Question about Konica Minolta Minolta Bizhub C253 Copier
Error c-3721
What oval blue pill has G3721 W/a scribe on the back ?
G 3721 (Alprazolam 1 mg) Pill imprint G 3721 has been identified as Alprazolam 1 mg. Alprazolam is used in the treatment of anxiety; panic disorder; depression; borderline personality disorder; tinnitus (and more), and belongs to the **** class benzodiazepines.
oval blue pill has G3721 Google Search
Dec 18, 2016 | Health & Beauty
How do I dissemble acer aspire z3730
https://www.youtube.com/watch?v=hzTUF9ds2cw
Nov 07, 2014 | Acer Genuine Power Aspire Timelinex...
How do i get to safe mode ?
When you first power on the laptop repeatedly press f8 until the safe mode menu appears.
Jul 11, 2014 | Dell Inspiron 17-3721
How can i fix error message c-3721 on bizhub c360 machine
If this code come back after this procedure get a new fuser, do NOT reset and Reset dealing with the fuser it can catch on fire that will ruin a perfectly good day
1.
Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
May 07, 2014 | Konica Minolta Office Equipment & Supplies
An error on my c360 konica minolta c-3721
fuser temp too high to reset turn off machine then turn on while holding down the utility/counter button when the trouble reset button comes up on the touch screen touch it and make sure it says ok then turn the machine off wait 10 seconds and turn back on if error code comes back fuser unit will have to be replaced
Dec 11, 2012 | Konica Minolta Bizhub c203 Copier
C-3721 error is displaying. How can I fix it?
Fusing abnormally high temperature detection (heating side)
Check the fusing unit for correct installation
Check the fusing unit, PRCB and DCPU for proper connection and correct or change as necessary.
Change fusing unit
Change PRCB
Change DCPU
Jun 28, 2011 | Konica Minolta Bizhub c203 Copier
When quoting that error message, Konica told us the machine was disabled remotely by them.
Nov 16, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Trouble code c-3721 on konika minolta multi functional printer
was told this message meant Konica have disabled the machine remotely.
May 13, 2010 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Minolta Bizhub C253 Copier Logo
14 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
