Question about Broan-NuTone FAN CONTROL SWITCH
3-function control switch
I BOUGHT THIS SWITCH FOR MY BATHROOM. I HAVE  2 SEPERATE-LITES AND AN EXHUAST FAN I WISH TO WIRE TO IT. THE SWITCH HAS ONE BLACK TERMINAL AND THREE BRASS TERMINALS ON THE OTHER SIDE.DO I TAKE ONE BLACK WIRE FROM EACH LIGHT AND FAN AND SCREW THEM TO THE BRASS SIDE OF SWITCH. FROM THE POWER SOURCE ATTACH BLACK WIRE TO BLACK TERMINAL AND JOIN THE WHITE WIRES TOGETHER?
  • 37 Answers
You are correct.
Posted on Jan 27, 2009
Bathroom fan is on the same circuit with the light. Is there a switch that I can install on the fan so that I can control it from the light switch without running an additional wire?
It depends in part on the fan. Many but not all give you the option to run seperate feeds for the fan and the light, which is necessary to do what you want. If you are experienced with electrical work, you will be able to tell because the feeds for the fan and light will be pigtailed together in the small junction box built into the fan housing. You will need to run a new cable to the location where you plan to mount the 2 switches also... hope this helps
Jun 01, 2011 | Cooper Wiring Devices ACE DUAL CONTROL...
I need help hooking up my bathroom fan and light i have three wires going to the bathroom fan and light white black and ground i want a swith to turn off the bathroom light one to run the light to the fan...
Right now a single switch turns on both light and fan.
You want to put in a double switch to control light and fan separately.
But the problem is there is not a separate wire to each the light and fan.
You need a separate wire to each, but the circuit wasn't wired that way.
Usually when the circuit is wired for separate control, there is a red wire that also goes to ceiling box.
Unless you run another wire to the ceiling box, it won't be possible to control light and fan separately.
Electrician can do this pretty easily if there is attic space above bathroom.
Oct 17, 2010 | Broan-NuTone Broan 68W White Decorator...
How do i hook up a two function swith i have white black and ground going to the fan and the light and anther white black and ground coming from my bathroom light i want to have a switch to turn my...
Ok you only have two switches, so you would use one switch for your bathroom light, and the other for both the fan and the light, the light will come on when you turn the fan on.Connect the incoming black (hot) wire to both switches. Then connect the black wire to the switch you want for your light. Connect the other black to the second switch that goes to your fan and light. Connect the three white wires together (neutral) Connect all ground wires together, and leave a pigtail to connect to the ground terminal on the light switch. If you want separate switches for light in the fan and fan, you will need another conductor and a three gang switch.
Oct 17, 2010 | Broan-NuTone Broan 68W Dual Rocker Switch
Have a 2 gang 2 way switch,one of the lights controlled by this switch is really only one way,the other(landing)light is 2 way.I can not get the 2 way to operate correctly they control a bathroom light...
I think your goal with the 2 way switch is to be able to turn the landing light on/off from either the top of the steps or the bottom of the steps. When you run a one way light in with that circuit it will not make a complete circuit, hence the 2 way will not work. If your bathroom switch was in with the light switch at the top of the steps, you will have to seperate these two switches. Make the bathroom a switch by itself, and then connect the two way switches. If a circuit is not making a loop it will not work. 2 ways must make an uninterrupted loop, (the one way is interrupting the loop) in order to function properly. Hope this helps!!!
Sep 21, 2010 | Cooper Wiring Devices ACE6003W-K ACE"...
Our switch for the ceiling fan burned out today. Instead of getting the same type of switch (rotary knob with push on/off) I bought a Pass & Seymour combination toggle switch (dual on/off toggle...
The wire to the ceiling fan are meant to send voltage to the fixture only and are not usually wired to control both the light and the fan independently. In order to do that, you may have to pull another set of wires to the switch box and then connect them to the light circuit in the box where the fan is. In regards to the other wiring that you mentioned, it makes no sense that the wires go to the stove fan and the bathroom fan unless those wires are source wires that carry the incoming voltage.
Mar 17, 2017 | Pass & Seymour #690IGCC6 15A Ivory DPLX...
Triple rocker switch to control 3 function bathroom fan/light
I suggest you cut 3 pigtails out of your black wire (about 5-6" each and strip them so you can put a nut to tie them all together on the main wire, then do the same for your grounds using green 5-6" strips of wire and then connect all 3 switches with the pigtails to their proper locations. This WILL fix your problem.
Mar 08, 2010 | Leviton 1755 Triple Rocker Switch Decora
I am trying to install a 42" ceiling suspended fan .. just making sure the blue(1) and black(2) wires go together and then the green goes to the bare ground wire coming from the box.
If you are not using a seperate switch to control the fan the blue and black go together and the white goes to white and the green goes to green. The blue wire is the fan power wire and the black is the light power wire if you are just using the switch on the fan to control the fan speed then the above configuration is the way it should be wired.
Jan 19, 2010 | Aloha Housewares (93645) Ceiling Fan
Hey i just took a pot light out of the roof of my bathroom to install a fan and light combo in the whiring for the pot light the whiring is on a normal switch and is whired into another light over top my...
yes, maybe- if there is power in the switch then you can steal power from it.. Take off the coverplate and remove the switch. If there are two seperate cables in there with a black and white or a black white and red then there is power there.. You will however need to run one more single wire to the fan, and another switch. You can get a double switch that will fit in the single box..There is one other way to turn the fan on and off, but the light has to be on for the fan to be on, without running new wires. Get a simple pull cord switch and mount it in the face of the fan housing. Then find the black wire running to the fan and seperate it where it ties into the power. Connect the black wire from the fan to one of the wires on the pull switch (either one) and connect the power wire to the other wire on the switch.
Dec 06, 2009 | Broan-NuTone Broan Ultra Silent, Bathroom...
Wiring Bathroom light/vent/heater switch with 3 separate controls
Wiring a bathroom combination vent, heater, light 3 way switch means more wires. In brief, you need to run two cables - one a two wire and one a three wire from the switch to the fan.
Incoming power will have white black and ground.
The two wire cable for the switch to the fan will have wht, blk, and ground.
The three wire will have red, blk, wht, and grnd.
The switch will likely have 2 blacks and a red coming from it, with two blacks and a red on one side, and a single black on the other.
The fan should have a red, blue, green, black, and white.
On the fan end: Group all green/copper grounds together and use a wire nut to fasten them together. Tape the nut to the wires.
There will be five white wires coming through. For ease of handling, using wire nuts, connect two on one nut and three on the other.
connect the blue to a blck. Connect one red to one black, and the other red to the other black.
The switch will have one red going into the 3 wire cable, a black going to the 3 wire cable, and a black form incoming power to the side opposite the 3 wires, and a blck going to the two wire cable.
There. Confused?
May 26, 2009 | Broan-NuTone FAN CONTROL SWITCH
Broan-NuTone FAN CONTROL SWITCH Logo
630 people viewed this question
Top Broan-NuTone Electrical Supplies Experts
Craig Butler
Craig Butler
ken skalski
rickb63
Are you a Broan-NuTone Electrical Supply Expert? Answer questions, earn points and help others
