Question about Frigidaire FSC23F7D Side by Side Refrigerator
My frigidaire model R134a not cooling - Frigidaire FSC23F7D Side by Side Refrigerator
    Genius:
  • 1,669 Answers
Get it recharged with coolant.
Posted on Jan 22, 2013
Frigidaire r134a the freezer is not cooling but the fridge is working
Bobby, I'm not sure what refrigerator you have but are you sure your refrigerator part is working? Did you actually measure the temperature in it? It should be around 40 deg F. The reason I ask this is because in most cases, the refrigerator portion of the unit receives its cold air from the freezer. This suggests that you can't have a problem in the freezer section without a problem in the refrigerator section. You may want to clarify this point before you move on with the diagnosis.
Dec 07, 2016 | Frigidaire Refrigerators
Where is the drain located on Frigidaire model r134a? is it the hole on the bottom freezer side?
R134A is not the model number. This is located inside the freezer on a white sticker on the left or right wall. Anyways, the drain is going to be located inside, behind the back wall of the freezer on the floor, directly below the Evaporator coils where all of the "cold" in your entire box is created. If you're referring to a refrigerator, there should be an aluminum tray/pan that all the defrost water drains down into. Sometimes they just freeze over & the hole becomes plugged w/ice. Hope this helps. Tips appreciated. Have a great weekend :)
Mr. All-Star
Jul 30, 2016 | Frigidaire Refrigerators
Where do i add r134a freon to frigidaire gallery refrigerator model frs26zth
U don't unless you get the correct size shraeder valve and install it on the suction line. And when you do add freon it has to be done very carefully since refrigerators are very fussy about the correct amount of refrigerant. They are not tolerant of slight overfills/underfills like air conditioners.
Should use gauges to monitor suction line pressure
Nov 10, 2015 | Frigidaire Refrigerators
Need to find were water filter is to change model R134a
R134a is the refrigerant that is pumped through the compressor. The water filter is for the water dispenser and the ice maker, it has absolutely nothing to do whatsoever with the refrigerant. If you have a water filter on your model, and its possible you dont, it will be located inside the fresh food section at the top.
Oct 09, 2010 | Frigidaire Refrigerators
Frigidaire r134a compressor.how can i know the horse power
It depends the model number, 452 BTU are 1/6 HP, R134a 776 BTU are 1/5 HP.
Dec 20, 2009 | Matsushita DD73C14GAU6 1/4 HP R134...
Model R134a Refrigerator...Freezer works fine but no cooling in the refrigerator... What can I do if anything besides replace it?
Two things, One, the coil in the freezer could be Iced up, deforst the freezer.
Two, the circulatng fan is not running.
Sep 01, 2009 | Frigidaire Refrigerators
(Frigidair refrigerator R134a system) 3 months after a new compressor was installed it stopped cooling, it leaked. I found and repaired the leak. Then bought some automotive R134a it had dye,conditioner,...
The stop leak probably stopped up your cap tube system and the filter drier.You can try by replacing the filter drier, vacuum the system to 500 microns and recharge.The automotive 134a is the same as any other 134a.
Jun 08, 2009 | Frigidaire Refrigerators
Refrigerator not cooling freezer working fine
Refrigerator suddenly not cold enough . Drip pan clean and dry. No dirt or dust.
Oct 05, 2008 | Randell 20072SC R-134a Refrigerator
Frigidaire FSC23F7D Side by Side Refrigerator Logo
97 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
