Question about LG WD14311RD Front Load Washer / Dryer
LG WD 1433RD wont turn on
Seems start button not connecting with power
  • LG Master
  • 17,130 Answers
Possible failure of the power to the controller, check after disconnecting and if there is power to the controller with no action there is failure within the board. Check for fuse within or the surge protector, if not there can be damage in the circuit. estimate cost.
Posted on Jan 22, 2013
venexcsd
  • 1185 Answers
SOURCE: The barrel in our LG front loading WD won't turn.
Carbon Brushes on the motor worn down
Pulley loose on the motor or Drum Pulley
Motor control pcb failing to supply enough power to activate the motor
Take your pick !!
Posted on Sep 28, 2009
Testimonial: "Thanks for your help! It's direct drive so no brushes or pulley. It comes up with a fault code but we don't have a manual to look it up in."
  • 383 Answers
SOURCE: My washing machine is LG
I did a quick search on Google-- and I found this site most helpful:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6250
Please enter that, and read thru the pages of good suggestions-- Evidently a new installation uses special reset procedures--
and if the machine has not had High Efficiency soap-- that can cause this trouble--
It sounds like there are several other possibilities too-
Let me know if reading that site is helpful or not-- Maybe we can work thru the site together, and get to the bottom of the trouble.
Mack B
Posted on Jan 27, 2011
  • 5161 Answers
SOURCE: Hi, hope you can help, I have a 4 kg LG Washer /
CL means that the child lock feature is active and the control panel buttons will not respond. For the LG WD1433RD, press and hold the Rinse+ and Pre-Wash buttons together for about 3 seconds to toggle the lock off. For the LG WD14311RD, press and hold Option and Rinse for about 3 seconds. On both washers, there is a small icon between the two buttons needed to toggle the child lock feature on and off. (It's a small face above a padlock.)
The manual as a Djvu file for the LG WD14311RD is available here: http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=WD-14311RD&initialTab=warranty&targetPage=support-product-profile .
The manual for the WD1433RD is available as a PDF here: http://www.manualsonline.com/ex/thread/view/idThread/80183 .
I hope this helps.
Posted on Apr 07, 2011
Testimonial: "Simple explanation , very quick response....fantastic"
  • 6277 Answers
SOURCE: I'm looking for a manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Apr 29, 2011
  • 6277 Answers
SOURCE: Hi LG WD 1433rd wont spin up to speed. Have
'won't spin up to speed'- does that mean that it stays running at the normal slow speed? If so it could be motor OR control board.
If it is just struggling then it does sound as if the motor requires replacement, particularly noticeable when called upon to run the spin cycle. It is not uncommon to find that the brushes are worn sufficiently for them to not make perfect contact with the commutator at the higher speeds- bouncing and sparking. Now, a word or two of advice from this retired Englishman in SW France. It might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the commutator (like the worn ones!), often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor on our 19+ year-old Bosch at a cost of GBP250 ;-0(
The choice of course is entirely up to you- but do not forget that it is not an uncommon fault, especially if the washer is not exactly new. Others I have given this advice to have chosen new brushes and I don't blame them!
John C
Posted on May 02, 2011
I have an LG-WD-1433RD . My dryer wont spin dry what would be the problem
Most basically it can be 2 things assuming it powers on and the touch controls act normally.
1. The belt that drives the tumbler around is broken and therefore it isn't spinning.
2. The motor that spins the tumbler is blown out and needs to be replaced. Again, no spinning.
In either case they are an easy fix and most any good dryer repair tech can fix it quickly. I've done this type of repair myself, but you have to be handy AND careful because if the exposed sheet metal edges. I always wore gloves and a long sleeve shirt.
Good luck. Having your dryer out stinks!
Hope this helps, please don't forget to rate or ask a follow-up question.
Jul 15, 2014 | Washing Machines
Lg wd-1438rd wont turn on
It sounds like when you moved the machine it pulled a plug off inside the machine, the only way to find out is to disconnect the power and remove the top of the machine, You will be able to see if anything is not connected as it should be.
May 14, 2017 | LG WM2077CW Laundry XL Front Load...
Hi, hope you can help, I have a 4 kg LG Washer / Dyer (model WD - 1433RD). It is displaying "CL" on the readout. Have lost the manual so wondering if this is a simple fix or not?
I hope this helps.
Apr 06, 2011 | LG WD14311RD Front Load Washer / Dryer
LG WD1433RD Washing comes out with black lines and sometimes even worse Have cleaned rubber seal repeatedly Same problem for years every few washes
My LG Front Loader Washing Machine WD-1433RD having a leakage from Front when it fills the water up to ~70% of water. There is no leakage prior to that level. Please help me to fix this.
Feb 19, 2011 | LG WD14311RD Front Load Washer / Dryer
Need User Manual for Washing Machine LG 1433RD Code CL
It means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and thats it.
May 16, 2010 | LG WD14311RD Front Load Washer / Dryer
Cant get dryer to work
Professionals Hair Salons they use Hair Towels because they are Professionals in there field so they better know about this.
100 Cotton Salon Towels Bleach Resistant 16 27
Oct 03, 2009 | LG WD 14311 RD Monitor
Take your pick !!
Sep 28, 2009 | LG Washing Machines
LG washing machine Model WD 1433RD
I had the same problem. I thought it was the motor it turned out I had a nickle wedged in the filter (bottom left behind panel) the nickle blocked the water pump makeing the pump overload.
Sep 15, 2007 | Washing Machines
LG WD14311RD Front Load Washer / Dryer Logo
270 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
