Question about LG WM-2277HW Front Load Washer
LG washer wm3470hva won't turn on without unplug&plug in again
rallupae
  • 9 Answers
SOURCE: LG WFT1081TP Top load washer
The fuse is located in a black cover.  You need to gently pull the front panel out of the way and look to the right of the unit, in the area under where the panel was.  There, you will see a black wire running into a black cylindrical case that has a black wire running out of the other end.  Heed the warning on the label, please, and make sure that the power is unplugged form the wall.  Gently pry open the casing and you will see the fuse within.  The ends of the wires just pull off (gently) and then you have the fuse.
Tomorrow I go on a fuse hunt and try this out.
Posted on Mar 11, 2008
SOURCE: LG Washer (WM2277HB) won't turn on without unplug & plug in again
I'm having the same problem!!! ANY solutions out there?
Posted on Sep 13, 2010
rickead1
  • 1998 Answers
SOURCE: I have an LG WM0642HW washer. After a wash cycle
sounds like a loose connection either going to the main control board or a break in your power cord or the main harness has a fault in one of the connection locations to the main control the control is located under the upper control area this is also the schematic for your machine showing how to access the control area http://c.searspartsdirect.com/lis_png/PLDM/K0810327-00001.png this repair will require you to break out the multimeter if you are unable to visually see any misconnection I await your reply for any further questions Thanks Rick
p.s there is also a relay located on the power board and if you dont find any issue with the wiring it may just be the relay that is hooked on to the main control board as well. I await your reply
Posted on Jun 11, 2011
rickead1
  • 1998 Answers
SOURCE: Hi, I can't open the
I am unable to find that model number for your unit but I did find another that was close and is also an LG Tromm click this link http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28702783&pkw_=basket&model_id=5520802&NewWindow=1 you would have to remove the bottom panel the one that has the drain filter attached to it by removeing the screws that hold the panel in place. Once the panel is removed then you would reach up along the side that the door lock assembly is on and you will see and feel a cord with a ring that you would pull and then your door would open once you pulled this cord. In some units if you unplug the machine for 7 minutes this also causes the control to reset and sometimes this also causes the door to be able to open once the control is reset. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation Thanks Rick
Posted on Aug 16, 2011
inokumum
  • 10 Answers
SOURCE: My LG washer won't power up
Double check the cord to make sure all the wires are hooked up to the washer correctly, check your breaker/fuse box to make sure you don't have a tripped breaker or blown fuse, and check the outlet for power by plugging a known working item into it or using a circuit checker.
If the washer is getting power, try holding the power button down(if there is one) for 3-5 seconds.
If that doesn't help, here's a link to LG's customer support options: http://www.lg.com/us/support/contact-customer-service
Posted on Feb 09, 2012
My new LG front load washer has a deep small scratch in the outside of the plastic door. Should i be concern
Take the reimbursement because the minute scratch is not effecting the performance and you are the only one who is aware of the condition. As for the noise, a bit of One Lube spray on the hinge will take care of that. One Lube is a special oil/silicone application that works on all moving parts that tend to make noise, and it lasts far longer than all other products. Look for it on the internet, or ACE Hardware.
Apr 15, 2014 | LG Wm3470hva Wm3470hva Front Load Washer
When I started my washer wm3470hve for first time after half an hour it started jumping.it was really scary my house was shaking with the noise.
6his can happen when you either overload the washer or you have a low amount of stuff in but it is heavy. would seem 4.0 is the max you can have in the drum at a time. if it persists at this with varying loads. then the shockers have gone weak and need replacing. or the drum has come out off balance. this can because of the bearing or something has dented the drum. somtimes putting shoes in to was can do this type of damaged.
Oct 28, 2013 | LG Wm3470hva Wm3470hva Front Load Washer
Wm3470hva no power
Unplug the washer from the wall wait about 5 minutes, plug it back in to the wall and press the power button. You should see all of the lights on the front come on and start cycling. wait about 2 minutes and you should be ready to start washing.
May 06, 2013 | LG Wm3470hva Wm3470hva Front Load Washer
Wash machine LG wt5001cw won't turn on
I have a LG wt5001cw top loader washer and after it completed its cycle it shut off and will not turn back on. How do I fix it?
Jan 12, 2013 | LG WT5001CW Washer
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
My LG front-loading washer WM2501H drum light comes on at the end of the cycle and won't shut off. Additionally the control buttons cease functioning. If I unplug the machine and plug it back in, the...
I am having this same issue. I have to unplug and replug back in every wash. Very annoying. Especially because I am short and can't reach the plug without a step stool.
Sep 12, 2011 | LG WM2501H Front Load Stacked Washer/...
Washer won't turn on at times. It acts like it has no power. Unplugging electric cord from wall socket and reconnecting seems to reset the unit and it functions normally for a while. After an hour or...
Try this first, unplug the unit and connect it to a different outlet and see if it corrects the problem. If it still continues, you will need to replace the control board. Good luck.
Jun 18, 2011 | LG WM2301HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
717 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
