Question about Brother Disney ULT-2002D
How to replace floppy with usb on Brother ult2002D
I have a ULT2002D Brother sewing machine that keeps catching the thread. From the needle and winds around the bobbin causing a jam. What Can I do about this and can I fix it myself
Sounds like there is a hook of metal either on the needle or the bobbin case (sometimes happens when trying to sew something very very thick and the needle bends slightly and hits the bobbin case.). Suggest changing needle 1st, if this is not the problem, take out bobbin case and look and feel with fingers, if there is a mark where the needle has hit just use your own steel nail file and file the area very gently to remove the bur. Good luck!
Oct 11, 2017 | Brother Sewing Machines
Do you have the repair manual for the Brother ULT2002D sewing machine?
no
but if you go google and type in -workshop manual for brother ult 2002d sewing machine -- you may find a pdf version for download
Jan 22, 2017 | Brother Sewing Machines
How do I format a floppy disk for use in a Brother ULT 2002D Embroidery Machine
Contact Brother Online Service. They can direct you best.
Nov 17, 2014 | Sewing Machines
Converting floppy drive to a USB
Speak to a computer shop about a converter
Mar 12, 2014 | Brother Disney ULT-2002D
Floppy drive
No it can be replaced or upgraded to a USB port.
Oct 06, 2013 | Husqvarna Designer I
Is there a way to upgrade a Brother ULT 2001 floppy drive to a USB?
You would have to ask a brother technician this question. But I doubt it.
Oct 01, 2013 | Brother Sewing Machines
Replace floppy drive with USB on a Designer 1
Check with a Viking dealer whether Viking offers a conversion kit. My guess is that rather than offer such a kit, Viking would rather sell replacement floppy drives or a newer model of machine.
Dec 21, 2012 | Husqvarna Designer I
Can the brother pacesetter ult 2002d floppy drive be replaced with usb
Julie, You should be able to have that on-board floppy drive repaired. USB is from a computer only to send a design to the machine.
Cheers,
Embroidery Services
San Diego, CA
Jul 23, 2012 | Brother Disney ULT-2002D
I have floppy disk for all software can I get it on cd?
best solution would be to go on ebay and buy a usb floppy drive, that way you can still use and open the floppies. either that or buy the floppy drive and fit it into the computer.
most laptops and desktops support usb floppy drives
they quite cheap too. good luck
Jun 16, 2012 | Husqvarna Rose
How can I make my presser foot stay up on a ult2002d machine? There is nothing in my manual .I treid unpluging and still not working. If you have a soluition to the problem may I tell others online?There...
If you are lifting the presser foot and it sorta holds then drops down.....its probably worn and needs replacing. If the machine is well used thats usually the culprit. There is a lob on the presser foot lever that wears and causes it to not stay up. No easy solution other than changing the part.....best left to a pro.
Derek
Jan 17, 2011 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
318 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
