Question about Dynex Dx-26ld150a11 26" 720p Hd Lcd & Dvd Player Hdmi Free
My brand new lcd tv keeps saying no signal when cable is plugged in?
  • Dynex Master
  • 3,904 Answers
Check the input setting and make sure it matches where it cable is plugged into.
Posted on Jan 23, 2013
Tv wont get channel signal
1- Have you tried a different input cable?
2- maybe try using the set top box tuner?
3- check the input setting on TV?
Good luck
Dec 11, 2013 | Emerson LC320EM9 32 in. LCD HDTV
My dynex lcd tv keeps saying no signal when cable is plugged in?
It sounds like the CATV portion of the TV tuner is bad--Cable band.
You may have an option---with a cable box that has the audio/video jacks for output of signal on its rear side connect to a unused video input on rear of set--go to that input and change channel via the box---BY PASS THE TUNER IN THE SET THIS WAY.
May 25, 2012 | Dynex Televison & Video
I cain't get cable or antenna to work on my 19"dynex flat screen tv to work
if it keeps saying no signal make sure all the cables are plugged into the tv
and select the appropriate input on the tv
Nov 05, 2011 | Dynex DX-LDVD19-10A LCD TV
I am having an issue with my rgb connection, it was working one night the next it says no signal.. what could be causing this? the tv is only 6 months old the cables are brand new as well..
Tries take out and plug in RGB cable back in/out for a couple times,should solved this connections problems mishap.Dose not solved the problems.Return the tv set and get a new tv replacement tv have cold soldering in RGB joints connections somewhere.
Aug 20, 2011 | Vizio L32 32 in. LCD HDTV
Anytime i watch a premium channel, on demand movie the image is blurry and jumpy to the point of getting a headache. Regular HDTV seems to be great with the exception of the blacks on occasion, popping to...
It the tv,it have intermittent video problems,with the Tuner board.That the board in the tv,where the cable company broscating signal cable plug into it.U used a HDMI cable to plug into HDMI port hub to get ur HD signal.Take it back talk to Best Buy,tell them this tv have intermittently not supporting HD frequencies changes.Tell them upgrade the tv frameware software for u
.Or keep presisting give u another replacement tv.
Aug 02, 2010 | Insignia 42" LCD Flat-Panel HDTV
No instructions! do i need a lead to detect tv signals?
By "TV" Signals, do you mean video signals? If so, the WIndows video player does a good job of playing most varieties. If you mean off air or cable TV signals, you'll need a receiver. Look at the Elgato, or similar brands. They plug into a USB port and are capable of receiving analog and/or HD ATSC signals, or cable signals. Keep in mind that digital cable signals are generally a mess to identify and sort out because they are on different digital channels and subchannels. You may need a digital to analog converter in front of your Elgato to keep from going nuts trying to fighure out where everything is.
Nov 14, 2009 | Computers & Internet
VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no signal.so use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Jun 15, 2009 | Insignia LCDTV26 26 in. Television
Won't keep digital signal
If you're connected to a digital cable box, I would try using the external component connections and bypass the TV's tuner. If all you have is straight cable coming into the house, it could be the cable signal itself or a defective tuner in the TV assuming all the menu settings are correct in the TV.
Jul 25, 2008 | Toshiba MW20H63 TV
Laptop to Samsung TV via VGA cable - unsuccessful !!
The problem is located in the CABLE, the SAMSUNG LCD need the higher quality cable than others vendors.
Please try it.
May 13, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Dynex Dx-26ld150a11 26" 720p Hd Lcd & Dvd Player Hdmi Free Logo
82 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
