Question about Dryers
Access motor 1.does back or top comme off ?
    Scholar:
  • 42 Answers
Your dryer and motor can accessed a couple different ways depending on the make and model:
1. Can be the Top (remove 2 screws near filter-pull) can slide a putty knife and screw driver and pop the top off.
2. Also, the Door must be taken off to access the motor (Screws on inside of door)
3. Bottom - panel comes off by sliding a putty knife or screw driver and dis-engaging.
After intially opening the dryer cabinet; you will most likely need to remove the front door by removing 2 screws located at the inside top corners (1/4'). ** Be sure to turn off power to unit before opening and servicing.
Whats the problem? Humming noise? Not tumbling/turning? How old? What make?
Posted on Jan 27, 2009
Oil Leak on sprinter engine by starter
could be your freeze plug or u have a leak commeing from the top of your engine seal gasket .first jack it up use a dirty cloth and clean up all the access oil around it and on top then turn it on and see where exactly where its comeing from ,get back to me i owned 1 before
Jan 15, 2013 | Mercedes-Benz Sprinter Cars & Trucks
Tip
Add 802.11g (Wireless G) network access
Google a program called total commander. download and install it on your phone.
Now open total commander. Listed on the very top of the folders list will be \\
-Click on \\
-then click registry (you are now in the devices registry, be careful not to change other things)
- select hklm (this stands for Hkey local machine)
you need to go to this location
HKEY_LOCAL_MACHINE\COMM\TNETWLN1\PARMS
(so you would choose comm, then scroll down to tnetwln1, then select that and scroll down to parms and select parms)
then assign the follow changes to the keys listed in PARMS...
Assign a value of 1 to dot11SupportedRateMask
Assign a value of 8 to dot11SupportedRateMaskG
Perform a soft reset (do this by holding the power button for roughly 6 seconds, until a box comes up asking you if you want to shut off the device. Turn it off, then turn it back on and the changes will go into effect)
Then simply try to log on your router
Peter
on Oct 02, 2007 | T-Mobile MDA
Tip
-Click on \\
Peter
on Oct 02, 2007 | Dopod 838 Smartphone
I was ripping some 2x4s on my Jet 10" contractor table saw and the motor started lugging and the wood started burning. I removed the motor because the tool place in town said it might be clogged with...
How freely does the motor turn without the blade on it??? Also what does that blade look like, are the teeth worn or broken? As for the motor usually there are vent holes in it and I would just try and use compressed air to clean as best asa possible. If the motor does not spin freely it could be dirt or possibly bearings. Let me know
Aug 12, 2011 | Jet 708662PK/JTAS - 10XL30 - 1 with 30...
SIR I WANT TO OPEN THE SIM LOCK OF HAIER HC-C2076 TO USE OTHER OPERATES SIM
unlock-c2076mv03c
but vahi unlock hoga jo *#0000# karne par version show kar
Selected Model...C2076
Asking Server Access Take Few Seconds...
Successed to connect server
User name...xxxxxxxxxxxxxx
Searching Phone Please Wait :
Your Phone Version:= Dec 09 200914:17:22May 06 200807:00:00SCNGZ355*
Found Inside Version = QSC6010-SCNGZ-3550®?~
Phone Is In Boot Mode.
Prepairing Phone For Opration.
Phone Ready To Unlock..
DATE CONFIRM HC2076MT03C...
SEARCHING INTERNAL VERSION...
Found...HA2076MV03C
SEARCHING LOCKS...
LOCKS DISABLED...
Haier C2076 Unlocking Finish Restarted Phone...
error 0 in comm
error 1 in comm
error 2 in comm
error 3 in comm
Total Time Take...00:00:34
Log Saved To...C:\Advance Cdma\C2076log_5_1_2010_3_08_49 PM.txt
HOPE THIS WOULD BE HELP FULL .
PLEASE DO RATE ME.
HAPPY NEW YEAR
THANK YOU
Jan 01, 2011 | Alcatel Virgin Mobile ?£30 Text Cellular...
Tip
-Click on \\
Peter
on Oct 02, 2007 | i-mate K-jam Smartphone
Tip
-Click on \\
Peter
on Oct 02, 2007 | Cingular Wireless 8125 Smartphone
I have error codes flashing on my thermostat..it is an american standard model the manual for the therm. has ACOT900AC43UA on front..says to find addedum 18-HD32D2-1/69-2009 for codes i cannot find it...
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
Aug 22, 2010 | American Standard Heating & Cooling
My honda sel sol roof wont shut
try another sunroof button if that doesnt work. Ive had 2 go out on 2 crxes
Jan 13, 2010 | 1995 Honda Civic del sol
Dryers Logo
101 people viewed this question
Top Dryers Experts
