Question about Kenwood KDC-MP228 CD Player
Cd player plays, but no sound comes out of speakers.
I hooked up subs and amp in my truck. I ran the remote wire to the battery to test them and they worked fine. I then tried to run the remote wire to the back of my head unit and that did not power the amp. So I spliced the blue/white wire in the wire harness and connected the remote wire to this. This did not power the amp either. So I spliced the red wire in the wire harness that runs from the battery. I connected the remote wire to this and it did not power the amp. The next time I tried to play my cd player, it would play but no sound would come out of any speakers, even with my subs disconnected. Did I blow a fuse or wire somewhere?
  • 116 Answers
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
Larry T
Winona Lake, IN
Posted on Jan 28, 2009
2 Suggested Answers
  • 5 Answers
SOURCE: cd player plays, but no sound comes out of speakers.
first off the amp gets power straight from the battery. the amp is used to power the subs. the subs are suppose to be connected to the amp only( never the speakers).
for the second part you mostlikely killed the wires. you should get some one to look at it and check the wires. thee speakers might need to be re-wired
Posted on Feb 01, 2009
My pyle dvd player has picture but no sound it plays through the subs but not the speakers
What Kind of Vehicle Do you Drive... It is Possible that you have a Factory Amp installed that runs all the stock speakers in the vehicle(LF, RF, LR, RR.). You would have locate the Amp remote wire for the stock amp and hook it up to the remote amp wire on your deck.
Jan 10, 2011 | Pyle PLD7MU Car DVD Player
When the radio is on the sound comes out of all the speakers. when the cd player is on the sound only comes out of the sub woofer
are you running separate amps for the woofer and speakers??? sounds like you have the woofer amp being turned on be the amp remote wire (blue/white) and the speaker amp turned on with the power antenna remote wire (blue). if this is the case you need to use the blue/white to turn both amps on.
Apr 30, 2010 | Eclipse CD2000 CD Player
Is there a wiring diagram for the nikkai EAPA450 Amp
Hi, if you still need a photocopy of instructions email me
If you want instructions in brief this involves POWER CONNECTIONS, PHONO LEAD & SPEAKER CONNECTIONS:
POWER (At the same time when routing these wires, I would connect the PHONO LEADS from the car cd player to the amp, if your car cd player only has 1 preout (1red & 1 white) then you will need two phono splitters, a female to 2 males. Phono leads carry the unamplified sound from cd player to the amp):
~ Permanent 12V+ (Thick lead that is fused direct from battery all the way to the amp, wire must be 20a to 30a +, hence 1cm diameter wire, known as AWG8, Maplin sell cheaper kits then most)
~ Amp REMOTE (A thin insulated cable (5a is OK) from car cd player amp remote wire, this turns the amp on when the cd player is on, if your car doesn't have an amp remote wire, suggest nearest ignition supply or seperate switch that you turn on when you want to turn on the amp)
~ GrouND 12V- (Insulated lead (20a to 30a) to nearest part of unpainted car chassis such as interior panel screw hole, instead of an insulated cable all the way from the batery, this is common practise.
Each speaker has a - negative & + positive, these must connected correctly. The amp has 4 channel, 2 channel labeled as front, 2 channels labeled as rear. Using speaker wire, connect cable from amp to speakers. Note: Ensure the speakers being connected only receive sound from the amp (Not cd player as well, as would damage players or at the very least impair sound)
The amp has a feature called bridgeable this means a sub 8" or 10" sub can be powered by 'bridging' two channels. For example there are 2 ways to bridge power a Sub on the NIKKAI EAPA450:
i) Sub speaker wire positive + to channel RL and Sub speaker wire negative - to channel RR.
ii) Sub speaker wire positive + to channel FL and Sub speaker wire negative - to channel FR.
~ Bass boost, meant to be on for a channel if using sub, otherwise off.
~ X-over mode adjust hi/lo frequencies, only work if both x-over switches are on! Then adjust switch frequency knob, until it sounds right.
~ Gain (Volume knob) adjust volume knob up or down, until it sounds right!
You will need patience! many hand tools and parts such as: Wiring kit, fuse holder 20a/30a, Phono leads, speaker cable, Fork/ring connectors, wire strippers, wire cutters, set of screw drivers, also ueful to have zip ties to tdy excess cable and 'P' cable clips to tidy speaker wire to shelf, etc.
Any more questions just email me
Dec 01, 2009 | Car Audio & Video
Rear speakers not working
Your FM tuner will only generate sound from the front sepakers. CD's, Tape, and I guess mp3 player, as well, will only play through the front speakers.
I've included a link for the manual. The audio on this rig is pretty complex. read through the info, especially pages 11,12,13, and play with the audio controls.
Aug 16, 2009 | RCA RT2500 System
Sub jacks play but door speakers wont play when hooked up to proper wires why
your car has a stock amp for the speakers hook up the blue wire that is on the stock lead wire harness to the remote wire along with the remote for the amp
Jun 29, 2009 | Audiovox VM9311TS
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
Jan 31, 2009 | Kenwood KDC-MP238 CD Player
Kenwood KDC-MP538U - no sound.
My issue was that I didn't have the blue "amp" wire hooked up and I had a factory amp.
Jan 06, 2009 | Kenwood KDC-MP538U Car CD/ MP3 Player
1st make sure your amp is coming on. Use another speaker that you have heard play to test it.
Next test the woofer with a 9 to 15 volt battery. Touch the battery leads quickly across the + and - on one side at a time. The speaker should move and make a pop on both voice coils.
If the amp plays and speakers play, then you need to know the power rating and impedence stability of both amp and speakers. That will determine how they are wired up.
Jul 28, 2008 | Digital Audio DA8012 12" Subwoofer Car...
I replaced the cd player in my accord, the one before worked when i took it out, the radio i put in works as well tested it with hot and ground wires and a speaker to every terminal before i hooked it up...
On many cars there is an exterior amp that the sound goes through before it is sent to the speakers. If the remote turn on wire isnt connected after you take your previous cd player out then the amp wont know when to turn on and therefore no sound will come from your speakers although your cd player is doing its job.
Jul 20, 2008 | 2004 Honda Accord
Kenwood KDC-MP228 CD Player Logo
388 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
