Question about Brita 35516 Pitcher
The battery is dead
The start indicator does not work anymore
Hi my toyota has probelms starting in the morning, my headlight beam strenght varies between weak and strong throughout the day, and this moning my hazard lights came on and would not go off and would not...
Sounds like the starter battery can't hold the charge from the alternator. A 1 hour highway drive should charge the battery enough - if it's the same the next morning it's up for replacement. Assuming there are no lights, radio or other devices on in the car during the night.
If the battery has been recently replaced - the alternator might not supply enough current anymore. In this case alternator brushes might need replacement or the voltage regulator has died. Usually the battery indicator lights up in this case. The battery indicator light can be checked by turning the ignition key one notch so all lights in the dash light up. If the battery indicator doesn't light the lightbulb might be dead.
Jul 01, 2011 | Toyota Corolla Cars & Trucks
2000 bravada worked ok yesterday went out this morning and won't start. Lights. radio and heater fan run and tries to turn over then just clicks. Could it be starter or alternator
The indication for your symptom is a dead battery, loose battery cable of a faulty ground wire. n If the battery is dead it could be an indication of a charging issue or there is some parasitic load or light that was left on
Apr 15, 2011 | 2000 Oldsmobile Bravada
My acer notebook wont charge all the way it stops at 87% and it wont charge anymore.
hello
The battery is starting to be dead. one or couple of battery cells gone dead, need replacement. if the battery is giving enough backup time then no need to replace it immediately. let the battery gone dead, sooner or latter, then you can replace or repair it,
good luck
Dec 14, 2010 | Computers & Internet
I jumped started my car now my cd player won't work. There is a red light it indicate power but won't switch on. Please help x
sounds like your connected to the battery, and if you had to jump start ill assume the battery is dead..... dead battery=no power, so radio/cd player will not work, replace battery and it should be fine
Jan 08, 2010 | JVC Car Audio & Video
Remote start will not work anymore..already checked fuses????
try to change the battery in the button mite be to dead t ostart but not dead to unlock doors.
Dec 15, 2009 | 2006 Pontiac G6
97 Chevy Astro will not start
Sounds like your battery / starter may be dead. Do you get a clicking sound at all? A click will indicate a dead starter, a buzz indicates battery issues.
May 01, 2009 | 1997 Chevrolet Astro
Ducati 620s - Won't Start - Dead
The battery has died over the winter. Indicators staying on is a sure fire signal of low battery charge.
The battery may have enough amperage to get the headlight and the horn working, but the indicator relays take a bit more.
New battery I'm afraid.
Feb 22, 2009 | 2003 Ducati Monster 620s i.e.
Battery is not charging
Let the battery go all the way dead. You may have to adjust the settings in your bios so that the laptop will stay on until the battery goes completely dead. Then charge the battery. Do this a few times if it does not fix the problem you do need a new battery.
Jan 21, 2008 | Compaq tc4200 Tablet PC
Battery dead, boost car, cd player doesnt work anymore...
Get a testlight or DMM and test all of the power wires. It's your only hope.
Nov 04, 2006 | Panasonic CQ-C5301U CD Player
Brita 35516 Pitcher Logo
140 people viewed this question
Top Brita Water Filters & Coolers Experts
Tom Chichester
Are you a Brita Water Filter and Cooler Expert? Answer questions, earn points and help others
