Question about Refrigerators
I have old coronado chest freezer is cold setting all the way right or left
dididsaythat
  • 291 Answers
SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
Posted on Sep 20, 2007
SOURCE: new chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
Posted on Aug 24, 2008
woodchuck789
  • 4070 Answers
SOURCE: Hotpoint Freezer Chest
Is the compressor motor running. It's around back underneath behind the cardboard cover. If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Jul 11, 2009
  • 389 Answers
SOURCE: Kenmore chest freezer model 12235 - won't get cold
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
  • 1218 Answers
SOURCE: chest freezer model mfco5mobw4 been plugg in for 2
God day,
Either the refrigerant has leaked out or the compressor isn't pumping properly. If you can put your ear up to the unit and it hums that is the compressor running.
No practical repair possible unless the unit is under 5 years of age in which case you are entitled to factory warranty service.
Posted on Apr 30, 2010
Have a second hand Homemaker chest freezer model hmbd155....recently noticed fluid around the floor....? Leaking..don't have a manual and noticed a dial on the bottom left hand corner .What this do..?
The dial Adjusts the temperature. If it is adjusted too cold you might have ice build up underneath the freezer thus causing the fluid that you see. As the freezer is old it can also be that the insulation underneath is a bit old causing the ice build up and fluid leakage. A broken thermostat (dial) will also cause too low temperature inside and possible ice build/fluid leakage.
Oct 04, 2017 | Refrigerators
I have 2 big old chest freezers--Kenmore 122 and Coronado 193. The doors on both of them will not stay open whenever I put in/take out items. I assume it is in the hinges but how do I fix them?
These models have a spring built into the hinges. You can remove a hinge and take the spring out and try a local hardware store or online @ Graingers
Because replacement parts are hard to find for these I have seen folks us the hydraulic hatchback shocks to assist in opening the lids and holding them open. Other have just made a prop rod similar to a car hood support.
Sorry I couldn't give you a direct link to replacement parts, But I tried my best to find these springs.
Best of luck!
Oct 11, 2013 | Freezers
Fast freeze light on all the time is this right new belling 100 ltr chest freezer
No check your settings. You may try to unplug it for about a minute and then restart. If that doesn't work, call the mfr. they should help since it is new.
Feb 02, 2013 | Magic Chef Chest Freezer MCCF5WBX
Used Kenmore freezer won't get cold enough
If it is running but not cooling enough the problem is in the sealed system.
If you started it up just after hauling it home it may have be moved around enough to get oil in the systems smaller tubing causing problems. Unplug the unit for 24 hours and let it sit. Try it again for 24 hours and see if it cools.
If not this means either there is a refrigerant (freon) leak in the system or a restriction causing the refrigerant to not flow properly.
Either one are an expensive repair. and will require a professional to look at.
May 09, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Temperature
If this unit has a control it would be located on the outer left side in the lower right hand corner. There would be a dial, the higher the number the cooler the temperature. Many of these chest freezers did not have an adjustable control.
Apr 13, 2010 | Kenmore 15 cu. ft. Chest Freezer 16542
Old Kelvinator Cyclic 340. Freezer is Ice cold
Read the below :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 16, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Will not quite get to freezing.
check warranty quick
Oct 09, 2009 | Freezers
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Refrigerators Logo
128 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
