Question about Nautilus T914 Commercial Series Treadmill
Configure nautilus t914 treadmill - Nautilus T914 Commercial Series Treadmill
Can I find service in Europe
Customer Care Number: +1-800-628-8458, +1-800-605-3369
See More Detail Email Address: csnls@nautilus.com
Contact Person:
Address: 17750 Southeast 6th Way Vancouver, Washington 98683, United States
Website: www.nautilusinc.com
Contact Nautilus Inc
Nov 02, 2015 | Nautilus T914 Commercial Series Treadmill
I have a nautilus T914 commercial treadmill. What kind of receptacle do I plug it into? The motor is 230 volts.
Depends on which plug blade is horizontal and which is vertical.
You know that on a standard 2-blade plug, one blade is wider than the other. The wider one is the common and the narrower one is the hot wire. If the hot wire blade is the one turned sideways, then the treadmill is a 20 amp 220v appliance. If its the common blade that's turned flat or sideways (the wider one), then it's a 20 amp 125v appliance.
The fact that the motor is rated at 230 volts doesn't mean much in this case. The motor is a DC motor and the electronics may provide varying voltages for it for different running speeds. The motor likely may also run on pulsed DC.
Sep 13, 2014 | Nautilus T914 Commercial Series Treadmill
How can I get the console to work?
Heat sensor on motor is shorted out. Will have to replace thermistor or whole relay assy on motor sounds like. Not hard to do.
Jun 01, 2014 | Nautilus T914 Commercial Treadmill
Will not power up and the outlet is fine
A few things to check....wiring harness, power switch, controller
Jan 03, 2014 | Nautilus T914 Commercial Series Treadmill
Calibrate nautilus T914
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step. The Calibration seq
God bless you
May 22, 2013 | Nautilus T914 Commercial Series Treadmill
System overload
Step 1:
see the video and lube the rollers bearings too
Step 2:
test the input voltage motor, if there are the motor need repair
see the diagram attached.
Step 3:
test the output voltage board, for input voltage motor, if there are NOT the board is faulty,replace
see the block diagram
Jan 09, 2013 | Nautilus T914 Commercial Series Treadmill
Drv reset 1
Adjust the speed sensor, clean it, and tight the connector very well.
After RUN the software calibration, under the HOOD, see the instruction, for diagnose, troubleshooting, and fix it.
See if there are voltage input motor, if there are the motor Need repair. Test the output voltage board if there are NOT the board is faulyt. see the block diagram.
God bless you
Sep 02, 2012 | Nautilus T914 Commercial Series Treadmill
I have a Nautilus commercial series T914 and my key pad and quick mode is not working?
1) change the batteries, and clean the contacts batteries very well
2) Tight the ribbon cable +connectors wires
3) adjust the reed switch, clean and tight the connector, see the diagram attached.
God bless you
Jun 22, 2012 | Exercise & Fitness
T914 "drive motor error 2"
1)VSD(variable speed drive) MICROPROCESSOR eprom/sram failure: Exchange VSD board.
2) Belt speed pickup,failure in the speed pickug, to due motor, wiring or controller board.
sincerely.
E.CUADRA
Sep 12, 2011 | Nautilus Tc 916 Treadmill Vsd Board
Nautilus T914 Commercial Series Treadmill Logo
20 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
