Question about Toshiba MV13L3 13 in. TV/VCR Combo
MV13M3 TV/VCR Combo
Remote does not work with tv, so purchased a new remote and it does not work.
I did take a cell phone camera and the light flashes when button is pushed.
Is there a setting on the tv that needs to be addressed or is the tv gone?
What kind of universal remote do you have? Is it "One For All" ? Did you try the "Search for your Code" method?
Posted on Mar 31, 2009
What is the code for a Panasonic tv/dvd/vhs combo.....
New 3 digit codes for DVD/VCR, DVR/SAT, TV/VCR, TV ...
DVD/VCR, DVR/SAT, TV/VCR, TV/DVD, DVR/CABLE and DVR/DVD combo codes for GE/Jasco three digit universal remote controls purchased after ... 3 digit codes for GE Universal remotes purchased after August 2002 ... PANASONIC, 437.
[PDF]Manufacture Code List
AT&TDVD VCR COMBO. VCR. HTIB. REC TUN. AMPLIFIER. TV. Abex 1098. Admiral ....Panasonic 1003, 1010, 1049, 1053, 1096, 1123, 1152, 1231, 1289,. 1292 ...
Remote Control Program Codes - FTC -
Jan 01, 2016 | Panasonic Televison & Video
What is the remote code for a toshiba 55HX70 tv
Almost any Toshiba code for sets made around that time will work.
Google the model number for the remote you are trying to program for "manual" which will have instructions and a list of possible codes to try.
Jun 15, 2012 | Toshiba MV13M3 / MV13M3W 13 in. TV/VCR...
My remote won't work at all.
If no remotes work it is likely the remote receiver (ifrared and at front of set) is either dirty (lens) or bad.
A hint here is try original remote right up against the receiver--if works receiver is bad.
Note: original remote can be tested by a shop or even with most digital cameras--in a dark room the remote pointed at the camera and the lcd display will flash faintly when buttons on remote are pressed.
Apr 22, 2012 | Toshiba MV13M3 / MV13M3W 13 in. TV/VCR...
How to program tv manually
You need the original remote, a universal will not do this--
You direct enter a channel number and then in set's menu select in setup ADD---if auto program will not work you can direct enter channels one at a time and then add them into the memory of the set with the remote.
Apr 07, 2012 | Toshiba MV13M3 / MV13M3W 13 in. TV/VCR...
Remote doesn't work. have purchased after market units and they don't sync up either? What to do?
Return the tv universal remote where u bought it,get ur money back.If none of the tv univeral romote programming codes on the owner manual codes for ur tv make and model don't even work and don't have any responses for ur tv make and model functioning all.Try website like to buy the tv original remote or a very closed compatible clone one.
Sep 03, 2011 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
I need the remote code for the toshiba MV13M3
Universal remote setup codes for Toshiba TV/VCR combo are:
0260 0358
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jul 14, 2011 | Toshiba MV13M3 / MV13M3W 13 in. TV/VCR...
Have a Toshiba TV model Mv13M3. All of a sudden it turned off, with no sound and no picture and the word "line" in green on the upper rightn hand corner of the screen. Any suggestions?
Although I did not manage to find the manual for this combo set, to check it fully, it seems that maybe someone pressed the remote button marked "Input Selection" that selects each one of the audio/video inputs of the set.
Press it two or three times and check if it cycles the inputs till a TV channel shows on the screen.
Hope this info can help you!
Mar 12, 2011 | Toshiba MV13M3 / MV13M3W 13 in. TV/VCR...
Remote Control does not work
well probally not dust sounds like a bad reciver i just fixed one about a month ago
Apr 03, 2009 | Sylvania SRC22134 13 in. TV/VCR Combo
Panasonic pv-df2704 remote control does not work
if you have a mobile phone with a camera on it put it into video mode to record a video and point your remote control at the lens of the camera at arms length so you can see the remote through the screen on the phone then press any buttons on the remote control and that will tell you weather it is working or not, you should see a light flashing on your remote control that is not visable to the human eye (the camera on your phone can see it but you cannot) you will see it via your phone camera, change batteries on remote control if you dont see the flashing light emmiting diode on your remote control. (infra red) otherwise take your tv to a repair shop,
Mar 28, 2009 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Toshiba MV13L3 13 in. TV/VCR Combo Logo
326 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
