Question about Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP 4663
I also have had a problme with the Samsung. When I turn the set on, the picture stays black, the sound comes on, and first the "lamp" light flashes on and off. This progresses to all three - "lamp, Standby, and Timer" flashing. I have tried to replace the lamp with no change. I then purchased a new ballst which also was easy to change out. I still have the same problem. I still don't feel that I am any closer to having a working TV. HELP!
  • 5 more comments
  • Tyler2 Nov 04, 2007
    I am having a problem with my 4663. When I power on the TV, the fan comes on, but I get no picture. I have to power on the TV several times to finally get it to show a picture (takes 20 or more minutes). I have noticed a blue colored electrical short under the projection lamp case on the circuit board, and you can hear the electric arcing when I see the glow. Not a big short where it could melt something, but one nonetheless. The short will last about 2 to 3 seconds and then go away. Any assistance would be appreciated.
  • nlee Dec 06, 2007
    I have the same problem in my Samsung HLP 4663, it is nightmare, I told myself that never buy any Samsung TV again.
  • ram40ut Oct 04, 2008
    I changed the bulb. It worked fine then shut off. I get all different combos of flashing lights. I took the panel off and put a fan back there. It work fine for about 6 hours. The next it powered up fine but only worked for 10 minutes.
    I was told that if the picture comes on nice and bright for merely a fews seconds it's not the lamp or ballast.
    My color wheel is not making noise and the picture seems to be fine.
    When I go through the steps to get data on usage it never works.
    1. menu
    2. 1-8-2
    3. power
    this will not work
    I'm getting ready to throw a brick right through this mother scratcher
  • mnerenbaum Dec 10, 2008
    I have the same problem on my HLP5063W and I have not replaced anything yet. Did anyone ever correct this type issue?
    Sound, no picture, lamp LED blinks for 30 sec and then TV reboots. This happens 3 times and then all three LEDs blink, which apparently indicate a defective lamp. However, I'm not so convinced. Prior to last night, the lamp was working intermittently. A couple days ago, I removed the lamp housing and examined the lamp....it looks fine.
  • Anonymous Dec 10, 2008
    I have the exact same problem with my Samsung...by the way this is the second issue in 3 years. I had to have the color wheel replaced about 18 months ago. I did all the usual stuff like change the bulb and clean the fan, but that did not fix the problem. I bought the extended warranty so I called and they came out. They could not fix the problem on site (even though I pay for that) and had to take it to their shop. Their diagnosis is that I need a new light engine. The warranty company has to approve such a repair and I am told that will take about a week and then another week to get the part and make the repair....so about 18 days from their original visit to my house to get my working TV back. This is the last Samsung product that I will buy. The picture is GREAT when the TV works but it has been a major pain since I bought it. I am on my third bulb, replaced the color wheel, and now the light engine...never again with DLP and especially Samsung DLP.
  • kvnn Dec 23, 2008
    I have exactly the same problem for about over a year, now my TV HL-P4663W died completely. No more SamSung. SamSung should repair for all buyers, this is not one or two TV, it looks like this is a serious defected model from manufacture. My brother bought a Sony TV, the color went wrong, Sony repair for FREE! Why don't anybody submits an request, with everybody signs on this, to SamSung to see what can they do for us?
  • Anonymous Jan 20, 2009
    I have the HL-P4663W and replaced the color wheel. I removed the jumper and it worded great with a good picture. Three days later it shuts off...three lights blinking and now it will not ture on. I replaced the lamp, still no good....
    Can anybody help?
    Scholar:
  • 73 Answers
Skippy is right, you should check the color wheel. There are only two moving parts in the set and the color wheel is one of them. If you listen closely to the TV you may hear a high pitched whirr or whine. If so, you've got a bad color wheel motor. If you are mechanically inclined, take the back off and remove the lamp vent. Take off the screws and cables holding the optical block tray and slide the tray out. The lamp points directly at the color wheel. There is a metal heat sink held in place by two silver screws over the compartment infront of the lamp. Using latex gloves, remove those and the whole color wheel assembly will come out. Of course this process isn't as simple as I've stated it but with some common sense you'll be fine. When replacing the wheel pay attention to the model number. Some of these sets use a bearing setup and others an air cushion one. Make sure you order the right part. If you do order the wrong one, not all is lost, you can (with a jumper) modify it to work. Make sure your gloves are clean and re-install the color wheel, and reverse your dismantle. Good luck!
Posted on Dec 11, 2008
  • Axle80
    Axle80 Dec 11, 2008
    by the way, I see a lot of broken Samsungs, don't feel singled out. Of all the tv's I've repaired over the years, samsung seems to be the brand I constantly have in my shop. But it is also the most service friendly. They can be fixed easily. Keep in mind that almost all brands of TV's use philips and samsung parts, boards, etc. So changing brands may not be your ultimate solution. Sony on the other hand is the brand I see the least. But when they die, they are DEAD. Fixing sony is often a nightmare. Moral of the story, 6 of one half dozen of the other. Pick your battle wisely.
  • 143 Answers
Color whele is bad
Posted on Nov 30, 2007
SOURCE:
My model hlp 4674 wx/xaa sceen won"t do anything
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
Samsung HLP 4663w dlp-hdtv replaced lamp and ballast, still not working. lamp/standbytemp and timer all flashing. i get no clicking on ballast, upon power up all i hear is low fan or vibration sound which...
If the capacitor on the ballast was puffed up or blown up you have to replace the lamp, ballast & SMPS at the same time. But if the ballast is not trying to fire the lamp it sounds like the color wheel is not coming up to speed. If this is the case, the set will not turn on.
Sep 22, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP Model HLP 4663 WX Constant Whining
What you're hearing is the most likely the color wheel if you remove the lamp you can see part of it ...a multicolored plastic disk.It rotates on a high speed motor and make an awful whining noise when it fails.
Rustym62
Apr 30, 2009 | Samsung HLN5065W 50" Rear Projection...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Replacement of bulb for my HLP 5674 WX/XAA
sounds like your lamp is needing to be replaced. www.alltvlamps.com will have the lamp for your set just enter the model number of your Tv to locate it.
May 20, 2008 | Samsung HCN473W 47" Rear Projection...
Turning On Problem
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Feb 06, 2008 | Samsung HLN467W 46" Rear Projection HDTV
No picture and no sound
simply unplugging the TV and turning it back on if started to work.
if it doesn't then the Trying a new lamp first is reccommended.
After all, you will need another lamp eventually.
Samsung Parts
http://www.samsungparts.com/
model HLM507W as two different lamp replacement part. the LAMP for my TV was BP960224A. the replacement lamp listed on the Samsung site is BP960224C which was replaced by BP960224J. the difference according to my supplier is that A part has a brown power coupling and the J part has a black power coupling. hope this helps someone in the future. The couplings are different and a black LAMP coupling will not fit a brown TV coupling.
Replacement is simple, getting the right bulb is tougher. Make sure the TV is unplugged and the lamp has cooled. Looking at the TV from the back there is a lamp cover on the lower right. Remove the single screw, remove the door. There are two screws holding the lamp in, loosen these. Then flip the black plastic handle up at the bottom of the lamp assembly and pull the lamp assembly out.
Note the brand of the buld and the color of the connector (black or brown) and then call to order your parts from Samsung's parts reseller
With set off...mute + 1 + 8 + 2 + power.
Arrow down to "Options" push enter.
Lamp reset and lamp hours should be in there.
Power off 2 minutes or until fan kicks off to exit.
BP96-00224C LAMP ASSY./ PHILLIPS 40''-50'' $199.99
Jan 28, 2008 | Samsung HLM507W 50" Rear Projection HDTV
Samsung 46" DLP
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
No sound or picture
Sep 29, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Sumsung HLP 4663W
Might be a bad ballast, has the picture been dark?
Jun 21, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
966 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
