Question about HP Pavilion Computers & Internet
OxE0000203 showing in device manager on wi-max
Turn wireless switch
Only two models came with Wi-FI
5316-1BU and
5316-1CU
Here is the datasheet
Her http://shop.lenovo.com/ISS_Static/WW/AG/merchandising/US/PDFs/kseries_techspecs_110909.pdf
Go to Control Panel, then Device Manager, it will show you if you have Wi-Fi or not and if is enabled. If it is disabled, enable it here.
You can also buy a USB Wi-Fi adapter compatible with Windows 7 Operating system.
May 24, 2014 | Lenovo IdeaCentre Computers & Internet
Hi, I have acer aspire 5738. I installed wi-fi
Just search and download cobra driver pack, it will scan and update your driver to a correct working one.
Aug 09, 2013 | Acer Aspire 5500 5570-2609 Laptop
Wi fi card remove computer startworking
Remove and reinstall driver...possibly replace Wi-Fi card. Are there 2 Wi-Fi cards? Go to device manager (Windows?) and see if it thinks your card is working or not. Yellow ! means it has a problem. And that's where you uninstall it. Reboot and see if that helps.
Aug 23, 2012 | MSI 185 Allinone Barebone Bb A912001BUS...
Hoe zet ik wifi uit op ibm thinkpad R52
RIGHT CLICK ON MY COMPUTER Klik rechts op MIJN COMPUTER
CLICK ON MANAGE Klik op Manage
GOTO DEVICE MANAGER GOTO DEVICE MANAGER
SELECT NETWORK ADOPTERS THEN WI-FI SELECT NETWORK adopters DAN WI-FI
RIGHT CLICK ON WI-FI THEN CHOOSE DISABLE Klik rechts op WI-FI en kies UITSCHAKELEN
AND FOR ENABLING AGAIN DO THE SAME EN voor het inschakelen van OPNIEUW
hetzelfde doen
THAT'S IT THAT'S IT
PCCLINIC INDIA
Aug 10, 2011 | IBM ThinkPad R52 Notebook
Problem with on or two network adapter
First make sure that wi fi switch of your laptop is turn on.
Then check that wi fi netowkr adapter driver is installed perfect and enable.
Go to device manager and enable wi fi adapter.
For check device manager right click on my computer icon then click on property then hardware ->device manager.
Then you see all driver list.
Then enable wi fi .
Also right click on my computer places icon then go to proeprty then you can see your network adapter right click on wi fi adapter then click on "view available wi fi networks."
then connect your wi fi .
Let me know if you need more assistance.Thanks.
Oct 01, 2009 | Acer Aspire 4720 Notebook
Hardware manager shows the device as working correctly but cannot locate any wireless network. Is this a PCI card or internal? Known good wireless routerr right next to the notebook
First check your wi fi network drivers are installd and enabled .
Then turn on wi fi switch on laptop.
then also check on your router wireless is enabled.
then check.
Aug 21, 2009 | Computers & Internet
Wi fi driver
easy way is to run a cat 5 cable to your router and go to device manager and tell it to update your wireless drivers other option is to go to another computer download the drivers onto removable storage device and then install drivers from device manager.
right click on "my computer" select select properties
device manager find your device right click and update
drivers follow prompts
Apr 23, 2009 | Computers & Internet
Is there a wi-fi swtich on thinkpad r52?
IBM load there own set of software on there notebooks which take care of networking lan and wi-fi, I have found if try to use the windows native wireless checker it does not pick the networks up. Try using the IBM program either in the taskbar near the clock or in the start menu.
Also in Device Manager does the wi-fi device show up.
There also may be a light that indicates wi-fi is on on at the front or or above the keyboard if its off let me know.
Other possibility is to uninstall the driver for the wireless device restart and let it reinstall automatically.
Mar 18, 2009 | IBM ThinkPad R52 Notebook
No Wireless Connection
Let’s check the Wi-Fi card on your PC. Go to "Device Manager" and look if any yellow or red alerts are being displayed under the Network Adaptors. If not, make sure the Wi-Fi card shows up under Network Adaptors. To access the "Device Manager" go to the 'Control Panel", "Administrative Tools", "Computer Management" and select "Device Manager" located in the left side column.
If there is an alert, double click on that device to determine the problem, i.e.… device not configured, cannot start this device, etc…
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 27, 2008 | Dell Inspiron B130 Notebook
Computers & Internet Logo
42 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
