Question about Asus Notebooks ASUS U47A-RS51 14.1" Laptop with 3rd Gen Intel Core i5-3210M
Backlight type for asus u47a-Rs51 - Asus Notebooks ASUS U47A-RS51 14.1" Laptop with 3rd Gen Intel Core i5-3210M
  • Asus Notebooks Master
  • 32,281 Answers
You can get a CCFL lamp from this WEB site.
LCD screens and Inverters www.lcdparts.net
Posted on Jan 22, 2013
Cant down load candy crush on face book
Make sure that you have flash player installed on the browser.
Oct 01, 2014 | ASUS X53E-RS51 New
Num lock not working in asus r500a
maybe you need to clean the keyboard see if nothing is inside it i would turn it upside down and shake out the food particles and dust inside the keyboard if the key itself is broken only way is to replace it.
Apr 06, 2014 | Asus Notebooks R500A-RS51 Laptop
How to fix a broken key
Pry it off carefully with a small flat piece of plastic or metal. Look for some debris underneath. There should also be some mechanism, such as a small spring or metal "X" to push the key back up, it may not be connected or snapped in properly.
Jan 31, 2014 | ASUS X53SD-RS51 Intel Core i5-2450M,...
Is it possible to run two external monitors on a X53E?
Yes, you could via a VGA splitter, which is readily accessible online and ocassionaly in places like Best Buy.
Nov 04, 2013 | ASUS X53E-RS51 New
Need directions to use ASUS X53E keyboard
Check the user manual here:
http://www.manualowl.com/p/Asus/X53E-XR2/Manual/149649
Jan 14, 2013 | ASUS X53E-RS51 Notebook
Can i upgrade my asus u47a with 2nd gen i7 processor to 16gb ddr3
Each computer contains two important components---a Central Processing Unit (CPU) and memory chips. The CPU and memory chips work together to process computations within your computer. You can't have one without the other. Your computer has a base amount of memory installed, 512 Megabytes or higher, that can be expanded to beyond 1 Gigabyte, in most cases. Before you upgrade your computer's memory, you need to know what type of RAM your computer takes: SDRAM (Synchronous DRAM), Rambus DRAM (RDRAM), DDR (Double Data Rate SDRAM) or other type.
Open your computer's Internet browser by clicking on the program's icon on your computer's "Desktop," this applies to both Windows and Mac platforms. Enter www.crucial.com/systemscanner/index.aspx in the URL box at the top of your browser's screen. The "Crucial System Scanner" tool application website will open. Click on the check box next to the wording "By selecting this box and clicking the download the scanner button, I agree to the Terms and Conditions." Click on "Download the Scanner." The "Opening CrucialScan.exe" dialog box will open. Click "Open" or "Run" to download and set up the program directly. Click "Save" or "Save As" to save the program's setup file on your computer if you don't see the "Open" or "Run" option or you are using dial-up or a slow Internet connection. The program will download and setup on your computer if you selected the "Open" or "Run" option. Navigate to the directory where you want to save the file, if you selected the "Save" or "Save As" option. Select the "Desktop" if you have a hard time locating downloaded files on your system. Double click on the "CrucialScan.exe" icon to open the program, if you selected the "Save" or "Save As" option. Click "Run" when prompted with the "Open File -- Security Warning." The "CrucialScan.exe" program will run and appear in your computer's Internet browser. Scroll to the second section on the "Memory upgrades from Crucial.com -- Determine My Memory Needs" website. The section is labeled "Your XXXXX Specifications." The "XXXXX"s represent your computer's brand and model. Locate the wording "Each memory slot can hold..." Write down the this sentence on a piece of paper---this is the type of RAM your computer accepts. Click "File," "Print," "OK" to print this website, if you have a printer attached to your computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible Hope this helps.
Dec 10, 2012 | ASUS U47A-BGR4 2.8GHz 750GB 14" Laptop...
Touch pad scroll is not working
The reason why your cursor is jumping all over the screen is because you are touching it by mistake with your thumb or hand somehow. You can turn the sensitivity down ans set two finger scroll (and other options) for your touchpad - go to control panel > mouse > device settings >
If you do not have device settings, you need to download the official drivers and software to enable all features. The driver you have is probably the default win 8 generic one. Let me know the model number of your laptop and I can help.
Nov 05, 2012 | Asus Notebooks R500A-RS51 Laptop
User Manual asus x53e-rs51
Hi
Go to the following webpage and put your info from your computer into the search panels and download your manual
Please rate me
Bud
http://www.service.asus.com/#!downloads/c1wax
Oct 05, 2012 | ASUS C90S Notebook
Does the Asus U50F have a keyboard backlight? & how to turn on?
No i'm sorry but that model has no keyboard backlight. If you wanted one which did have a backlight you would have to purchase a customised one.
Regards.
Apr 12, 2010 | ASUS Computers & Internet
Asus Notebooks ASUS U47A-RS51 14.1" Laptop with 3rd Gen Intel Core i5-3210M Logo
78 people viewed this question
Top Asus Notebooks Computers & Internet Experts
ray gallant
Terry Schallert
Tony Mitri
Are you an Asus Notebooks Computer and Internet Expert? Answer questions, earn points and help others
