Parts for EPS-1200X
Need plastic gear for EPS-1200x shredder
JayBlair
  • 328 Answers
SOURCE: need gear
Have you tried EBAY?
Posted on Jul 31, 2007
dlundmark
  • 797 Answers
SOURCE: Fellowes Shredder Parent Part # 38605
If this unit is worth it to you, you can build your own gear.
Here is a link to get plastic repair materials to make plastic parts. This site also will have materials for repairing plastics.
Another possibility is to search Ebay for a unit like yours which has other problems. Never can tell... it may be there.
Make sure you ask for the model of the unit in your search (on the NET as well. The serial in this case is not needed.
Posted on Jul 26, 2008
SOURCE: Questions on Fellowes Shredder Spare Parts
these guys might be able to help http://wheelermachines.com/fellowes_parts.htm
Posted on Aug 07, 2008
t_vinson57
  • 58 Answers
SOURCE: T7CM Fellowes shredder -- internal parts
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
  • 3 Answers
SOURCE: NEED A REPLACEMENT PLASTIC GEAR THAT DRIVES THE UNIT
This Shredder is an Aurora AS650C Rebranded for Walmart as Durabrand. You can call Aurora at 800-327-8508 8-5 PST and tell them that you need one of the plastic gears for the WM6X Durabrand, they know exactly what your talking about, and will offer you two gears. The one that is in contact with the drive motor is gear "A" and the Plastc reduction gear that drives the steel gears is gear "B" Hope this helps
Posted on Jun 04, 2009
Repair of a Staples shredder EPS-1200X
Unplug it from the wall unit. Check to see if there is any tiny piece of paper stuck in the machine, if there is you can use
tweezers to pull the small pieces out. Then you can put it in reverse and let any paper that my be stuck in it come out.
Make sure that there is no paper caught in the teeth at all or it still might not work.
Jun 11, 2017 | Cars & Trucks
My Executive Machines EPS 1200X shredder works in reverse, but does not shred.
there should be a forward/ reverse switch that is used to unjam paper being shredded. check that
if it is automatic then check for paper stuck in the shredder causing the reverse action.
May 12, 2015 | Shredder Office Equipment & Supplies
I need a owners manual for a swan 1200x linear amp
if the following search on google does not supply an answer it isn't available.
swan 1200x linear amp manual
Dec 26, 2014 | Radio Communications
Sportster xl 1200x fuel capacity
1200 Model Fuel Capacities are as follows:
XL1200c and XL1200L = 4.50 gal. 17.03
Jul 12, 2014 | 2010 Harley Davidson XL 1200X Sportster...
Correct tyre pressure chart
Hi Anonymous, factory recomended tire pressure for a 2011 XL 1200X is: front tire 30 lbs. rear tire 36 lbs. solo 40 lbs. double. Good luck
Apr 07, 2014 | 2011 Harley Davidson XL 1200X FortyEight
Executive Machines EPS-1200X Shredder has power but papers are stuck and there is no sound from motor
You will need to clear the jammed paper using tweezers from between the rollers. Make sure the sensor arm in the middle of feed opening is not stuck and moves up and down freely. If not you will need to give it a good soak with lubricant to allow any stuck paper to soften and loosen. Once cleaning procedure done unit will be good as new
Oct 13, 2013 | Staples Executive EPS711X Shredder
Does acer aspire 1200x have wifi?
No, this laptop does not have a WiFi interface.
You can add a USB WiFi interface. If you do, try to seelct one that supports "N", not just "G" or "B".
Oct 06, 2009 | Acer Aspire 1200X Notebook
Service menu proxima x350 , ASK M3 or Yokogawa D-1200X
you should be able to by the menu button on the top of the machine.
Jan 26, 2008 | InFocus Proxima UltraLight X350 Multimedia...
77 people viewed this question
jasbo
jasbo
