Question about HP DeskJet F380 All-In-One Printer
Printer wont turn on even the power supply is ok.
  • e_armeza Jan 28, 2009
    thank u 4 d suggestion. i followed it. the problem s n d printer mother board. i can't find external defects
First open your printer and check the if the fuse in power pack is ok, the if is ok then check the wires if there ok the as for new printer mother board ok
Michael
Posted on Jan 27, 2009
Westington tv wont turn on
My tv is a Westinghouse**** Sometimes i move the tv slightly and the cord partially comes out at the side and i just push it in all the way and all is ok
Nov 30, 2013 | Westinghouse 46" Class LED-LCD 1080p 120Hz...
It wont turned on
If you are encountering power problems with your printer, please go through the following checklist:
  • Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
  • Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
  • Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
  • If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
  • Make sure the correct power supply is connected to the printer.
Mar 21, 2012 | Lexmark X2500 All-In-One Printer
My printer wont turn on even though it's connected to direct power supply. Why wont it turn on?
Generally the troubleshooting steps are:
  1. disconnect the printer from the data cable to the computer and plug directly into a wall outlet bypassing any power strips/battery backup and then see if it will power on. If it does, run a self test and see if it prints.
  2. If still in a no power state, unplug the power adapter from the wall and the printer, wait 5 minutes, then plug into wall, then in to printer and try to power on again.
  3. If still no power and under warranty, contact manufacturer for repairs/replacement.
  4. If not under warranty and an Inkjet, almost assured it will be less expensive to replace than to repair:
My current favorite: http://www.walmart.com/ip/HP-Deskjet-3050-All-In-One-Printer/15075186
Jul 10, 2011 | Lexmark Office Equipment & Supplies
My HP Deskjet printer won't turn on even the power supply is ok.
Loose cables. Ensure all cables are tightly plugged in. If that doesn't help it could be a major hardware failure.
Jul 02, 2010 | HP DeskJet 3745 Printer
PRINTER WONT TURN ON...PLUGGED IN...CHECKED CONNNECTIONS ..OK...NO POWER
Is the printer connected to a power bar?
If YES, kindly remove it from there then directly plug-in the printer's power cable to the walloutlet
you can also try other walloutlets
If still not working, then it's time to replace the printer's power supply or the adaptor or the printer itself.
Feb 26, 2010 | Lexmark Office Equipment & Supplies
Power surge, now wont turn on
The power supply is a separate part and only runs around $29.00, even with labor it should be less than $100.00 to repair.
Aug 12, 2009 | Canon PIXMA MP970 InkJet Printer
Shiki
I am trying to do this from memory as I don't have that model in front of me. turn the printer on. then while the printer is on unplug the power lead (don't turn the printer off first)
hold the OK and cancel buttons and plug the power supply back in. keep holding the buttons until the printer powers off. release the buttons, unplug the power lead and after 10 seconds replug in the lead and and switch the printer on.
this is an NVM reset whcih should clear any "hangs" in the printer.
Let me know!
May 07, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
91 people viewed this question
Ben Johnson
