Question about RCA P52960 52" Rear Projection Television
Picture in concave on all sides and blue and red are off
Made a popping noise, shut off and on , and now the picture is blurry and the sides of the picture are concave and the red is off set to the blue. When looking at numbers the red shadows the blue. six years old was wondering if it is worth fixing. Model no. P52937
  • jk_pettit Jan 29, 2009
    Yes I have a soldering gun and am capable if you can send the informatiom required to repair it.
  • 4,234 Answers
The shape of the picture indicates that the convergence circuit is not working properly. Generally speaking this occurs without making any sound at all. The popping you heard may have been a capacitor in the power supply. If the power line effected supplied the convergence circuit, repairing the supply should return the set to normal. If not, then the convergence ICs may be faulty. If you can solder, and are confortable working inside the set where potentially dangerous high voltages exist (even when unplugged), you may be able to repeir this yourself.
Let me know and I'll provide additional details and instructions.
Dan
Posted on Jan 27, 2009
Three pictures red green & blue and it looks concave
Install the Sony type 1 convergence repair kit available from www.tvrepairworld.com the kit includes the components and the cd with instructions.
Jun 30, 2010 | Sony KP-51HW40 51" Rear Projection...
LEFT SIDE OF PICTURE IS BLURRY AND COLORS DISTORTED
Does that set have whats called a color wheel, if so that maybe you problem, and replacement is how you fix it.
Apr 30, 2010 | Toshiba TP43H95 43" Rear Projection...
Lots of Blue shadows off to side. concaved picture almost
HI, this is a failed convergence chip that is located on the convergence board. it will need to be replace ASAP. you can just replace the chip or , you can order a new board.
Replacing the chip can be a rough job if you don't have tech experience. if you are a fluid tech and you can solder and know your way around a circuit board, just replacing the chip will cost less. if you are not an experienced TV tech, i recommend a service call to the nearest TV tech to replace the convergence board.
May 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Screen lookes like colores separating
This is what is known as convergence. a projection tube ussally has three picture tubes.. red green blue. they all have to align. the concave picture indicates complete loss of convergence or convegence power supply. First question on these sets Do you have the convergence option in the customer menu under setup. if you do not this is a indication of the common "FL231 fuse problem" and inexpensive simple repair. I have wrote and artilcle on this under my tips and trick section. If you do have the option then next does autoconvergence work. in you case i would not think it work. under blue and red manual convergence does the crosshairs move. if not then this is indication of convergence power supply board. if they move at all this may indicate a convergence amplifer problem.
Sep 10, 2008 | RCA HD52W56 52" Rear Projection HDTV
Everything on the screen has a blue shadow
need to change both convergence ICs STK392-560. you can get replacements at the following link with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Jun 30, 2008 | Sony KP-46WT500 46" Rear Projection...
Covergence problem
your set has indications of several problems. red green and blue. indcate convegence issue. the fact that the picture is concave is a indication of totall loss of covergence power supply. the convegence menu missing idicate loss of some voltages from what know as the flyback.AND SHUTDOWN. indicate further problems. generally when convergence fails ..not always the set wont shut down. it could be a simple issue but further trobleshooting would have to occur to narrow it down.
Feb 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
Rca d61w20 dominate red & blue screen also very blurry picture
Red and blue present, but no green = bad green CRT is
best guess.Remove lower front panel = adjust screen and focus
controls for best pix..................T.
Oct 30, 2007 | RCA P52926 52" Rear Projection Television
RCA P52960 52" Rear Projection Television Logo
133 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
