Question about Panasonic PT-56LCZ70 56" HDTV
Lamp or Power issue Panasonic PT56lcz70
Ok, I have a just over 5 year old (out of warranty I suppose) Panasonic PT 56LCZ70. When trying to power on the green light blinks for several minutes, fan comes on but no light. I acutally Unplugged the tv for a week or two and went back in tonight to see if any better and initially the same problem so I thought the bulb was shot. I was messing with the power button on the tv (press and hold like a computer) and the tv came on working fine. Great picture sound etc. Left it on for about a half hour and it looked great. Turned off and went throught the normal cool down of a few minutes before shutting off. Tried to turn back on and no luck whatsoever. Back to long period of green flashes of power lamp then eventually two red blinks on lamp light. Could this be a power or diode issue as opposed to a lamp or are all the components part of the lamp assembly. I know this is not usually a user servicable lamp replacement but I did watch a tech tear down this tv twice when we first bought it to replace a noisy fan. I have built computers for years and if its a straight forward process I may consider replacing the lamp myself as paying for labor will likely make it not worthwhile as compared to purchasing a new set. Is there anything else I should be checking? Also seem to be finding several compatible bulbs online and may be the difference between new and refurbished?
    Genius:
  • 1,669 Answers
I would think that the fact that when you held the power button in for a long time that would give you a hint! If the power button is making a poor contact there will be a small surge of power and some parts of the internal circuits will respond(indicator lights, for example). Try REPLACING THE ON/OFF BUTTON.
Posted on Jan 22, 2013
4 Suggested Answers
PCCCTech
SOURCE: Panasonic PT-56LCZ70 no picture or sound
My name is Jonathan and I am an employee at the Panasonic Customer Call Center. Based on the symptoms you've described, I'd recommend contacting the Panasonic Customer Call Center at 1-800-211-7262 for assistance. We are here to help customers that have purchased (or are considering purchasing) our products and would like to assist you with resolving the symptoms described here. Our hours of operation are:
Mon - Fri, 9 AM - 9 PM EST
Sat - Sun, 10 AM - 7 PM EST
Posted on Jan 22, 2009
Angel Petter
  • 114 Answers
SOURCE: PT-52LCX65 Lamp Meter
Hello.. meseta809
first off all it's not necessary to have the TV on to reset it. the problem is the dmd need to send the info that you have a working lamp.
try this to see if it work's
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Ok, so apparently there are a couple of different ways forum members have found out how to reset their Panasonic Lamp timer (this should apply to all of them, not just the TY-LA1000 specific lamp)
“Hold the VOL down button on the TV and the SPLIT button on the REMOTE for five seconds”
Again, you will need to press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds, it will NOT work if you try to do it both from your remote!
Posted on Feb 02, 2010
  • 8457 Answers
SOURCE: Lamp or Power Supply (Ballast)?
Power Supply is the problems.The lamp problems you will not have picture at all.U said have power and picture all day sometimes right?Power supply board have intermitten problems.
Posted on Mar 04, 2010
1080p PT56LCZ70, won't turn on, green light flashes for a while and then the red light flashes twice, pauses for a second or two and then flashes twice again, continues to repeat this over and over. What...
I have the same problem with my Panasonic PT56LCZ70, after check the test points, I'm sure its the "LIFI 4000" Lamp, and I think its a faulty part in all kind of those Tv's
Jan 15, 2011 | Panasonic PT-56LCZ70 56" HDTV
WHERE IS THE LAMP IN THE PT56LCZ70 TV? CAN'T FIND IN OWNERS MANUAL
Behind the lower front silver snp-off panel. Then a twist button to open lamp door.
May 06, 2010 | Panasonic PT-56LCZ70 56" HDTV
Mar 04, 2010 | Panasonic PT-56LCZ70 56" HDTV
My Panasonic pt56lcz70 has a blue tint to the picture after I got it back from the repair shop they replaced the lamp any ideas?
the optical engine is bad you just couldn't see the blue tint before because the lamp had gotten weak
Jan 26, 2010 | Panasonic PT-56LCZ70 56" HDTV
Panasonic LCDHDTV PT56LCZ70 turns off randomly and the green light just continues to blink and doesn't turn back on even if left off for a while it still hasen't come back on what is wrong does it need a...
Usually at worst,you need to replace the bulb once every year. Life expectancy for a lamp is anywhere from 1000-3000 hours depending on how heavily it's used.
It sounds to me like you've got a power supply issue more so than a lamp issue,if you haven't replaced the lamp recently then I would try that first,if not have a technician look at the boards for a culprit.
Oct 28, 2009 | Panasonic PT-56LCZ70 56" HDTV
Tv stoped working - LIFI PT56LCZ70
This unit has a very complicated bulb replacement procedure. You would be much better off if you contact a panasonic service center and have them replace it. Bulb assy is pretty expensive as well. The part # is LFS4000PA1EB but you will have to go to panasonic to get it. Good luck. Thanks
Oct 27, 2009 | Panasonic PT-50LCZ70 50" HDTV
Dec 11, 2008 | Panasonic PT-56LCZ70 56" HDTV
Panasonic PT-56LCZ70...according to the manual it's "malfunction 9"...lamp light blinking red twice.
Just curious when all of you purchased tv's. We purchased ours in Jan. 2008. and is now having the malfunction 9. Online manuel says this is a lamp problem and lamps have a two year labor 5 year part warranty so I am working on getting it taken care of under warranty as I have heard lamps are pretty spendy. I will try to let you know how it turns out....Any updates on yours???
Jun 30, 2008 | Panasonic Televison & Video
Panasonic PT-56LCZ70 56" HDTV Logo
199 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
