Question about Flower Factory Fright Tape 40'
I need to buy 24000 ton fish flower - Flower Factory Fright Tape 40'
Which things should be considered while buying a flower bouquet for wedding event ?
I think that if you want red and white flowers for a bouquet then you should go with Rose and Stephanotis flowers because they look beautiful together.
Aug 22, 2016 | Garden
What tonnage is it
not sure what you want so i will give a general answer.
tonnage is equal to BTU ...
so it you have a....
12000 BTU that's a 1 ton AC
24000 BTU that's a 2 ton AC
36000 BTU that's a 3 ton AC
and so on and so on just look on the tag for the BTU's
Feb 01, 2016 | Heating & Cooling
Ge 24000 throws beaker not breaker on unit cord
bad breaker or exceeding its amp rating. a 2 ton window units pull alot of amps on start up.
Aug 13, 2014 | GE 24000 Btu Room Air Conditioner EnerStar...
I need to know what is the tonnage for york heat pump model number f1cp024a06a [air handler]
the 024 in your model number is two ton . this is a 24000 btu system
Sep 15, 2011 | Heating & Cooling
How do I find out how many "tons" my Carrier AC units are?
Look in the model number for numbers like 24, 30, 48, or 60....
They represent the BTU's in thousands of the unit....
The BTU's are 12,000 per ton...
in other words a 24000 BTU unit will be a 2 ton unit
heatman101
Jul 29, 2011 | Carrier Heating & Cooling
How many tons is my unit?
divide your btu rating by 12000. (1 ton = 12000 btu)
For example - a 24,000 BTU Air Conditioner is a 2 ton unit. 24000 divided by 12000 = 2
A 18000 btu air condtioner is a 1 1/2 ton unit 18000 divided by 12000 = 1 1/2
you can find out your btu rating by looking on the tag on your unit.
Jun 07, 2011 | Heating & Cooling
I want to replace a system
Hello
Tons of cooling is in btus.12000 btus is one ton,24000 is 2 tons.
Somewhere on your unit is the cooling capacity in btus,take that number and divide it by 12000.
Usually a 2000 sf house will need 3 to 4 tons of cooling,more is always good.
Im sending a link to do an easy calculation that should be helpful.
http://www.consumerreports.org/cro/appliances/heating-cooling-and-air/air-conditioners/sizing-worksheet/
Jun 01, 2010 | Ruud UBHC Air Conditioner
Central A/C unit
That would be a 2 ton 24000 BTU unit
heatman101
Apr 23, 2010 | Heating & Cooling
Size
Greetings jdreisbaugh,
The tonnage is usually found on the name plate on the condensing unit outside. 12000 btu = 1 ton, 24000 = 2 ton and so forth. In your case the unit is 36000 btu, therefore a 3 ton.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jul 24, 2008 | Intertherm P3RA-036K Air Conditioner
Flower Factory Fright Tape 40' Logo
Top Flower Factory Event Planning & Celebration Experts
DAVE PARTA
Level 1 Expert
gamehouse8888
Level 1 Expert
 steve
steve
Are you a Flower Factory Event Planning and Celebration Expert? Answer questions, earn points and help others
