Question about HP DeskJet F380 All-In-One Printer
My printer wont turn on even the power supply adaptor is ok
  • Anonymous Apr 10, 2009
    It just wont turn on
Check ur usb port
Posted on Jan 27, 2009
  • pasijukka
    pasijukka Feb 12, 2013
    what do yo mean? Check your USB port? How to check it?
Officejet pro 8500a premium power light on but touch screen is off and will not respond and the power button will not respond either
hi, Mr Justin Becker
i think its a power supply problem, first you should try another dc adaptor, if your printer works fine with the new one, you have to replace it or take it for repair.
if it is a DC Adaptor problem it cost about: US $29.74
HP OfficeJet Pro 8500 AIO GSA printer power supply ac adapter cord...
Mar 06, 2014 | HP Office Equipment & Supplies
Acer aspire one won't turn on
Try another Wall Power Supply. To test. Take Out battery, Plug In wall supply to Wall & PC, without battery does it work OK? IF YES, replace battery still OK? Laptop Should work on Wall ONLY, if not, replace wall unit.
Apr 28, 2010 | Acer Aspire One PC Notebook
PRINTER WONT TURN ON...PLUGGED IN...CHECKED CONNNECTIONS ..OK...NO POWER
Is the printer connected to a power bar?
If YES, kindly remove it from there then directly plug-in the printer's power cable to the walloutlet
you can also try other walloutlets
If still not working, then it's time to replace the printer's power supply or the adaptor or the printer itself.
Feb 26, 2010 | Lexmark Office Equipment & Supplies
Printer does not turn on
Please folow these steps :-
1.disconnect the [power cable from the back of the printer
2.press and hold the power button for 20-30 seconds
3.reconnect the power cable back to the printer
4.check whether the adaptor has a green light on it or not or is it warming up
5.if the green light is not on try in a different wall outlet
6.if still it does not work then buy a new adaptor it should work or even if the adaptor does not warm up replace the adaptor
it should work
thank you
HAMID
Dec 24, 2009 | HP PSC 2355 All-In-One InkJet Printer
My officejet7210 all-in-one, not working . i shut it off to checjk all connections, i had to to move the printer, now it wont turn on. I've pushed the on button quickly, held it. no go. any ideas?
hi, lets try some reset on the printer but before that make sure that the printer is directly connected to the wall socket and there is no power surge protector connected now place your hand on the the power adaptor of the printer and check if the adaptor is heating or not if its heating then proceed further if not then there is some problem with the adaptor
now connect the power adaptor to the printer and then try turn on the printer if its not turning on then press and hold the power button for 10 sec and then remove the power cable from the printer now keep pressing teh power button and after 10 sec reinsert the power cable and then release the power button
still if the printer is not powering on then press the # and 3 button on the printer and then while pressing them remove the power button wait for 5 sec and then replug the cable while pressing the buttons
now try to power on the printer if not powering on still then try the above step using the # and 6 buttons if till face the problem then the device needs service
Aug 29, 2009 | HP Officejet 7210 All-In-One InkJet...
Clear paper jam error
just unplug and plug the power supply adaptor or the cord of your printer ...
Aug 17, 2009 | Dell V305w All-In-One R840635AU InkJet...
Printer wont turn on even the power supply is ok.
first open your printer and check the if the fuse in power pack is ok, the if is ok then check the wires if there ok the as for new printer mother board ok
Michael
Jan 27, 2009 | HP DeskJet F380 All-In-One Printer
Compaq Presario 700 Series Laptop wont turn on
Please first make sure that your adaptor is working.
Try to remove the battery and connect your laptop to the adaptor. Swith on. If nothing chages, then there is good chance that you have a motherboard related problem.
Nov 23, 2008 | Compaq Presario 700 470024-192 Notebook
Hp 2355 all in one printer
Can you turn on the printer normally? If you can't then you have a faulty power adaptor. If you can then it sounds like the connection between the computer and printer has been lost. Disconnect the printer and reconnect to another USB port. If this works then fine, if not then try another device in the same usb port to check wither the usb port is functioning. If it does, you have a faulty printer. You might be able to clear any probelms in the printer by performing a full reset.
Ppower up the printer and discconect the power supply while the printer is running. Hold the OK and Cancel buttons while reconnecting the power supply. When the printer switches off after 10-20 seconds, release the buttons, unplug the power and reinsert it. Turn on the printer and reun through the processes before plugging inth e USB. If it is still faulty, throw it away!!
Let me know what happens
Jun 01, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
111 people viewed this question
Ben Johnson
