Question about Dell Vostro 1500 Notebook
I am trying to turn my friend's laptop on, but I am getting no sounds. By the power button there is a light blinking with an "a" in it. What can I do?
  • Mr C B Mar 27, 2009
    Dell Vostro 1500 won't boot. Same blinking light as nateisgreat5. pressed everything I can think of- seems to be stuck in sleep or something. Also, the battery doesn't seem to be charging. re-installing it did not work.
  • 1,223 Answers
Check the battery
check if it is in hibernate mode or sleep mode press any key on keyboard.
remove the battery and after a minute re install it now try , other wise try changing the RAM but try all other things first
Posted on Feb 24, 2009
G61-306NR power button doesn't work
Disk Drive works, Memory is good, so any Blinking Lights or Beeps when you hit the power button? Does anything ever post to the lcd screen when you press the power button?
It sounds like either you've got a memory issue or a video card issue. Just because the memory worked in your friend's computer does not mean it will work in yours. Your Slot where the memory goes might be bad.
When you plug in the power cord is there anylights whatsoever on the laptop, where the plug goes in or on the AC Adapter ofthe power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Apr 11, 2012 | HEWLETT-PACKARD G61-306NR Notebook
I tried to power on my computer and there was nothing. It was plugged in and the battery light was blinking amber when I tried to press the power button. The light on the power cord is green but there is...
It sounds like the Power adapter is:
1. Not plugged into the computer
2. Not functioning
3. Has a broken connector (or the laptop has a broken power connector)
Unplug the adapter, remove the battery, hold the power button on the laptop for 30 seconds. Plug in the power adapter connector to the laptop - if the power indicator illuminates, remove the power cord, insert the battery ant then plug in the power cord. Press the power button (hopefully you're back in business).
If that does not help, p borrow an adapter from a friend and try it with your laptop, if it works, then go buy a new adapter!
Sep 05, 2011 | Acer Aspire 7740G6364 (lxplx02165) PC...
I have a Dell Latitude D830 Laptop. One day i found out i can not turn on the laptop. The power light is on, and so the HDD light indicator.. and the caps lock light is blinking. But the screen keep...
Have you tried it with an external monitor?
If this does not help. then you may have a motherboard problem. The Dell motherboard is easily replaced and you can get one on e-Bay
Jun 07, 2011 | Dell Computers & Internet
Lap top will not turn on
There are a couple of things you can try. First let's make sure the battery has power. On the battery there is a little white button next to some LED lights. Press the button if you get no LED lights (they should be green) you have no power, if you get one fast blinking LED you have no power. Plug in your power suuply and make sure the green/orange light comes on on the adapter right where it attaches to the laptop. If you need to you can try a different power adapter if you can find on available from a friend or a store. Assuming you have power we could try reseting the SMC. Press and hold the power button for 10 seconds to make sure the power on the laptop is off. Unplug the power cord and using a coin or key to turn the circular lock, remove the battery from the laptop. Next with the battery out and the power unplugged press and hold the power button for 5 seconds then release. Replace the battery and lock into place. Plug in the power cord. Wait 5 minutes and then try to power the laptop on with the power button again. Hopefully this helps.
Apr 09, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My friends computer just stopped working while she was using it. The screen froze and than she shut it down. When she tried to turn it back on all that happened was that the caps lock, the scroll, and the...
There are a number of things that can cause this to happen. Try taking the battery out of the notebook, disconnect the AC adaptor (if in use) press the power button a few times. Re-install the battery, reconnect the AC (if needed), press and hold the power button for about 2 seconds. This is a hard reboot and should correct you issue. When the notebook powers up, make sure you remove any cd's in the cd-rom drive.
Good Luck,
Jan 05, 2010 | HP Compaq Presario V2000 Notebook
It will not power on when I press the power button and there is a blinking "A" light going off. When I press the power button the "A" light with a lock around it blinks, the fan sounds like it is going to...
try to run diags, press and hold fn key then press the power button an release them both at the same time when the computer turns on, check for any error message, or try to reseat your memory modules too
Oct 04, 2009 | Dell Latitude E6500 Laptop
Samsung sp-r4232 power button blinks 4 times but tv wont turn on
I have this TV. My father in law tried to turn it on one day and it started making a clicking sound and never came on. So he went out and bought a new tv and gave it to me. It came on when I brought it home and worked for a couple weeks. Then just the other day it stopped working. When you hit the power button the light around it blinks four times and then you here a clicking sound. TV does not come on. Took the back panel off and I don't see any damaged caps or fuses. b435b80e-6d09-419f-a021-9b8a430e0a74.jpg
May 03, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Blinking power button, no responce from the laptop
sound like you charger is broken, i think tose use the same charger as the compaq presarios, evo's if you can get a used 65 wat that problem would have been fixed, but those are still pretty new, i think you can get a new charger for free if it's still under warranty
Dec 24, 2008 | HP Compaq nc6320 Notebook
Dell Vostro 1500 Notebook Logo
135 people viewed this question
Alun Cox
