Question about Office Depot Ativa D5772 Phone
How to change ink ribbon on ativa p4000 calculator
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
HOW DO I CHANGE THE INK IN THIS OLD CALCULATOR? THE RED IS COMPLETELY GONE AND THE BLACK IS VERY LIGHT
What model is the calculator and if it's a inker type then you have to replace the ink roller. If it's the ribbon type then you have you replace the ribbon. You can pick those inker or ribbon from Edmonton Cash Register Co. Ltd. or send us a email to order
Apr 10, 2015 | Casio HR 100TM Portable Printing...
Can you change the ribbon
Yes you can. That type of calculator has two separate ink rollers, one black & one red. They are easy to remove by putting your finger around the little ink roller & sliding it out towards you, the new one will lightly click into place. You can buy the sharp brand of ink rollers or a generic brand that will fit your calculator.
Jan 25, 2011 | Sharp EL-1701C Calculator
How do I change the ink roll?
How do I change the ink roll on my Ativa ATP1,000 calculator
Dec 20, 2010 | Canon P100-DHII Calculator
How do i change the ink cartridge
No ink cartridge - the ink is on the ribbon. Replace the ribbon if out of ink.
Dec 14, 2010 | Sharp EL-1801P Calculator
HOW DO YOU SET DATE AND TIME ON ATIVA AT-P4000 CALCULATOR
instructions are here
http://www.ativaproducts.com/downloads/577-813_faqs.pdf
Aug 12, 2009 | Office Depot Ativa D5772 Phone
Printing is very faint. How to change or add ink printer device.
This is most likely a ribbon impact system. Any office supply store should have the ribbon you need, with information on compaitability on the package.
Remove the paper roll and gently but firmly pry on the bezel surrounding the paper exit path. Examine the sides of the ribbon casing for any clips or fasteners.
May 22, 2009 | Victor 1280-5 Calculator
Don't know how to change the ink?
How do I change my ribbon on a CASIO FR - 2650 PLUS
May 15, 2009 | Casio FR-2650Plus Calculator
Canon Calculator; P28-D
Hi there, there are a couple possibilities. First, Remove the cover where the paper feeds out, if there is a ribbon or an ink roller in there it will need replacing. This you can get a staples. The other possibility is, if there is no ribbon or ink roll, it is probably a thermal printer which means is uses a special heat sensitive paper. If this started when you changed the paper, this is most likely the problem. This you can also get at staples!
Jun 19, 2007 | Canon BP120 DH Calculator
Office Depot Ativa D5772 Phone Logo
32 people viewed this question
Top Office Depot Lands Phones Experts
ashburton
k24674
Zelio Picanso
Are you an Office Depot Lands Phone Expert? Answer questions, earn points and help others
