Question about Dacor Preference SGM466 Gas Cooktop
Kenmore gas stove top switch harness replacement instructions
I need instructions on how to replace the switch harness for a 30 inch kenmore stove top.. model number 911. 322 191 00 Serial number 1m702916q Also two of the 4 burners will not turn.. at the present I have to light the gas top with a lighter and can only use two.. thank you
  • pacificrefle Jan 28, 2009
    thnak you but how excatly step by step do I replace the switch harness.... not sure from top bottom remove glass piece by knobs.. how .. thanks .. for you time aloha
    Novelist:
  • 222 Answers
For the 4 burner if u not use coz of no igniter,use matches or lighter every time to use,if not turn the burner remove the knob & try to use hammer slowly at the top of the gas valve mostly the problem is stockcup,use oil b4 u try to turn.for the harness wire call the contact service center to buy a harness wire to replace the parts,but it so easily to replace the wire try to open the unit to see the wire size,color then gi to hardware to buy a wire same as in ur unit.tnx gerbee
Posted on Jan 27, 2009
  • gerbee gomez Feb 01, 2009
    to replace the harness wire 1st thing 2 do,unscrew all the screw u see at the top of ur unit,to remove the stainless cover then u can see the actual part u need to replace. carefully unscrew all the screw coz sometimes it will be broken or loss tread,if u see the wire check if there is any damage b4 u replace,if wire is burn replace it make sure the unit is unplug.tnx
I have ge jgp337 . My gas stove started ingniting without turning the burners on and all flame started coming out from all 4 burners. i switched off the electric switch now even after 2...
I've seen this problem before. It happens when spillage get's into the ignitor switches. The switches are mounted on top of the gas turn-on valves. You have to replace all the ignitor switches because they are connected into wire harness. Rich
Aug 15, 2010 | GE 30 in. JGP337 Gas Cooktop
What causes gas igniter to keep clicking when gas is off
Just solved this on the Kenmore model 911.33389 (same unit). Ignitors started with no one touching the cooktop. It has had a history of doing this and, this time, sparks were visible under the knob. Disassembled cooktop (don't forget to unplug and shut off the gas!). Performed "smell test" for burned electronics. Found smell in #3 ignitor switch. Disassembled and found worn, burned, and fried. Parts list was inside unit but had a typo for the "ignitor switch". Showed WB18T10240. Ordered that only to discover it was the transformer to ignitor wire harness set (no photo on website!). Wrong part... ugh! Dug deeper for the correct part #. It was WB18T10239 but it has been replaced with WB18T10344. Noted on some website that someone installed one and then the ignitor was NOT synchronized. Turns out, you can install WB18T10344 about three different ways. Mine was 22 degrees off vertical (different than original) and now my unit works perfectly! Also, install the new switch harness (if that's what you do) starting from the left front valve then clockwise. The original unit installed from the right front valve, then clockwise. Hope this helps.
Jun 20, 2010 | GE Profile JGP636 Gas Cooktop
All 5 ignitors constantly spark
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Feb 26, 2010 | GE 30 in. Profile JGP933 Gas Cooktop
THE IGNITERS WILL GO OFF WHILE THE BURNERS ARE ON COOKING. IS THIS SAFE AND HOW CAN IF FIX THIS PROBLEM? I HAVE KENMORE GAS COOKTOP MODEL# 91132229100
It is not dangerous, but very annoying. Most likely you need a new spark switch. Or simply unplug it for 24 hours and see if it dries out. Usually people spill stuff on them.
kenmore stove repair in orange county, ca
appliance repair orange county, ca
Feb 08, 2010 | Kenmore 30 in. 33202 / 33204 / 33209 Gas...
Safely remove knobs from 50's Kenmore gas stove
The safest thing to do would be to turn off the power ( un-plug it or turn off the breaker) or the gas or both to the unit. Turning off the power would probably be easier. There should be a gas shut off valve behind it.
Jan 07, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Purchased 30 inch induction cooktop stove to
its ok to cut the laminate using the wood saw to fix the new one.be careful to cut the laminate.
Sep 09, 2009 | Cooktops
All 4 ignators are spaking with the contrtols on off position on my GE JGP328 cook top
It's the Switch Harness. Do not remove the stove and disconnect it from the gas. Turn the gas off under the stove. Take off the: knobs and the plate; burners; hxw screws. Pull burners out and disconnect igniter burners. Lift the top of the oven off. The Switch Harness is on the right, under where the knobs are located. Replace the Switch Harnes.
Mar 30, 2009 | GE 30 in. JGP328 Gas Cooktop
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Dacor Preference SGM466 Gas Cooktop Logo
597 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Mike
Mike
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
