless I intervene again with the timer). Any advice? Thanks!
  • 1 more comment
  • PRISCILLA lee Jul 20, 2007
    Interestingly enough I had tried rocking the machine a bit last night (before I got this answer) and when I went to try rocking again this AM the machine had somehow self-corrected- delayed response to my rocking last night? I'll never know, but I think your solution is the right one :) Thanks
  • jsciegienka Mar 16, 2009
    I have the same problem.
  • Anonymous Mar 21, 2014
    Machine was bouncing about and I turned it off, re balanced it then set it off again and it was fine. I have used it again today and it is leaking lots from underneath
  • 147 Answers
Lift the Back up by the Top back it has self adjusting legs and do the sam in Front ttech
Posted on Jul 20, 2007
SOURCE:
Gw612 won't agitate
Fantastic that's great news you got it going.
Oct 04, 2013 | Fisher and Paykel GWL11 Top Load Washer
How to clear maytag f20 error code
Open the top access door and press the black bottom right button for 2 aeconds.put the access door back.
Oct 13, 2012 | Maytag MHN30PDBWW Washer - High...
Coin completely jammed in vertical coin drop mechanism
unplug the machine,open the top of the coin op i use a stubby 5/16 nut driver,you have to remove the rod and it's a 5/16 inch rod,turn it counter clockwise to remove,this rod holds the unit in place,when you have the rod out then you can grab the front where you put the money in and lift it up and out,it sits in a couple of slotted holes
Nov 11, 2017 | Maytag MAT12CS Top Load Washer
Maytag washer won't shift to rapid spin dry (only slow back & forth)
Hi Jim, you issue could be caused by a couple either one of a of the following,
1) Draining problem, cant empty the water from the machine within the prescribed time limit - preventing the spin programme to commence. check pump filter is clear and waste water is pumping from the end of the waste hose, the hose itself could be blocked with limescale and detergent residue.
2) Unbalanced load, most machines wont spin 1 item, its a safety thing, if a machine spins with one heavy item it puts the drum out of balance resulting in excessive drum movement possibly damaging the inside of the machine and put indue stress on the bearings. Try putting it on a spin cycle with no clothes in
Unbalanced load detection can also be caused by a faulty motor tacho, this usaually positioned at the rear of the motor, this sends an electrical signal to the programmer telling when it is 'Safe' to spin. There also the posibility that the programmer is not reading the tacho signal or misinterpriting it.
May 20, 2009 | Maytag Washing Machines
Lost coin op washer keys
you need a locksmith.  Because of the key design
Mar 11, 2009 | Maytag MAT12CS Top Load Washer
My maytag neptune wash machine does not drain and spin clothes it
its ok dc means the clothes are unbalanced..even the load open lid and restart..onthejob
Jan 31, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken.  It needs replacing.
Dec 25, 2008 | Maytag MAT12CS Top Load Washer
Maytag MAT12CSDAW
Leep, open the hatch that the timer sits under. You will see the timer and actuator that the coin tray pushes to start the wash cycle. You can rotate this cam clockwise until it gets to it's home position, ususally right around the 12:00 position. Good luck
Jun 20, 2006 | Maytag MAT12CS Top Load Washer
Maytag MAT12CS Top Load Washer Logo
1,324 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
