Question about Blenders
Need a general electric blender drive coupling
How to replace waring blender 028538 drive coupling
Check and see if your blender was made in China.
If so, the chances are really slim for a finding parts for a fix.
If it was made in the USA, try "e-bay" for parts.
If you need a parts list, you will need to find one first.
Also, type Waring Blender into your search engine on your computer, to see if a dealer or repair place has a web-site.
God bless your efforts.
Sep 16, 2016 | Waring Blenders
5ksb52ewh5 need a spare part
http://www.amazon.com/KitchenAid-9704230-Blender-Coupling/dp/B000V6ZEZ4
Apr 06, 2014 | KitchenAid Blenders
How to disassemble blender drive clutch gear
The hex wrench only fits in one position, there is a groove in the lip in the top housing and you need to turn the coupling until the hex screw head lines up. The groove is normally plugged with a dob of white silicone. The hex screw is not tightened fully tight on reassembly, the coupling needs a bit of slop.
Apr 16, 2013 | Vitamix Blender Driver Clutch Gear Super...
Are the drive coupling parts available seperately?
only for the blender base; not the jar. part# 9704230
Jul 31, 2010 | KitchenAid KSB560 5 Speed Blender
Blender motor drive coupling fitted to motor which drives rotor blades broken and I want replacement.
If it is a KitchenAid blender, the part you will need is a 9704230 coupler.
Jan 29, 2010 | Blenders
My kenmore blender stopped blending!!!
There is a gear underneath the blender blade. This connects the blade to the motor found on the base of the blender. This gear usually get worn out specially if the load that we are giving to the blender is beyond its limit. I hope you could by a spare on one of the electric shop near or might as well consider buying a new set.
Oct 06, 2009 | Kenmore Blender Single-Speed Blender
Can't get drive coupling off bosch unversal blender blade fixture
what you need to do is hold the blades with a towel to protect your hand, then, use a visegrips needle nose to grab the coupling (pushing the guard down) and twist it loose. It may be very tight, when I loosened mine, the plastic portion of the coupling pulled off leaving the metal "nut" tight to the shaft. Either way, remove the coupling/nut in the standard "lefty loosey" direction. Many thanks to the people at pleasanthillgrain.com for walking me through the process. Blessings to you.
Mar 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Broken blender coupling
Try going to MarBeck.com they are a great source for small appliace parts.
http://www.marbeck.com
Dec 15, 2008 | Black & Decker BL600 ProBlend Work Top...
The coupling of my kitchen Aid blender is broke could tell me how to change it
Visit MENDINGSHED.COM.
On the left, click KITCHENAID. On the next page, click KITCHENAID BLENDER PARTS. On the next page, you will see a listing for a drive coupling. You want to choose on the left, which is retailing for $5.95.
You may order the part if you need it. If not, click onto the parts order page and scroll down. There will be a two-step instructional guide on how to properly replace the coupler.
Sep 14, 2008 | KitchenAid KSB5 Professional Stainless...
Blenders Logo
227 people viewed this question
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
