Question about Imperial Commercial Cooking Equipment IDR-2-RG24 Stainless Steel Range
I have an Imperial gas 6 burner range. All my pots are getting coated in soot. The appliance is 11 years old and this is a new problem.
    Genius:
  • 1,669 Answers
Old jets are in need of cleaning or replacing because they are not allowing the fuel to be burned completely! If their orifices are too large, too much gas comes through and there is not enough air to use the gas completely.
Posted on Jan 22, 2013
I noticed soot in my lp gas oven that had been clean. concerned when it started to ruin my food I decided to run the self cleaning cycle again. My whole house filled with toxic soot. My eyes were on fire...
Normally soot is from a range that hasn't been converted for the gas type, like natural or propane. It may be set up for natural when you're on propane or visa versa. Has this range ever worked properly without sooting?
Sep 20, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
Soot build up
Flame is Orange? If so, propane is "choked", not enough air. Remove burners, clean each burner hole with a same size metal dowel (coat hanger works well) flush out inside of burner with garden hose, hi pressure air through all holes to dry. Replace burners ONLY after also cleaning chambers and chimney (garden hose and long brush). Do not forget to clean pilot light area too.
Most Imperials are pre-set air intake. Check gas pressure if able, 3" NG, 10" LPG. Good Luck
May 12, 2010 | Imperial IFS40 Deep Fryer
My pots and pans are covered with soot. We us propane for our 6 burner heavy duty gas range
u stove is designed for natural gas you need to retro fit or change the gas valve over to propane or locate a propane adapter kit for ur stove check with appliance part stores or product company
Oct 29, 2009 | Imperial Commercial Cooking Equipment...
Black soot on bottoms of pans
Wellif you uninstalled and reinstalled the same appliance it should work the same.. thats weird that it changed. however the black soot is usually from flames that are to high. you could try tightening down the orifice where the gas comes out.
Dec 01, 2008 | GE Spectra JGBP35 Gas Kitchen Range
Cannon Rhapsody LPG Gas open Fire sooting up of burners
well its my experience that ranges don't come lpg they are all made natural gas but you convert them to lpg after purchase now if the lpg conversion isn't done properly then they soot like crazy proper lpg converson is to change the spuds on the burners and to turn the orifice over in the pressure regulator do you still have your owners manuel if so consult it on converting gas range to lp then check to see if every thing was done right on the pressure regulater there is a square cap you take it off and there is a round part that on one side says lp on the other says ng this changes the pressure that the regulator as ng and lp operates at different pressures and the regulator has to be set for what you using like i said im not familiar with your brand or model but i do know the problem if the range did come ng then you need to make sure the conversion most ranges aren't lp because there is not that big a market for it read the plate on the back will tell you if it was made ng or lp serial plate on front may say also most of the time it is beside the bottom drawer on the range
Jan 18, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire convection free standing range
new ranges come set for natural gas. in the installation instuctions there should be instruction for converting the range to lp. some models require that the orafice for the burners be replaced as part of the coversion, if so the there should be a pack of them with the new range. others you just have to tighten the orafices that are all ready in the range. you installation guide will tell you which one you have to do
Nov 24, 2007 | Tappan MGF500PBW Gas Kitchen Range
GE XL44 and soot from burners
propane burns very dirty.you need to remove the burners and orfices and clean them good with oven cleaner.make sure their rinsed and dried well before installing,this should solve your problem.
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Imperial Commercial Cooking Equipment IDR-2-RG24  Stainless Steel Range Logo
Top Imperial Kitchen Ranges Experts
Dan Webster
Dan Webster
Thomas Perkins
Thomas Perkins
Are you an Imperial Kitchen Range Expert? Answer questions, earn points and help others
