Question about Dell Inspiron XPS Series Notebook: XPS M1530, M1530, PP28L (707425009297)
Dell pp28l enciende pero la pantalla esta negra
Se enciende el portatil pero la pantalla se queda negra no se ve nada
  • 3 Answers
SOURCE: Dell axim x3i problem
Press and hold the reset on the back and press and hold the power button. This will reset to manufacturing settings.
Posted on Sep 23, 2007
nblady
  • 206 Answers
SOURCE: Quitar Password de Bios de Pc Dell Optiplex GX100,
Hope you can read this. if not, GOOGLE...TRANSLATE.
Removing the PSWD jumper is the correct method of clearing the BIOS password. Removing the battery resets the CMOS.
Remove the power from your computer. Remove the battery. Remove the PSWD jumper. Wait!!!!
Keep power off the computer for at least 30 minutes, overnight is better.
Replace the battery. Plug the computer in. Do Not Reconnect the PSWD jumper.
Now reinstall your operating system and drivers. When finished, restart your system. If everything works and you want to redo the BIOS password, shut the computer down. Unplug the power. Remove the battery. WAIT.
Replace the PSWD jumper. Replace the battery. Plug in the power. Restart the computer, hitting "F2" as it starts....to open the BIOS setup page. Reset your password here. Esc to continue, Yes to save.
Good luck
Posted on Feb 24, 2010
Joed911
  • 4338 Answers
SOURCE: el problema que tengo es
Nused que cuando movi? la impresora que usted instal? atr?s encima de la bandeja de 250 hojas (es requerido para el modelo 3100cn), es posible que puedan haber da?ado la entierra-conexi?n el?ctrica entre la base de impresora y la unidad de 250 hojas de bandeja.
Devuelva la base de impresora de la unidad de bandeja y conjunto aparte. Examine con cuidado el conector en la unidad de bandeja y aseg?rese del corchete que contiene el conector no ha sido doblado ni ha sido deformado. Consiga alguna ayuda e incline la impresora atr?s suficiente distante que usted puede examinar el conector que aparea debajo de la impresora. Si no ayuda a estar disponible, desliza la orilla de la impresora lejos la orilla de una superficie fija s?lo lejos suficiente en ver la conexi?n.
Posted on Nov 30, 2010
SOURCE: tengo un proyector dell modelo 2300, lo compre de
yo tengo un proyector de la misma marca y modelo pero sin la
lampara si gustas te lo vendo barato o me vendes la lampara cel 01 4611886077 luis enrique
Posted on Jun 10, 2011
  • 539 Answers
SOURCE: cuando se conecta el pc a la toma de corriente, se prende directamente la pc, no da video ni reconoce teclado ni mouse
http://www.manualowl.com
Posted on Apr 13, 2012
Eee pc 90ha mb pantalla negra no enciende
Tengo un pc eee top et1602 y la pantalla no enciende se queda negra los led si prende el ventilador tambien ando preocupado si alguien tiene repuesta a este problema por favor enviarme un correo digitalpaint2012@gmail.com o por aca
Feb 16, 2012 | ASUS Eee PC 900 PC Notebook
Buenas, Enciendo el ordenador y aunque el led esta encendido y se abre la tapa del CD no se oye el disipador ni se muestra nada en pantalla
Buenos Dias,
Cuando enciendes el ordenador es normal que la tapa del CD se encienda. Ahora trata de nuevo de encender la netbook pero con el cargador conectado. Cuando conectes el cargador deja trata de encender de nuevo la netbook hasta que se enciendan varias de las luces. Y espera a que cargue el Sistema Operativo.
Jun 26, 2011 | Compaq Evo N800c Notebook
Hola amigos tengo un problema con un Tv Sony wega modelo kv-29fa515 chassis BA6/9 el tv me enciende osea arranca bien imagen, color y sonido pero alcabo de cinco segundos se me cae la imagen osea queda la...
por favor si alguien tiene informacion que me sirva para arreglar esta falla,le agradesco de corazon.el tv enciende y la pantalla queda oscura,el filamento enciende y los voltages de catodo estan elevados(192v) si aumento el escren, aparece imagen muy al fondo,la pantalla tiene lineas de retorno y cambia de azul a verde.
Jan 12, 2011 | Televison & Video
No enciende la lampara pero el tele si enciende pero la pantalla esta negra
la lampara es muertos posiblemente. lo siento.Póngase en contacto con el fabricante.
Nov 12, 2010 | Samsung SP50L6HX 50" DLP HDTV
Por Favor me gustaria que me respondierais a la mayor brevedad posible y en español. Mi lg pdp42,estaba funcionando perfectamente y de pronto se escuchó un ruido,como cuando se va la luz,como si...
Podrias proporcionar el modelo completo de tu plasma?
Cuando proporciones el modelo te indicare donde esta la falla y tambien donde comprar la parte(s) para reparar tu TV.
Sep 12, 2010 | Televison & Video
No enciende el display queda negro. La fuente y la bateria estan bien. El ventilador de la cpu funciona. parece estar todo bien pero no sale nada en la pantalla. Gracias
mi laptop cuando estoy trabajando se queda la pantalla de muchos colores y me impide seguir trabajando, y tambien sino pasa eso se queda pegada
Aug 24, 2010 | Gateway MT3422 RTL Notebook
LA PANTALLA SE PONE COMPLETAMENTE NEGRA CUANDO ENCIENDO EL AIRE ACONDICIONADO Y SOLO SE ESCUCHA
Dependendiendo donde vivas, y si esto solo ocurre cuando enciendes el aire, es simple que la misma linea que alimenta el aparato de aire acondicioneado, es la misma que esta supliendo energia al TV. El area donde vives debe tener problemas con caidas severas de voltage. Los equipos cuyo consumo de potencia es menor que la inmensa demanda de potencia que requiere un acondicionador de aire, tienden a llevar la peor parte del sunministro electrico. Te recomiendo que busques otro toma corriente para suplir el TV, y para estar seguro de que lo estas colocando en una linea que no esta con el aire, sin encende el aparato de aire acondicionado enciende el TV y ve te a la caseta de breakers, ve bajando (off) uno por uno hasta que veas que el TV se apaga, ponle una matrca a ese breaker ya que es el mismo que suple el aire. Luego conecta el TV a otro tomacorriente y repite el proceso (asegurate tambien de que la nevera esta apagada) si ves que en un breaker diferente al que marcaste hace apagar la tele, entonces dejala en ese toma corriente y con todos los breakers arriba (on) enciende el aire acondicionado) si no sufre la tele, ya resolviste el inconveniente, pero si se vuelve a poner negra, busca un multimetro o tester y asi con el aire funcionando, pon el multimetro en la funcion de voltage AC (voltage alterno) Y mete cada uno de los terminales o puntas del multimetro en un tomacorriente (no hay peligro alguno, el multimetro solo mide) deben haber 120 voltios aproximados con un descenso s ascenso de un 10%, es decir entre 108 a 132 voltios. si baja mucho menos el valor de lo que especifique, entonces tienes un serio problema con la energia que te suministran a tu casa. Si eso ocurre, me escribes y te doy una pequeña solucion a eso...
Dec 29, 2009 | Televison & Video
Compaq deskpro EN
mi compaq deskpro pentium iii enciende y se queda contando la cantidad de memoria..y luego se reinicia..y cuando le doy a f10 me dice que el cmso tiene problemas, y le he quitado la pila y el jumper pero todavia sige igual, y le he dado al boton que esta en el board que dice CMSO , pero no se arregla nada
Sep 26, 2009 | Compaq Deskpro EN PC Desktop
Mi pmp carga y enciende su luz pero no quiere encender el aparato
YO TENIA UN PMP ME PASO LO MISMO. Y TEMO DECIRLES QUE MURIO, TUVE QUE CAMBIARLO, LO QUE ME DIJERON FUE QUE SE DAñO LA MEMORIA Y LA BATERIA, ASI QUE PAILA. TAL VEZ EL TUYO NO SUFRA LO MISMO
Dec 06, 2008 | iRiver PMP-140 Digital Media Player
Dell Inspiron XPS Series Notebook: XPS M1530, M1530, PP28L (707425009297) Logo
179 people viewed this question
Alun Cox
